Date/Time: Sat, 05 Sep 2026 02:27:22 +0000
Historical tick data export for MNQ/MES/MGC — does Package 3 cover expired contracts back
View Count: 31
| [2026-09-04 05:00:18] |
| User371572 - Posts: 2 |
On Service Package 3 (Base Standard, $26/month), using the Sierra Chart Historical Data Service (not a third-party feed like OEC): can I export tick-by-tick data via "Write Bar Data to File" for CME micro futures (MNQ, MES, MGC) covering multiple years — including expired quarterly contracts — back to 2011? Or does full multi-year tick depth, or access to expired contracts specifically, require Package 5 or higher? Is there a real per-download size/date-range limit beyond the stated 3000 requests/month?
| [2026-09-04 21:39:39] |
| Sierra_Chart Engineering - Posts: 24776 |
Those contracts you mention were not in existence back to 2011: MNQ, MES, MGC This only applies to historical daily data for futures: Is there a real per-download size/date-range limit beyond the stated 3000 requests/month?
It does not apply to Historical Intraday data or historical market depth data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-09-04 22:00:44] |
Understood on the 2011 point — since MNQ/MES/MGC only exist from their real 2019 launch, my real question is: can Package 3 export tick data for ALL of MNQ/MES/MGC's real, expired quarterly contracts since their 2019 launch (not just the current front-month), via "Write Bar Data to File"? Or is expired-contract access itself restricted to Package 5+?
