Date/Time: Sun, 08 Nov 2026 21:26:19 +0000
SC Historical daily data does not update
View Count: 1576
| [2014-11-05 12:56:13] |
| User626121 - Posts: 82 |
Hi SC Engineering, when I try to update historical DAILY data (SC delayed feed) by disconnecting the Sierra Chart feed and connecting it again (or by closing SC and starting again), nothing happens. In contrast, delayed INTRAday data of the same symbols is loaded. When I update SC to a newer version (if available), then the new daily data is loaded, too. When I start SC for the first time at a given day, most daily symbols update (but not thereafter at the same day). Thanks in advance |
| [2014-11-05 12:58:42] |
(or by closing SC and starting again), nothing happens This most definitely could not be true unless you have exceeded the maximum downloads per day. If that is the case you would see a message of this in the Message Log. The Message Log clearly indicates the historical data downloading that is being done.To update Historical charts, select Edit >> Download Data For All Historical Charts. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-11-05 13:01:54
