Date/Time: Sun, 18 Oct 2026 10:09:11 +0000
Repro for Sierra Chart crash (not common or high pri/blocking)
View Count: 250
| [2026-09-02 18:26:48] |
| User719512 - Posts: 507 |
Sierra Chart Engineering, Found a crashing issue. Sierra Chart v2947 Goal: Change studies 1,2,3 to 41,42,43 to save them as a new Study Collection Repro: A contrived scenario using inbox studies similar to my actual use case. Start with attached chartbook. F6 - Analysis >> Studies Open study 1, MACD, change ID from 1 to 41 OK Open study 2, CBBOAC, change ID from 2 to 42 On Alerts tab, change formula ...from: AND(ID1.SG1>ID1.SG2,ID1.SG1[-1]<ID1.SG2[0]) ...to: AND(ID41.SG1>ID41.SG2,ID41.SG1[-1]<ID41.SG2[0]) OK Open study 3, Subgraph Reference from 3 to 43 Click "Study Subgraph to Reference" so you can change ID2.SG1 to ID42.SG1. When you click it, the editor pops up Select the now Study ID 42 from the list The SG field is blank and trying to Select it crashes Sierra. Work around: After each change ID step, hit OK, exit the studies dialog. (and I hit "save" chartbook as a precaution/test) Reopen with F6 and change the next study/ID, OK, save, repeat Now you can save your study collection with IDs 41-43 so that when applied to an existing chart, the IDs will (probably) not conflict with existing study IDs and the formulas will work as expected. Date Time Of Last Edit: 2026-09-02 18:28:15
| [2026-09-03 23:37:14] |
| Sierra_Chart Engineering - Posts: 25206 |
We are checking on this.
| [2026-09-04 16:35:28] |
This will be resolved in the next release but it is necessary to press the Apply button on the Chart Studies window before making any changes to the individual Study Settings Inputs. Otherwise, Inputs that involve references to other studies will not work.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-09-04 16:36:06
