Date/Time: Sun, 18 Oct 2026 10:09:55 +0000
Market Depth Historical Graph study showing wrong quantities
View Count: 258
| [2026-09-02 08:15:42] |
| User821223 - Posts: 27 |
Hello, I have an issue with Market Depth Historical Graph study that is showing incorrect quantities compared to values provided by both DOM Graph (Market Depth which is drawn on chart (Chart Settings >> [Market Depth] >> Draw DOM Graph on Chart: Yes) and Trading DOM (Trade >> Trading Chart DOM On). As it can be seen, quantities provided by the study (orange numbers) are completely different from values on DOM Graph and Trading DOM like in below picture: https://www.sierrachart.com/image.php?Image=1788336667209.png I have the following settings: Global Settings: Global Settings >> Data/Trade Service Settings >> Common Settings >> Intraday Data Storage Time Unit: 1 Tick Global Settings >> Data/Trade Service Settings >> Common Settings >> Allow Support for Sierra Chart Data Feeds: Yes Global Settings >> [General] >>> Max Depth Levels: 150 Global Settings >> [General] >>> Support Downloading Historical Market Depth Data: YES Global Settings >> [General] >>> Max Historical Market Depth Days to Download: 5 Global Settings >> [General] >>> CME Exchange Data Feed Server Address and Port Override: ds14-2.sierracharts.com Study Settings: 41: Value Type for Highest Quantity for Coloring: Percentage of Maximum Depth 12: Highest Quantity For Coloring: 0 15: Value Type for Lowest Quantity for Coloring: Percentage of Maximum Depth 8: Lowest Quantity for Coloring: 0 4: Extend Last Known Depth: Yes 6: Show Quantity Numbers: Only After Last Bar 9: Display Market Depth Quantities After Last Bar: Yes 14: Depth Quantity Type to Display After Last Bar: Last Depth 36: Determine Min and Max Levels from: Visible Bars 16: Maximum Levels to Display: 0 39: Combine Increment in Ticks: 1 I went through the steps: Market Depth Historical Graph: Downloading Of Historical Market Depth Data Market Depth Historical Graph: Market Depth Historical Graph Not Displaying Did I miss some setting ? I attach a chartbook with the study to the post. Thank you in advance, Przemek |
| [2026-09-02 13:25:25] |
| User431178 - Posts: 909 |
Set this to yes - Chart Settings: Use as Trade Only Symbol (Chart >> Chart Settings >> Symbol >> Symbol menu)
| [2026-09-02 18:44:52] |
Thanks a lot - it solved the problem! I'm trading MES on ES chart so indeed this option must have been checked. Cheers, Przemek |
