Date/Time: Sun, 18 Oct 2026 08:49:54 +0000
trading file needed
View Count: 190
| [2026-09-02 03:37:15] |
| User531621 - Posts: 144 |
My apologies if this is a duplicate message. ON 8/31 around 5 PM- PST , Rithmic had a glitch and i was unable to flatten trades.. I Lost quite a bit of money. I am working with Bulenox on this issue and they have requested a trading file from you if possible. Would you be able to send me the file on that date from 4:30-5:30 PM - PST 8/31 Thank you |
| [2026-09-02 14:00:31] |
| John - SC Support - Posts: 48239 |
We do not have any information for your account. We assume they are referring to the "Trade Activity Log". That is on your system and can be accessed by selecting "Trade >> Trade Activity Log". Refer to the following regarding either Exporting or Saving the log (depending on what you need): Trade Activity Log: Saving to a Text File Trade Activity Log: Importing and Exporting Data For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-09-02 16:03:47] |
i am having an issue following any of these steps. Is there anyway i can hire someone to created this activity log from 8/31 4:30 - 5:30 PST? I need to show the orders and the cancels primarily during this time frame for a specific account. i have a few and dont want the info from other accounts . Thank you
| [2026-09-02 17:52:52] |
This is not something we do. We just do not have the time to help in this manner. If you want one-on-one help, then we recommend contacting one of the people at the following link: Sierra Chart Personal Assistance In terms of what you need to do, you want to adjust the "Display Settings" on the "Trade Activity Log" to cover the time, account, and other parameters that can get you to the specific information you want. Refer to the following for what each setting does: Trade Activity Log: Common Instructions to Set Trade Activity Log Display Settings Once you have the data you want showing, then you can export or save and get that information to whomever you need. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
