Date/Time: Sun, 18 Oct 2026 17:45:25 +0000
Invert prices setting showing 0 as price.
View Count: 229
| [2026-09-01 15:51:04] |
| aznking12 - Posts: 4 |
Hello, in chart -> chart settings -> invert prices, when i use this to invert price, the price is showing as 0. When i use the multiply bars by -1 study or the real time price multiplier/historical price multiplier, i can see the prices (negative). However, the problem is that, when i use the latter, chart drawings from one chart (at the positive prices) are not shown on the inverted price chart. Chart drawings copying works when i use the invert prices setting (but prices are shown as 0) How can i get 1) chart drawings to be copied between charts (positive and inverted prices) 2) Also show the inverted (negative) prices? Date Time Of Last Edit: 2026-09-01 15:56:55
| [2026-09-01 16:16:15] |
| Sierra_Chart Engineering - Posts: 25206 |
What is the symbol of the chart?
| [2026-09-01 16:23:52] |
nasdaq100
| [2026-09-01 16:28:12] |
| Calculus - Posts: 150 |
It would be one hell of a feature if Sierra could add a Hot Key to flip the chart from normal to Inverted and back again.
| [2026-09-24 15:31:40] |
Hey sierra chart, is this possible?
| [2026-09-24 17:54:04] |
| John - SC Support - Posts: 48239 |
There is no built-in shortcut options for the "Invert Prices" setting. We have noted this as a Feature Request. We can not say when we would get to any particular request. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-09-24 22:45:40] |
| user2732 - Posts: 9 |
Please, I second a request for a hotkey for price invert.
