Date/Time: Fri, 16 Oct 2026 06:03:08 +0000
Send attached orders
View Count: 177
[2026-08-31 20:19:57]
User165981 - Posts: 64
I typically will scale in my position in 2 lots. After Im in, I do a send attached orders by position and have to do it for each order. Is there a way to have 1 click to attach to all orders as a single so I can set my take profit easily. For example. I scale in up to a 10 lot, instead of send by attached order 10 times, do something once and it will allow me to move the TP to different prices?
Hopefully this makes sense
[2026-08-31 21:33:30]
John - SC Support - Posts: 48222
It sounds like you want to use the Scale In option. Refer to the following:
Attached Orders: Scaling In
[2026-09-01 13:08:36]
That kind of helps, but is there a way to tell it to make each an individual 1 lot with one click? So if I have 5 lot on and click send send order by attached posotiion once, it would add 5 1 lot stops and targets? That way I can move the tagets to where I want individually.
[2026-09-01 16:21:15]
To have everything separate, you would not use Scale In, and you would have to send each order individually. There is not a way to send a larger quantity with a single click and then have them actually entered as separate individual orders.
To do something like what you want in an automated fashion, you would need to develop a custom study. Refer to the following:
Automated Trading From an Advanced Custom Study
https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php
