Date/Time: Fri, 16 Oct 2026 06:04:11 +0000
Erase all* text drawings
View Count: 157
[2026-08-31 14:37:08]
User14953 - Posts: 268
How to erase all* non-text, and erase all* text drawings?
In SC v 2813 after running "erase all non-text drawings" (alt-shift-l), and "erase all text drawings" (alt-shift-t), if a new line is drawn and alt-5 (erase drawing mode) is pressed, a drawings number is shown, e.g. 45* instead of the expected result = 1.
In erase drawing mode if a number < e.g. 45 is entered, then the 45 number will be reduced by one for each time that operation is repeated but is too time consuming for say, 75 residual charts for each chart in a large chartbook.
[2026-08-31 17:53:28]
John - SC Support - Posts: 48222
We are not able to reproduce this in the current release version (v 2946). We would need for you to update to the current release to see if this issue still exists for you and if you are able to reproduce it in the current release, then we would need more information on the workflow since we can't reproduce it with what we know at this time.
If you want to update, then follow these instructions:
