Date/Time: Sun, 29 Nov 2026 22:43:05 +0000
Can you please adivse
View Count: 226
| [2026-08-31 13:52:44] |
| coachted - Posts: 545 |
2026-08-31 09:48:01.996 | Denali Data Feed | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 2 2026-08-31 09:48:01.996 | Denali Data Feed | MaxConnectionsForSameDevice = 3, NumCurrentConnectionsForSameDevice = 1 I pay for 2 pc to be connected and i have 2 pc connected |
| [2026-08-31 17:40:22] |
Those are a standard message that is put into your Trade Service Log. You are not having any issue according to what they state. In particular, you are allowed to get data to 2 different computers at the same time and you are allowed to get data on each computer for up to 3 different installations of Sierra Chart (separate installations, not sub-instances). 2026-08-31 09:48:01.996 | Denali Data Feed | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 2
The above is stating that you have the data going to two different computers at the same time and you are allowed to get data to two different computers at the same time. 2026-08-31 09:48:01.996 | Denali Data Feed | MaxConnectionsForSameDevice = 3, NumCurrentConnectionsForSameDevice = 1
The above is stating that you are allowed to get data to 3 different installations on the computer where that Sierra Chart is running and you are currently using 1 of those three. -- If you are actually having an issue of some kind, then we need to know what it is. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
