Date/Time: Mon, 30 Nov 2026 00:05:23 +0000
Tool: Type Text - using saved configurations make the text disappear
View Count: 241
[2026-08-29 02:40:37]
Saj - Posts: 1
Hey. I am on version 2945 64-bit revision 57948
My issue is the Type Text tool. I have saved my configurations and when I try to apply them the text I am applying to disappears.
[2026-08-29 06:59:52]
Sierra_Chart Engineering - Posts: 25523
Refer to this setting:
Global Settings >> Tool Settings >> General >> Shortcut Menu and Properties Window >> Applying Tool Configuration to Existing Drawing Updates Text : No
