Date/Time: Mon, 30 Nov 2026 00:05:23 +0000
aRequest about Additional stock symbols
View Count: 283
[2026-08-28 19:20:39]
johnny scaddan - Posts: 1
I’m a new subscriber and really enjoying the Sierra Chart platform so far.
I just wanted to ask whether you have plans to add some prominent nasdaq listed stocks that currently don’t appear to be available, including:
* SPCX
* AVGO
* SNDK
* COIN
* NBIS
just to name a few
I understand that SPCX is a recent IPO, but given the size and significance of these companies, I was wondering if they are likely to be added to Sierra Chart anytime soon.
Thanks for your help, and great work with the platform.
[2026-08-28 20:54:46]
The data for all of the stocks that you reference is available from both of our equities exchanges (U.S. Equities Consolidated Tape and NASDAQ TotalView).
Keep in mind that we do not list all the stocks in the "File >> Find Symbol" window, as there are simply too many of them, and they change often enough that this would be too difficult to keep up with. You just need to type in the ticker of the symbol you want, with the appropriate suffix, based on what exchange option you want to get the data from, in the "Selected Symbol" field on the "Find Symbol" window.
If it is not the above (i.e. you have opened a chart for these, but are not getting data), then let us know. You should be getting the data.
