Date/Time: Sun, 29 Nov 2026 04:18:36 +0000
NVPOC in daily chart
View Count: 395
| [2026-08-28 16:34:33] |
| User193259 - Posts: 10 |
Hi, I'd like to see the daily VPOC in my daily chart, which has different volume profiles drawn. VAH and VAL would be a plus. This is the chart: https://www.sierrachart.com/image.php?Image=1787934674917.png The attached image is the chart I want to copy. Thanks |
Private File |
| [2026-08-28 16:58:35] |
We are not certain what exactly you are asking. The VPOC, VAH, and VAL can be displayed from a Volume Profile. Refer to the following Input and the 5 below it for the Volume by Price study: Volume By Price Study: Highlight Value Area Alternatively, you can use the "Volume Value Area Lines" to get the same information if you do not want a Volume by Price profile for that time period: Volume Value Area Lines For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-08-28 18:14:00] |
This works, thanks. Would it be possible to extend the VPOC lines? |
| [2026-08-28 20:48:29] |
Refer to the following Input: Volume By Price Study: Extend Point of Control For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-08-29 09:43:09] |
Thanks for the reply. My bad, I meant using the Volume Value Area Lines study. That study fixed my problem, but it seems it doesn't have the option to extend the VPOC lines |
| [2026-08-31 13:47:41] |
How are you wanting to extend the lines? Are you wanting to extend until a future intersection with a bar, or just have it display across the entire chart going forward? Or something else?
| [2026-08-31 15:49:26] |
Until future intersection
| [2026-08-31 17:55:10] |
Then follow the instructions at the following link: Color Bar Based on Alert Condition: Creating Extension Lines for Another Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-09-01 16:55:38] |
It worked, thanks!
