Date/Time: Sun, 29 Nov 2026 22:43:05 +0000
DOM Display Issue When Grouping Ticks
View Count: 367
| [2026-08-27 23:53:58] |
| MTScalper - Posts: 35 |
Hi at all. After the latest updates, the DOM is once again displaying very poorly when ticks are grouped. I’ve attached two screenshots of the exact same DOM, without making any changes to the settings. In the first screenshot, the DOM is grouped by 4 ticks with the scale set correctly, and you can see that the cells are properly filled across the background, making them clear and easy to read. After the latest update, however, the cells have become very thin again, making the DOM much harder to read. Could you please look into this and fix the issue? In its current state, the DOM becomes extremely difficult to read when ticks are grouped this way. Cordial Greetings |
| [2026-08-28 05:45:13] |
| Sierra_Chart Engineering - Posts: 25523 |
Check this setting: Global Settings >> Chart DOM Settings >> Other >> Other Settings >> Chart DOM Volume Bars Fill Combined Price Level Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-08-30 10:13:00] |
Thanks you so much
