Date/Time: Sun, 08 Nov 2026 21:26:18 +0000
Re: Historical Data
View Count: 1316
| [2014-11-05 07:55:53] |
| User41512 - Posts: 58 |
Hi, I have noticed that with some symbols (XPDUSD for example) that I cannot get data on my charts before 2010, even though in chart settings i have set the "use number of days to load" to significantly more than that. Please advise. Thks |
| [2014-11-05 13:03:42] |
The Historical Daily data that you get for a particular symbol is all that is available. For additional information refer to help topic 6: Http://www.sierrachart.com/index.php?page=doc/helpdetails6.html Assuming you are referring to Historical Daily charts. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
