Date/Time: Thu, 26 Nov 2026 22:32:16 +0000
[Programming Help] - SCString .Format() and .AppendFormat() causing SC to crash
View Count: 312
[2026-08-27 21:30:49]
drinkcodejava - Posts: 47
This one has been driving me nuts the past few days. The following custom study causes Sierra Chart to close by itself without saving. I am running SC version 2939 on a non-ARM x64 machine, and compiling using a standard remote build of the DLL. Can anyone duplicate this behavior on their computer?
#include "sierrachart.h"
SCDLLName("SCString Format Crash")
SCSFExport scsf_SCStringFormatCrash(SCStudyInterfaceRef sc)
  // Section 1 - Set the configuration variables and defaults
  if (sc.SetDefaults)
    sc.GraphName = "SCString Format Crash";
    sc.StudyDescription = "";
    sc.AutoLoop = 0; // Setting to 1 still results in crash
    return;
  // Section 2 - Do data processing here
  SCString StudyStr;
  // Variables for account/trade/position parametrics
  float CurrMargin = 0.0f, CurrNLV = 0.0f;
  float Limit_NLV80Pct = 0.0f;
  CurrNLV = 1000.0f; // Crashes for values >= 999.996 or <=-999.9, but not consistently
  Limit_NLV80Pct = CurrNLV * 0.80f;
  StudyStr.Clear();
  StudyStr.Format("\nNLV: $%.2f | ", CurrNLV); // Including any leading escaped/special character causes a crash: \t, \n, \", \\, \r, \'
  StudyStr.AppendFormat(" 80% NLV: %.2f (%.2f)", Limit_NLV80Pct, CurrMargin/Limit_NLV80Pct); // Including the % character after the 80 causes a crash
  // Commenting out the previous 2 lines and using this following line instead does not cause a crash
  // StudyStr.Format("\nNLV: $%.2f | 80% NLV: %.2f (%.2f)", CurrNLV, Limit_NLV80Pct, CurrMargin/Limit_NLV80Pct);
If anyone else is able to duplicate this, I think I will try to escalate it from Programming Help, but I just want to make sure I'm not doing something stupid. Thanks!
[2026-08-28 01:18:36]
User719512 - Posts: 548
Did you ask AI like Grok or ChatGPT for guidance? This should not take a few days to solve. This is a common pitfall we have all seen, forgotten, mistyped, etc.
The % after 80 is a format specifier, not a literal percent. Crashes happen when one forgets to escape %.
Escape it as %%:
StudyStr.AppendFormat(" 80%% NLV: %.2f (%.2f)", Limit_NLV80Pct, CurrMargin / Limit_NLV80Pct);
or keep it in one call:
StudyStr.Format("\nNLV: $%.2f | 80%% NLV: %.2f (%.2f)", CurrNLV, Limit_NLV80Pct, CurrMargin / Limit_NLV80Pct);
[2026-08-28 02:44:18]
Thank you!! *Sigh*
I figured it was something trivial and stupid like that. Thanks again for taking the time to respond.
I asked Google Gemini for characters that needed to be escaped in C++, but '%' didn't come up in the list. Only the ones requiring the '\'. What tripped me up was that it ran fine if I omitted the leading '\n' or if I used one .Format() call like you suggested, even without the double percent (%%) sign.
