Date/Time: Thu, 26 Nov 2026 22:32:18 +0000
Trade Window Reports That Targets and Stops Don't Match, Even Though That's Not the Case
View Count: 284
[2026-08-27 20:28:02]
Daniel - Backtesting.club - Posts: 177
I have several Trade Window configurations saved, each with a preset quantity of 1 and the “Ignore Quantity On Load Configuration” setting enabled.
When I set a different order quantity and switch to a different preset (configuration), the Trade Window displays the message “Qty: 1 Target/Stops NoMatch.” Here’s a video demonstrating this:
https://youtu.be/lYk0xNhGKx8
I don’t understand why this warning appears in this case. After sending the order to the market, both the target and the stop-loss have the same number of contracts (the same size), so everything is fine.
The only thing I can think of is that the error message is caused by a mismatch between my selected order size and the order size configuration. Could you please clarify this for me? Thank you.
[2026-08-28 05:55:25]
Sierra_Chart Engineering - Posts: 25497
In the next release with this kind of configuration, the Attached Orders will be updated to match the order quantity on the Trade Window at the time the configuration is loaded.
[2026-08-28 06:33:50]
Thank you so much!
That's exactly the solution I wanted to suggest 😄
