Date/Time: Thu, 26 Nov 2026 23:36:36 +0000
Limit for number of concurrenctly streaming symbols
View Count: 259
| [2026-08-26 20:51:40] |
| User582707 - Posts: 29 |
Hello, this question is regarding the consolidated equities feed. As far as I understand, there is a limit for how many symbols you can get concurrent live data for, 2250 - is that correct? If so, does this limit apply per installation/denali connection, or, per account/user. Thank you |
| [2026-08-27 00:37:23] |
| Sierra_Chart Engineering - Posts: 25499 |
It is per Sierra Chart account and if you want to go over that limit, create another Sierra Chart account. It will be an additional cost but that is the only way to have a higher symbol limit now.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-08-27 00:37:50
