Date/Time: Thu, 26 Nov 2026 23:36:33 +0000
Footprint chart is sharing with different chartbook.
View Count: 247
[2026-08-26 14:49:20]
User602969 - Posts: 20
Hey.
I have a problem with footprint chart across different chartbook.
Lets say I have Chartbook for NQ symbol and Chartbook for ES Symbol. (they both have number bar study).
When i switch the chartbook from NQ to ES, NQ number bar chart is still loading in ES bar, while ES number bar is also open. Theoretically speaking, NQ number bar chart should be closed (run at backend) then open ES number bar chart. I don't know how to fix this issue.
Pls note that, all my chart is detached from the chart.
Regards.
[2026-08-26 15:22:59]
We think what you are stating is that when you change to the ES chartbook, an NQ chart from the other chartbook is still visible.
If the above is correct, then that NQ chart has the option for "Window >> Window Always Visible" enabled. If you do not want to view it when you have your ES chartbook active, then select that option again for that chart to remove the checkmark and make that option disabled. Refer to the following:
Window, CB and CW Menus: Window Always Visible (Window)
