Date/Time: Thu, 26 Nov 2026 23:36:39 +0000
AAPL-NQTV / Market Data
View Count: 301
| [2026-08-26 13:34:36] |
| ChrisK - Posts: 54 |
Good morning, I’m currently running on SC v2933. Loaded AAPL-NQTV on 5 tick combined increment on market depth data. I see way less limit orders than usual and no pulling/stacking data. Is there an issue with the data feed this morning? Please advise and thank you. Date Time Of Last Edit: 2026-08-26 13:35:27
| [2026-08-26 13:45:57] |
| Sierra_Chart Engineering - Posts: 25499 |
We did do some updates yesterday evening related to NASDAQ Totalview. But we are not seeing any problems. We are checking on this more closely now.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-08-26 13:46:06
| [2026-08-26 13:52:12] |
We want you to update to the current version of Sierra Chart. Update instructions: Software Download: Fast Update The data looks correct to us: https://www.sierrachart.com/image.php?Image=1787752135317.png We also did try combining price levels and did not see any issue with that either. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-08-26 14:07:50] |
Thank you for the quick response. I have updated to v2945 and it looks correct now. Appreciate you all. Have a great day. |
