Date/Time: Thu, 26 Nov 2026 23:36:37 +0000
issue while updating ARM version of Sierra Chart
View Count: 408
| [2026-08-25 11:56:47] |
| Chris32 - Posts: 81 |
Hello SC team here is the issue I encounter : Running the ARM executable - Help> Download current version - Run Program after Install Complete option is selected - Install then the current version gets successfully installed but instead of having the new ARM executable launched after clicking Close, nothing comes up. So I launch it manually and SC starts. But I notice that SierraChart_64.exe is launched as a background process and stays there consuming resources unless it is killed manually. |
| [2026-08-25 14:59:19] |
How are you starting the new ARM version? Are you certain that the ARM version is being started and not the standard _64 executable? What happens when you stop the SierraChart_64.exe process? Does this impact the running Sierra Chart at all? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-08-25 16:16:51] |
I have a shortcut to C:\SierraChart\SierraChart_ARM64.exe that I use to start the ARM version. I can see in the task manager (processes) that it does indeed start SierraChart_ARM64.exe. I can also see that SierraChart_64.exe appears as a background process from the moment I click Close. Stopping the SierraChart_64.exe process doesn't do anything visible at all, doesn't impact my ARM instance. |
| [2026-08-26 00:56:19] |
| Sierra_Chart Engineering - Posts: 25499 |
We are checking on this.
| [2026-08-26 01:19:04] |
This will be resolved in the next release.
