Date/Time: Mon, 23 Nov 2026 20:37:50 +0000
SIM mode issue
View Count: 288
[2026-08-25 07:26:30]
shy - Posts: 35
currently I am trading the SIM mode, and it appears that the system opens trades by it self! (like ther is an algo running in the back).
needless to say I installed no algo...
Whats the problem and how to fix it?
Regards,
Shy
[2026-08-25 14:29:44]
John - SC Support - Posts: 48623
The system is not opening trades by itself.
When exactly does this occur? Is it during a replay?
Do you have any kind of study setup to do trading, even a Spreadsheet System for Trading, or one of the included trading studies?
[2026-08-26 05:32:25]
Sierra_Chart Engineering - Posts: 25466
Use the Trade Activity Log to determine the origin of the order that you are seeing:
Trade Activity Log Analysis: Determining the Origin of a New/Modified Order
[2026-08-26 06:09:15]
shy - Posts: 35
Hi John,
I run no kind of study / system / app that suppose to openn trades by it self (I don't even know how to do it).
lets make an experiment: tommorow (August 26) I will not tuch the system at all. If there will be any trade - it is a problem. And since I will make no trade, you will be able to track the log or what ever you need to figur out the issue.
Regards,
Shy
[2026-08-26 14:30:11]
That is fine.
Again though, we are curious if this is during a replay, as when you are running a replay and if you have not cleared the trading data (you are prompted for this when you start the replay), then you will see what appears to be a position being opened when the replay gets to a point where a postition existed. This is the system just showing you that position at that time. It is not a new position.
