Date/Time: Mon, 23 Nov 2026 23:10:35 +0000
Remove multiple columns - Study Summary window
View Count: 294
[2026-08-24 21:21:48]
HeyUgly - Posts: 290
Hello
For some reason there is no "organize columns"setting when using the Study Summary window. I have a study that is outputting to the window, works good, but there is like 10 stock columns i dont need to see like last/daily change low/volume etc - see screenshot - how do i remove those to only see my studies columns that are on the very end? seems like this should be a very basic setting to choose which columns you want to display.
Thanks in advance
imageScreenshot 2026-08-24 151900.png / V - Attached On 2026-08-24 21:21:35 UTC - Size: 22.27 KB - 87 views
[2026-08-24 21:34:05]
John - SC Support - Posts: 48633
Select "Settings >> Display Daily Quote Data Fields" to turn off those items.
Or, you can select "Settings >> Set Quote Fields" to define which quote fields you want to keep and which to remove.
Refer to the following and the item below it:
Study Summary Window: Settings >> Display Daily Quote Data Fields
