Date/Time: Mon, 23 Nov 2026 23:10:37 +0000
Large Trade Indicator Separate Bid/Offer?
View Count: 276
[2026-08-24 19:13:02]
User172061 - Posts: 36
Is it possible to have 2 instances of the LTI but have separate settings for the Bid side and the other one to have different settings for the offer? Ideally id like to have different shapes for both but i dont see a way to do that.
[2026-08-24 19:50:07]
John - SC Support - Posts: 48633
There is not a way to do this in one chart, as you can only have 1 copy of the "Large Volume Trade Indicator" per chart, and the Large Volume Trade Indicator does not have support for separate Bid and Ask thresholds.
And, unfortunately, there is not a way to specify to only have Bid or Ask data in a chart, so you can not get specifically only Ask or Bid information from the Large Volume Trade Indicator - it is going to give you whichever is the greater value.
