Date/Time: Mon, 23 Nov 2026 23:10:36 +0000
Create a time range for auto trade
View Count: 352
[2026-08-24 14:37:30]
User930387 - Posts: 6
I want to create a time range (e.g. trade only between 8am - 12pm) for my auto trade and close all position at end of normal trade hours. how do i do it?
[2026-08-24 15:31:05]
John - SC Support - Posts: 48633
Refer to the following for how to flatten positions for a chart at a specific time:
Basic Trading and the Trade Window: A >> Flatten And Cancel at Set Time
There is nothing built into Sierra Chart itself that control the hours for trading. But if you are using a custom study, then you can control this with the following function:
ACSIL Interface Members - Functions: sc.SetTradingLockState()
[2026-08-25 10:56:23]
Thanks for prompt reply. however i am not able to access data feed as per attached. m i missing smthg here?
imageScreenshot (21).png / V - Attached On 2026-08-25 10:52:31 UTC - Size: 260.05 KB - 67 views
[2026-08-25 14:35:05]
ForgivingComputers.com - Posts: 1256
You can do both with this tool: https://forgivingcomputers.com/advanced-risk-management-tool-for-sierra-chart/
[2026-08-25 15:33:20]
The fact that "Connect to Data Feed" is greyed out means that you are already connected.
Are you having some kind of issue with your data?
