Date/Time: Mon, 23 Nov 2026 23:10:36 +0000
Fix Field incorrect
View Count: 301
| [2026-08-24 13:44:06] |
| User165981 - Posts: 66 |
Im getting this error on marklet orders 2026-08-24 09:34:06.362 | Order update (Order reject). Info: Teton CME Routing (Order reject). Info: CME (Rejected). Text: FIX field incorrect 'Illegal Price: '2910600.1 contract 'MNQU6' (ticks in 25, CAB of 0)'. SecurityID=42004800. Operator=******. Text: Tag: SimpleBracket.twconfig. Text: SimpleBracket.twconfig. Internal Order ID: 1419. Service Order ID: 61475. Symbol: MNQU26_FUT_CME. Broker is AMP Im on 2942 |
| [2026-08-24 13:46:32] |
| John - SC Support - Posts: 48633 |
Refer to the following: Teton CME Price Multiplier Issue v2942 For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-08-24 14:30:57] |
| Sierra_Chart Engineering - Posts: 25470 |
Go back to an earlier version: Help >> Install Previous Version.
| [2026-08-24 14:34:35] |
I did and it's all good. Thanks!!
| [2026-08-25 03:37:33] |
This is now resolved in the latest release. You can update to the current version.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-08-25 03:37:41
