Date/Time: Mon, 23 Nov 2026 23:10:38 +0000
GetACSDrawingByLineNumber stack corruption v2941/2942
View Count: 373
[2026-08-23 11:20:11]
User907968 - Posts: 887
GetACSDrawingByLineNumber() appears to write beyond the end of an older s_UseTool structure when running under Sierra Chart v2941/2942.
The study DLL was compiled against an earlier Sierra Chart header, v2911.
Observations:
- v2940, the call does not appear write beyond the end of the older s_UseTool.
- v2941, one byte at offset 0x402 is modified, i.e. the third byte beyond the end of the older 0x400-byte structure.
- The overwritten byte appears to correspond to the new 8-bit 'ShowMiddlePointPrice' field added to s_UseTool in v2941.
- Visual Studio detects this as stack corruption because the write modifies the 0xCC debug guard/fill bytes following the stack-allocated s_UseTool.
- Testing a Release build of the same study results in immediate process termination when this code path is executed.
[2026-08-23 16:41:47]
User719512 - Posts: 546
I also see this on an existing study compiled for v2911. Sierra just crashes and closes. This will break a lot of studies and cause a lot of support requests if not patched quickly.
tl;dr
I see this from a debug build of my v2911 study.
Run-Time Check Failure #2 - Stack around the variable 'Tool' was corrupted.
triggered by:
call _RTC_CheckStackVars (07FFE6EEAD9C8h)
[2026-08-23 19:16:29]
Sierra_Chart Engineering - Posts: 25470
We will get this resolved. We apologize for this.
It was a mistake by one of the programmers and we are going to make sure, that they are not permitted to touch ACSIL structures again.
Date Time Of Last Edit: 2026-08-23 19:40:36
[2026-08-24 17:33:56]
Confirming this is fixed with the updated headers in v2943 which now that Sierra is compiled with, does not try to access ShowMiddlePointPrice unless v2941+.
Studies built for v2911 now run as expected.
[2026-08-24 17:35:02]
Thank you for the fast fix, appreciated.
