Date/Time: Tue, 24 Nov 2026 22:19:38 +0000
Service Package 11 vs. 12
View Count: 475
| [2026-08-22 23:25:17] |
| drinkcodejava - Posts: 47 |
Hello Support, I am considering changing from Service Package 12 to 11 but would like to clarify how it would affect availability of data for certain Trade DOM columns and ACSIL custom studies. From reading the descriptions, it appears the only difference is the MBO Data, i.e. resting/limit orders at each price level and relative order of the queue. On a Trade DOM, are the only columns populated with this data the Bid Market Orders, Ask Market Orders, and Combined Bid Ask Market Orders columns? If I change to Service Package 11, - will I still be able to see data in the Trade DOM's Combined Bid/Ask Market Depth Pulling/Stacking column? - will I still be able to see data in the Trade DOM's Bid Size/Buy and Ask Size/Sell columns? - will member functions sc.GetBidMarketDepthStackPullSum() and sc.GetAskMarketDepthStackPullSum() still return correct values? Thank you! |
| [2026-08-23 02:40:49] |
| Sierra_Chart Engineering - Posts: 25476 |
Yes to all.If I change to Service Package 11, - will I still be able to see data in the Trade DOM's Combined Bid/Ask Market Depth Pulling/Stacking column? - will I still be able to see data in the Trade DOM's Bid Size/Buy and Ask Size/Sell columns? - will member functions sc.GetBidMarketDepthStackPullSum() and sc.GetAskMarketDepthStackPullSum() still return correct values? To change your Sierra Chart Service Package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on the "Set Service Package for Renewal" link.
Or go to this page: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation You will need to login if you are not currently logged in. In the "Available Services >> Choose Usage Time Service Package" frame, select the Service Package that you want to set your account to. Press the "Set" button. The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price. There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted. When changing between Sierra Chart Service Packages, the usage time ending date on your Sierra Chart account is adjusted based upon the price differences between the package you are changing from and the package you are changing to. When changing to a higher priced package, your usage time ending date will be brought back closer in time. When changing to a lower-priced package, your usage time ending date will be brought forward further out in time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
