Date/Time: Fri, 20 Nov 2026 22:01:42 +0000
Trade window not wide enough to show 'Currency Value & Points' for DPL
View Count: 227
| [2026-08-21 17:06:49] |
| NorthernTrader_21 - Posts: 15 |
Hello! Trade window is not wide enough to display full DPL and I only see currency and a comma. Is there a solution? |
| [2026-08-21 17:47:12] |
| John - SC Support - Posts: 48610 |
There is not a way to change the size of the DPL field on the Trade Window. One option that you can try is to add the "Daily/Net Profit/Loss" control bar item to a control bar and see if this gives you enough space for what you need. You will find this item in the "Special Items" at the bottom of the "Customize Control Bar" window. Otherwise, you would have to use the "Trade Activity Log" to view the information. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
