Date/Time: Fri, 20 Nov 2026 22:01:43 +0000
Rendering issues with Initial Balance study
View Count: 370
[2026-08-21 14:12:19]
MarkusK - Posts: 126
I use the Initial Balance study to show IB High and IB Low on my charts (for ES and NQ).
However, I don't want to continue the lines all through the Globex session of the following day. (and I didn't find an option to disable that and end the lines exactly at the end of RTH session)
Therefore, I created a second chart that only shows the time period 09:30:00 - 16:59:59 (1 min chart). I put the Initial Balance study on that chart and then I included it with the Study/Price Overlay study on my main trading char (5 min chart).
It generally works, but I notice a strange rendering issue. Please see attached screenshot for this:
Instead of starting a the first candle at 09:30, there is one line segment drawn on the previous candle (09:25) as well (exactly at the price levels of the previous session's IB High and Low).
I assume that I did something wrong in my study configuration, but I simply can't figure it out. Please also find attached screenshots of the IB study and the corresponding Study/Price Overlay.
Any assistance with that would be much appreciated.
image01 - Rendering Issue.png / V - Attached On 2026-08-21 14:10:21 UTC - Size: 23.21 KB - 70 views
image02 - IB Study Settings.png / V - Attached On 2026-08-21 14:11:53 UTC - Size: 104.61 KB - 69 views
image03 - Study Price Overlay.png / V - Attached On 2026-08-21 14:11:56 UTC - Size: 47.78 KB - 66 views
[2026-08-21 15:56:51]
You must have data from 09:25 in your source chart that is being overlaid to the destination chart.
If you get us those two charts then we can take a look at how you have this setup and help you to resolve it. Follow the instructions at the following link, but get us the 2 charts, not just one, and make sure the issue is still showing in the new chartbook you provide to us:
[2026-08-21 18:06:05]
Hi John, thanks a lot for taking a look at this. It's much appreciated!
I created a new chartbook for you with only the two charts and attached it. I removed every other chart and study, so only the IB study remains in the first chart (#2) and the Price/Overlay study in the second chart (#12).
I tested it and can confirm that the issue still occurs (see right chart in attached screenshot).
However: the rendering issue doesn't appear immediately when you load the chartbook. There seems to be some kind of "trigger" for it.
I don't exactly know what it is, but after some testing, I found a reliable way to trigger the issue:
1. Open the Chartbook
2. Start a replay on chart #12 (Chart > Replay Chart > Replay Chart (Control Panel))
3. Set the start date and time to 2026-08-21 and 09:29:50
4. Set the playback speed to 5.00
5. Start the playback
The rendering issue (horizontal lines over/under the candle at 09:25 in chart #12) will appear at 09:31, when the second 1 minute candle opens on the 1m chart #2. Somehow, this seems to be the trigger.
Thanks in advance for taking a look at it!
imageRendering Issue Still There.png / V - Attached On 2026-08-21 18:03:20 UTC - Size: 166.62 KB - 65 views
Private File
[2026-08-21 18:29:59]
We do not need to look at the chartbook, we can tell you that what you are seeing is correct due to the fact that you are running a replay.
Since your replay starts at "09:29:50", it will be generating some data for the minute that has a starting time of 09:29:00 in the source chart. Therefore, you are seeing that IB information displayed in the destination chart in the 09:25:00 bar, since that covers the time of 09:25:00 to 09:29:59.
We are not certain what you are wanting to accomplish exactly with the replay, but you are going to get that item showing due to what you are doing.
[2026-08-21 19:32:44]
This seems to be a misunderstanding:
I was seeing the exact same rendering issue (IB bars showing in the destination chart at 09:25 bar) today during live trading.
Please kindly have a look at the very first screenshot I attached to my original post: that screenshot was not from any replay, but from live trading today.
Therefore, it is definitely not restricted to market replay.
The only reason I suggested to do the replay was because that's the most reliable way I found to reliably and immediately reproduce the issue.
Since the rendering issue will not immediately occur when you open the chartbook, and since I don't know what triggers it exactly, the only alternative would be to open the chartbook and wait for it to happen.
[2026-08-22 12:43:54]
Quick update: I figured out that the study "High/Low for Time Period - Extended" does exactly what I need. So I got rid of the additional chart and the Initial Balance study completely. That effectively fixes the issue for me.
