Date/Time: Sun, 08 Nov 2026 21:26:16 +0000
[User Discussion] - Spreadsheet study is not showing.
View Count: 1577
| [2014-11-04 18:37:26] |
| User48557 - Posts: 138 |
I added a spreadsheet study to about 20 different charts in the same chartbook (different products). They all worked fine yesterday when I added them. Today when I started my charts back up the study isn't showing on the charts. When I go to (studys) the spreadsheet study is still saved in there, so I don't know why it wouldn't be showing up on my charts.
| [2014-11-04 19:14:04] |
Make sure the Hide Study option is not checked in the Study Settings window for the Spreadsheet study and make sure it is set to the correct Chart Region you want to see it in. Is also not clear what you are seeing and what you expect to see. In general, the proper approach to this would be to start over again with the Spreadsheet Study for a particular chart to help see what the problem is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-11-04 19:14:24
