Date/Time: Tue, 24 Nov 2026 22:19:41 +0000
DOM Volume Profile
View Count: 343
[2026-08-21 03:17:50]
Selfmadejared - Posts: 11
Hello, I have a Volume Profile on my DOM & also on my regular chart. However they show different POCs & VAs. I have settings configured identically. My regular chart VP shows the POC & VA for the RTH session, and I want to do the same for the VP on my DOM. But for example on 8/20, my regular chart VP shows the POC 7703.75, but the DOM shows the POC as 7672.25. I have both set to the setting "Volume Graph Period Type: From session start time to end" and the proper Start/End time are in the settings (9:30 - 16:14:59)> Any help would be appreciated thank you.
[2026-08-21 14:58:21]
There must be something that is different between the studies. Most likely it is the "Ticks per Volume Bar" as this defaults to 2 for a chart and 1 for a Trading DOM. These must be the same to get the exact same POC and VAHs. But it could be any number of other settings within the studies that have to be the same.
There are also many chart settings that can affect this, such as "New Bar at Session Start" or "Include Odd Lot Trades" (depending on the particular symbol for this one). So you would have to ensure that the chart settings are also the same between the chart and the Trading DOM.
Date Time Of Last Edit: 2026-08-21 14:59:39
