Date/Time: Wed, 25 Nov 2026 09:28:01 +0000
Rolling volume profile based on volume
View Count: 264
| [2026-08-19 19:28:42] |
| NorthernTrader_21 - Posts: 15 |
I have selected volume graph period type to "Specificed Volume" but I don't want separate profiles printed every so often I want a single profile attached to the right of my screen that updates based on a moving window defined by a specific volume. This is possible with time but not with volume it seems. Is this possible at all? |
| [2026-08-19 19:46:39] |
| John - SC Support - Posts: 48648 |
You are correct that there is not an option to have a single profile based on volume. The workaround for this would be to setup a chart that has the bars based on the volume you want. Then setup the Volume by Price to have the following Inputs: - Volume Graph Period Type: One Period Based on Bar Count - Number of Bars for 'Based on Bar Count': 1 - Right Align Volume Bars: Yes - Align to Far Right: Yes The above will give you a new profile when the new bar starts, so if you want a "rolling" profile, you would need to use multiple bars and spread the volume out among those bars. The larger the number of bars, the more granular the rolling profile will be. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-08-19 19:48:08
