Date/Time: Tue, 17 Nov 2026 19:06:57 +0000
Time Zone & Axis:
View Count: 370
[2026-08-18 16:41:40]
Rafalitto - Posts: 13
Hello. Im Rafael from Spain
- I wish to adjust the chart timezone to match my local PC time (Spain Time Zone). Right now my PC shows 2:05 PM but the chart is showing 12:05 PM.
- On the bottom axis, I want to see the date format ordered by Day, Month Name, and Year in that order, with the month written in text (like "17 August 2026")
Hola, soy Rafael, de España.
- Quiero ajustar la zona horaria del gráfico para que coincida con la hora local de mi PC (zona horaria de España). En este momento, mi PC marca las 2:05 p. m., pero el gráfico muestra las 12:05 p. m.
- En el eje inferior, quiero que el formato de fecha aparezca en el orden: día, nombre del mes y año, con el mes escrito en texto (por ejemplo, "17 de agosto de 2026").
Thanks a lot
[2026-08-18 16:50:14]
User135243 - Posts: 334
Go to General Settings and there to Time Zone Settings and set it to Brussels
[2026-08-18 19:14:08]
John - SC Support - Posts: 48562
There are two time zone settings - Global and Chart Specific. If you only use a single time zone for all your charts, then set the Global Time Zone to the time zone you want and then ensure that all your charts are set to use that Global Time Zone. Refer to the following:
Time Zone Setting (Global)
Chart Settings: Time Zone (List) (Chart >> Chart Settings >> Session Times menu) (Chart)
There is no option in Sierra Chart to change how the date is formatted. It is done as "YYYY-MM-DD" everywhere in the system.
