Date/Time: Sun, 08 Nov 2026 21:26:12 +0000
Recommendations on best Windows version to run Sierra through Mac/Parallels?
View Count: 1689
| [2014-11-04 16:41:35] |
| User52989 - Posts: 42 |
Hi - Been using a Mac with Parallels running WinXP; will be upgrading to a new Mac and trying to decide between Win7, which I like, or Win 8.1. Any thoughts on which OS works better with Sierra? - thanks
| [2014-11-04 18:58:42] |
We definitely like Windows 7 better.
