Date/Time: Tue, 17 Nov 2026 20:11:06 +0000
Order Confirmation Appears Even When It Is Disabled
View Count: 302
[2026-08-17 14:24:08]
Deenius - Posts: 174
Even though I have order confirmation turned off globally, when I use the keyboard shortcut to cancel an order, a confirmation pop-up window appears.
This happens when using the “Cancel Orders for Chart” command. Please watch the video below.
https://youtu.be/EJK2VHXv7QM
When I use the “Cancel All” command instead, no confirmation appears.
[2026-08-17 20:11:44]
Sierra_Chart Engineering - Posts: 25433
Open the Trade Window for the chart you are trading from:
Basic Trading and the Trade Window: Opening Trade Window for Chart or Trade DOM
And then disable the confirmations that you want:
Basic Trading and the Trade Window: Main/C >> Menu >> Order Confirmations (chart specific)
[2026-08-17 20:43:25]
This is exactly what I do in my video. But it doesn't work for this specific command.
[2026-08-17 22:18:11]
We will make a change, to not show the confirmation prompt in this case, when the Cancel All Confirmation prompt is disabled.
Date Time Of Last Edit: 2026-08-17 22:18:20
