Date/Time: Tue, 17 Nov 2026 20:11:05 +0000
j ai effacé des chartbook!
View Count: 264
| [2026-08-16 14:33:37] |
| aversa - Posts: 1 |
bonjour, j ai effacé des données de sierra chart,et que je ne retrouve pas sur mon disque dur,est ce que vous stocké des données personnel de chaque utilisateur (chartbook etc)?? merci pour votre reponse |
| [2026-08-16 18:51:30] |
| ForgivingComputers.com - Posts: 1253 |
I deleted some data from Sierra Chart that I cannot find on my hard drive. Do you store personal data for each user (chartbooks, etc.)? Thank you for your reply. Sierra Chart saves backups of your chartbooks. Chartbooks (Workspaces): Restoring Prior State of Chartbook |
| [2026-08-17 19:41:08] |
| John - SC Support - Posts: 48563 |
Apart from what ForgivingComputers.com states, Sierra Chart does not store any information for you on our servers or in the "Cloud". All your information is stored on your local computer. You are responsible for backing up any information/data to another system if that is what you want/need to do.
