Date/Time: Tue, 17 Nov 2026 20:11:04 +0000
Statistics not showing on replay
View Count: 246
| [2026-08-15 19:16:08] |
| UserJG - Posts: 13 |
Hello, The trade activity log shows trades but no statistics and trade tab does not show any - using replay... please advise |
| [2026-08-16 19:58:30] |
| Sierra_Chart Engineering - Posts: 25433 |
If you see trades there should be trade statistics. Check this setting on the Trade Activity Log window: Trade Activity Log: Edit >> Disable Statistics, Trades, Period Tabs (Edit menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-08-16 19:58:37
