Date/Time: Tue, 17 Nov 2026 19:06:57 +0000
volume profile
View Count: 348
| [2026-08-15 10:03:59] |
| b1u3lee - Posts: 43 |
Hi Team could you point me to to the documentation where i could load additional volume profile data on my charts? Im viewing daily profile on my hourly charts currently and would like to view the composite 5 day & 30 day profile on top of it |
| [2026-08-15 10:22:36] |
* i meant 5 day and 30 day rolling volume profile*
| [2026-08-17 07:33:15] |
| Sierra_Chart Engineering - Posts: 25432 |
Follow through the example here: Volume By Price Study: 1 Hour Volume Profile At End of Chart The changes you would make to the above example are as follows: Time Period Type for 'Fixed Time': Days. Time Period Length for 'Fixed Time': 7 or 30. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-08-20 05:43:58] |
hi i have tried to re-add my 5 day rolling VP on my hourly chart. however, it is still aligned left despite changing the "allign to far right" to yes. is there some other setting i might have missed? |
| [2026-08-20 14:31:42] |
| John - SC Support - Posts: 48562 |
Do you have "Right Align Volume Bars" also set to "Yes"?
