Date/Time: Mon, 12 Oct 2026 18:40:51 +0000
Time/Date Issues
View Count: 1885
[2014-11-04 15:09:07]
OneMoreTick - Posts: 79
The dates are repeating along the bottom axis, 11/4 is there several times. I'm wondering if this has to do with daylight savings as it started just after daylight savings ended, but my timezone settings look ok and my pc clock is accurate. I use Rithmic data through Optimus.
Things I tried:
-Deleting and downloading all data several times but that didn't help. When I reload data, it keeps showing out of order timestamps, but a data delete and download doesn't fix it.
-Rebooted PC
-Restarted Sierra several times
-Used different broker data connection (AGN - but it's still Rithmic data)
http://www.sierrachart.com/image.php?l=1415112230522.png
[2014-11-04 18:53:01]
Set Chart >> Chart Settings >> Advanced Settings >> Continuous Contract to None.
After the select Edit >> Delete All Data and Download.
Let us know that solves the problem.
Date Time Of Last Edit: 2014-11-04 20:50:32
[2014-11-04 19:07:16]
This didn't fix it.
[2014-11-04 19:19:03]
Perform the procedure that we said again. And then post an image of the chart by following these instructions:
[2014-11-04 20:17:06]
http://www.sierrachart.com/image.php?l=1415132206703.png
[2014-11-04 20:49:47]
Can you tell us specifically what command you selected and on what menu , to re-download the data?
Do this again and provide a copy of the Message Log.
Provide a copy of the Message Log, by following these instructions:
http://www.sierrachart.com/index.php?l=PostingInformation.php#log
Date Time Of Last Edit: 2014-11-04 20:50:50
[2014-11-04 20:59:36]
Hmmm, I had previously created a right-click shortcut on the chart menu and added "Delete all data and download". I was using that before. This time, I used the Edit menu and it worked. So, my shortcut is not the same thing as from the edit menu I guess?
[2014-11-04 21:34:08]
We added the Delete All Data and Download to the chart shortcut menu and it did perform this operation correctly.
You can confirm that because the chart will go blank temporarily after performing the operation.
[2014-11-04 23:23:55]
I shut down Sierra and when I restarted it the problem had returned. I did the Delete All Data and Download 3 times before it went back to normal. I'm pasting my log here for your review to see if there's anything obvious that is causing this recurring issue.
Software version: 1205 | 2014-11-04 15:06:29
Usage end date: 2015-01-20 | 2014-11-04 15:06:29
Enabled for: Advanced Features. | 2014-11-04 15:06:29
Enabled for: Advanced Features 2. | 2014-11-04 15:06:29
Enabled for: Sierra Chart Historical Data Service. | 2014-11-04 15:06:29
Allow Support for Sierra Chart Data Feeds is enabled. | 2014-11-04 15:06:29
Active service: Rithmic Trading | 2014-11-04 15:06:29
Data/Trade Service Settings automatically set. | 2014-11-04 15:06:29
Time Zone: -08:00:00 (PST-08PDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2014-11-04 15:06:29
2014-11-04 15:06:29 Local computer clock time | 2014-11-04 15:06:29
2014-11-04 23:06:29 GMT time | 2014-11-04 15:06:29
2014-11-04 15:06:29 Time zone adjusted time | 2014-11-04 15:06:29
Time difference to server time: 0 seconds. | 2014-11-04 15:06:29
Program path: C:\SierraChart\ | 2014-11-04 15:06:29
Data Files path: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ | 2014-11-04 15:06:29
OS Version Number: 6.1 | 2014-11-04 15:06:29
Locale Information: C | 2014-11-04 15:06:29
Checking for new symbol settings for rim | 2014-11-04 15:06:29
HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 88.198.13.175 | 2014-11-04 15:06:29
HTTP connection to www.sierrachart.com:80 (1068) | Connected. | 2014-11-04 15:06:29
Symbol settings are up-to-date for rim | 2014-11-04 15:06:31
Files to Open on Start up | Opening file: ES - VZones.cht | 2014-11-04 15:06:32
Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2014-11-04 15:06:32
Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 0. | 2014-11-04 15:06:32
Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-11-04. | 2014-11-04 15:06:32
ESZ4-CME [CV] 5 Min #12 | Symbols used for continuous contract chart: | 2014-11-04 15:06:32
ESZ4-CME | 2014-11-04 15:06:32
ESZ4-CME [CV] 5 Min #12: Checking for volume based rollover dates. | 2014-11-04 15:06:32
Date rule based rollover from ESU2-CME to next contract occurs at 2012-09-13. | 2014-11-04 15:06:32
Date rule based rollover from ESZ2-CME to next contract occurs at 2012-12-13. | 2014-11-04 15:06:32
Date rule based rollover from ESH3-CME to next contract occurs at 2013-03-07. | 2014-11-04 15:06:32
Date rule based rollover from ESM3-CME to next contract occurs at 2013-06-13. | 2014-11-04 15:06:32
Date rule based rollover from ESU3-CME to next contract occurs at 2013-09-12. | 2014-11-04 15:06:32
Date rule based rollover from ESZ3-CME to next contract occurs at 2013-12-12. | 2014-11-04 15:06:32
Date rule based rollover from ESH4-CME to next contract occurs at 2014-03-13. | 2014-11-04 15:06:32
Date rule based rollover from ESM4-CME to next contract occurs at 2014-06-12. | 2014-11-04 15:06:32
Date rule based rollover from ESU4-CME to next contract occurs at 2014-09-11. | 2014-11-04 15:06:32
Checking Intraday data file for symbol ESU2-CME for the date range from 2012-06-07 to 2012-09-13. | 2014-11-04 15:06:32
Checking Daily data file for symbol ESU12 for the date range from 2012-06-07 to 2012-09-13. | 2014-11-04 15:06:32
Checking Intraday data file for symbol ESZ2-CME for the date range from 2012-09-13 to 2012-12-13. | 2014-11-04 15:06:32
Checking Daily data file for symbol ESZ12 for the date range from 2012-09-13 to 2012-12-13. | 2014-11-04 15:06:32
Checking Intraday data file for symbol ESH3-CME for the date range from 2012-12-13 to 2013-03-07. | 2014-11-04 15:06:32
Checking Daily data file for symbol ESH13 for the date range from 2012-12-13 to 2013-03-07. | 2014-11-04 15:06:32
Checking Intraday data file for symbol ESM3-CME for the date range from 2013-03-07 to 2013-06-13. | 2014-11-04 15:06:32
Checking Daily data file for symbol ESM13 for the date range from 2013-03-07 to 2013-06-13. | 2014-11-04 15:06:32
Checking Intraday data file for symbol ESU3-CME for the date range from 2013-06-13 to 2013-09-12. | 2014-11-04 15:06:32
Checking Daily data file for symbol ESU13 for the date range from 2013-06-13 to 2013-09-12. | 2014-11-04 15:06:32
Checking Intraday data file for symbol ESZ3-CME for the date range from 2013-09-12 to 2013-12-12. | 2014-11-04 15:06:32
Checking Daily data file for symbol ESZ13 for the date range from 2013-09-12 to 2013-12-12. | 2014-11-04 15:06:32
Checking Intraday data file for symbol ESH4-CME for the date range from 2013-12-12 to 2014-03-13. | 2014-11-04 15:06:32
Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-13. | 2014-11-04 15:06:32
Checking Intraday data file for symbol ESM4-CME for the date range from 2014-03-13 to 2014-06-12. | 2014-11-04 15:06:32
Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2014-11-04 15:06:32
Checking Intraday data file for symbol ESU4-CME for the date range from 2014-06-12 to 2014-09-11. | 2014-11-04 15:06:32
Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Min #3 | Symbols used for continuous contract chart: | 2014-11-04 15:06:32
ESU2-CME | 2014-11-04 15:06:32
ESZ2-CME | 2014-11-04 15:06:32
ESH3-CME | 2014-11-04 15:06:32
ESM3-CME | 2014-11-04 15:06:32
ESU3-CME | 2014-11-04 15:06:32
ESZ3-CME | 2014-11-04 15:06:32
ESH4-CME | 2014-11-04 15:06:32
ESM4-CME | 2014-11-04 15:06:32
ESU4-CME | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Min #3: Checking for volume based rollover dates. | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Min #3: Volume based rollover from ESU2-CME to ESZ2-CME occurs at 2012-09-14 | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Min #3: Volume based rollover from ESZ2-CME to ESH3-CME occurs at 2012-12-14 | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Min #3: Volume based rollover from ESH3-CME to ESM3-CME occurs at 2013-03-08 | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Min #3: Volume based rollover from ESM3-CME to ESU3-CME occurs at 2013-06-14 | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Min #3: Volume based rollover from ESU3-CME to ESZ3-CME occurs at 2013-09-13 | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Min #3: Volume based rollover from ESZ3-CME to ESH4-CME occurs at 2013-12-13 | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Min #3: Volume based rollover from ESH4-CME to ESM4-CME occurs at 2014-03-14 | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Min #3: Volume based rollover from ESM4-CME to ESU4-CME occurs at 2014-06-13 | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Min #3: Volume based rollover from ESU4-CME to ESZ4-CME occurs at 2014-09-12 | 2014-11-04 15:06:32
TICK-NYSE 3 Min #8 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 09:30:00. Next Bar Date Time: 2014-11-04 09:12:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\TICK-NYSE.scid | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Min #2 | Symbols used for continuous contract chart: | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Min #2: Checking for volume based rollover dates. | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Min #2: Volume based rollover from ESH4-CME to ESM4-CME occurs at 2014-03-14 | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Min #2: Volume based rollover from ESM4-CME to ESU4-CME occurs at 2014-06-13 | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Min #2: Volume based rollover from ESU4-CME to ESZ4-CME occurs at 2014-09-12 | 2014-11-04 15:06:32
Date rule based rollover from ESZ11 to next contract occurs at 2011-12-08. | 2014-11-04 15:06:32
Date rule based rollover from ESH12 to next contract occurs at 2012-03-08. | 2014-11-04 15:06:32
Date rule based rollover from ESM12 to next contract occurs at 2012-06-07. | 2014-11-04 15:06:32
Date rule based rollover from ESU12 to next contract occurs at 2012-09-13. | 2014-11-04 15:06:32
Date rule based rollover from ESZ12 to next contract occurs at 2012-12-13. | 2014-11-04 15:06:32
Date rule based rollover from ESH13 to next contract occurs at 2013-03-07. | 2014-11-04 15:06:32
Date rule based rollover from ESM13 to next contract occurs at 2013-06-13. | 2014-11-04 15:06:32
Date rule based rollover from ESU13 to next contract occurs at 2013-09-12. | 2014-11-04 15:06:32
Date rule based rollover from ESZ13 to next contract occurs at 2013-12-12. | 2014-11-04 15:06:32
Date rule based rollover from ESH14 to next contract occurs at 2014-03-13. | 2014-11-04 15:06:32
Date rule based rollover from ESM14 to next contract occurs at 2014-06-12. | 2014-11-04 15:06:32
Date rule based rollover from ESU14 to next contract occurs at 2014-09-11. | 2014-11-04 15:06:32
Date rule based rollover from ESZ14 to next contract occurs at 2014-12-11. | 2014-11-04 15:06:32
Checking Daily data file for symbol ESZ11 for the date range from 2011-09-08 to 2011-12-08. | 2014-11-04 15:06:32
Checking Daily data file for symbol ESH12 for the date range from 2011-12-08 to 2012-03-08. | 2014-11-04 15:06:32
Checking Daily data file for symbol ESM12 for the date range from 2012-03-08 to 2012-06-07. | 2014-11-04 15:06:32
ESZ14/ESZ4-CME [CV] Weekly #5 | Symbols used for continuous contract chart: | 2014-11-04 15:06:32
ESZ11 | 2014-11-04 15:06:32
ESH12 | 2014-11-04 15:06:32
ESM12 | 2014-11-04 15:06:32
ESU12 | 2014-11-04 15:06:32
ESZ12 | 2014-11-04 15:06:32
ESH13 | 2014-11-04 15:06:32
ESM13 | 2014-11-04 15:06:32
ESU13 | 2014-11-04 15:06:32
ESZ13 | 2014-11-04 15:06:32
ESH14 | 2014-11-04 15:06:32
ESM14 | 2014-11-04 15:06:32
ESU14 | 2014-11-04 15:06:32
ESZ14 | 2014-11-04 15:06:32
ESZ14/ESZ4-CME [CV] Weekly #5: Checking for volume based rollover dates. | 2014-11-04 15:06:32
ESZ14/ESZ4-CME [CV] Weekly #5: Volume based rollover from ESZ11 to ESH12 occurs at 2011-12-09 | 2014-11-04 15:06:32
ESZ14/ESZ4-CME [CV] Weekly #5: Volume based rollover from ESH12 to ESM12 occurs at 2012-03-09 | 2014-11-04 15:06:32
ESZ14/ESZ4-CME [CV] Weekly #5: Volume based rollover from ESM12 to ESU12 occurs at 2012-06-08 | 2014-11-04 15:06:32
ESZ14/ESZ4-CME [CV] Weekly #5: Volume based rollover from ESU12 to ESZ12 occurs at 2012-09-14 | 2014-11-04 15:06:32
ESZ14/ESZ4-CME [CV] Weekly #5: Volume based rollover from ESZ12 to ESH13 occurs at 2012-12-14 | 2014-11-04 15:06:32
ESZ14/ESZ4-CME [CV] Weekly #5: Volume based rollover from ESH13 to ESM13 occurs at 2013-03-08 | 2014-11-04 15:06:32
ESZ14/ESZ4-CME [CV] Weekly #5: Volume based rollover from ESM13 to ESU13 occurs at 2013-06-14 | 2014-11-04 15:06:32
TICK-NYSE 1 Min #6 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 09:30:00. Next Bar Date Time: 2014-11-04 09:13:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\TICK-NYSE.scid | 2014-11-04 15:06:32
ESZ14/ESZ4-CME [CV] Weekly #5: Volume based rollover from ESU13 to ESZ13 occurs at 2013-09-13 | 2014-11-04 15:06:32
ESZ14/ESZ4-CME [CV] Weekly #5: Volume based rollover from ESZ13 to ESH14 occurs at 2013-12-13 | 2014-11-04 15:06:32
ESZ14/ESZ4-CME [CV] Weekly #5: Volume based rollover from ESH14 to ESM14 occurs at 2014-03-14 | 2014-11-04 15:06:32
ESZ14/ESZ4-CME [CV] Weekly #5: Volume based rollover from ESM14 to ESU14 occurs at 2014-06-13 | 2014-11-04 15:06:32
ESZ14/ESZ4-CME [CV] Weekly #5: Volume based rollover from ESU14 to ESZ14 occurs at 2014-09-12 | 2014-11-04 15:06:32
Limiting the number of days back for the continuous futures chart to 4.9993155 years based on the account type. | 2014-11-04 15:06:32
Date rule based rollover from ESZ9-CME to next contract occurs at 2009-12-10. | 2014-11-04 15:06:32
Date rule based rollover from ESH0-CME to next contract occurs at 2010-03-11. | 2014-11-04 15:06:32
Date rule based rollover from ESM0-CME to next contract occurs at 2010-06-10. | 2014-11-04 15:06:32
Date rule based rollover from ESU0-CME to next contract occurs at 2010-09-09. | 2014-11-04 15:06:32
Date rule based rollover from ESZ0-CME to next contract occurs at 2010-12-09. | 2014-11-04 15:06:32
Date rule based rollover from ESH1-CME to next contract occurs at 2011-03-10. | 2014-11-04 15:06:32
Date rule based rollover from ESM1-CME to next contract occurs at 2011-06-09. | 2014-11-04 15:06:32
Date rule based rollover from ESU1-CME to next contract occurs at 2011-09-08. | 2014-11-04 15:06:32
Date rule based rollover from ESZ1-CME to next contract occurs at 2011-12-08. | 2014-11-04 15:06:32
Date rule based rollover from ESH2-CME to next contract occurs at 2012-03-08. | 2014-11-04 15:06:32
Date rule based rollover from ESM2-CME to next contract occurs at 2012-06-07. | 2014-11-04 15:06:32
Intraday data file for ESZ9-CME exists and is empty. Skipping Intraday data download. | 2014-11-04 15:06:32
Checking Daily data file for symbol ESZ09 for the date range from 2009-09-10 to 2009-12-10. | 2014-11-04 15:06:32
Intraday data file for ESH0-CME exists and is empty. Skipping Intraday data download. | 2014-11-04 15:06:32
Checking Daily data file for symbol ESH10 for the date range from 2009-12-10 to 2010-03-11. | 2014-11-04 15:06:32
Intraday data file for ESM0-CME exists and is empty. Skipping Intraday data download. | 2014-11-04 15:06:32
Checking Daily data file for symbol ESM10 for the date range from 2010-03-11 to 2010-06-10. | 2014-11-04 15:06:32
Intraday data file for ESU0-CME exists and is empty. Skipping Intraday data download. | 2014-11-04 15:06:32
Checking Daily data file for symbol ESU10 for the date range from 2010-06-10 to 2010-09-09. | 2014-11-04 15:06:32
Intraday data file for ESZ0-CME exists and is empty. Skipping Intraday data download. | 2014-11-04 15:06:32
Checking Daily data file for symbol ESZ10 for the date range from 2010-09-09 to 2010-12-09. | 2014-11-04 15:06:32
Checking Intraday data file for symbol ESH1-CME for the date range from 2010-12-09 to 2011-03-10. | 2014-11-04 15:06:32
Checking Daily data file for symbol ESH11 for the date range from 2010-12-09 to 2011-03-10. | 2014-11-04 15:06:32
Checking Intraday data file for symbol ESM1-CME for the date range from 2011-03-10 to 2011-06-09. | 2014-11-04 15:06:32
Checking Daily data file for symbol ESM11 for the date range from 2011-03-10 to 2011-06-09. | 2014-11-04 15:06:32
Checking Intraday data file for symbol ESU1-CME for the date range from 2011-06-09 to 2011-09-08. | 2014-11-04 15:06:32
Checking Daily data file for symbol ESU11 for the date range from 2011-06-09 to 2011-09-08. | 2014-11-04 15:06:32
Checking Intraday data file for symbol ESZ1-CME for the date range from 2011-09-08 to 2011-12-08. | 2014-11-04 15:06:32
Checking Intraday data file for symbol ESH2-CME for the date range from 2011-12-08 to 2012-03-08. | 2014-11-04 15:06:32
Checking Intraday data file for symbol ESM2-CME for the date range from 2012-03-08 to 2012-06-07. | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Day #9 | Symbols used for continuous contract chart: | 2014-11-04 15:06:32
ESZ9-CME | 2014-11-04 15:06:32
ESH0-CME | 2014-11-04 15:06:32
ESM0-CME | 2014-11-04 15:06:32
ESU0-CME | 2014-11-04 15:06:32
ESZ0-CME | 2014-11-04 15:06:32
ESH1-CME | 2014-11-04 15:06:32
ESM1-CME | 2014-11-04 15:06:32
ESU1-CME | 2014-11-04 15:06:32
ESZ1-CME | 2014-11-04 15:06:32
ESH2-CME | 2014-11-04 15:06:32
ESM2-CME | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Day #9: Checking for volume based rollover dates. | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESZ9-CME to ESH0-CME occurs at 2009-12-11 | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESH0-CME to ESM0-CME occurs at 2010-03-12 | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESM0-CME to ESU0-CME occurs at 2010-06-11 | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESU0-CME to ESZ0-CME occurs at 2010-09-10 | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESZ0-CME to ESH1-CME occurs at 2010-12-10 | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESH1-CME to ESM1-CME occurs at 2011-03-11 | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESM1-CME to ESU1-CME occurs at 2011-06-10 | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESU1-CME to ESZ1-CME occurs at 2011-09-09 | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESZ1-CME to ESH2-CME occurs at 2011-12-09 | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESH2-CME to ESM2-CME occurs at 2012-03-09 | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESM2-CME to ESU2-CME occurs at 2012-06-08 | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESU2-CME to ESZ2-CME occurs at 2012-09-14 | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESZ2-CME to ESH3-CME occurs at 2012-12-14 | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESH3-CME to ESM3-CME occurs at 2013-03-08 | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESM3-CME to ESU3-CME occurs at 2013-06-14 | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESU3-CME to ESZ3-CME occurs at 2013-09-13 | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESZ3-CME to ESH4-CME occurs at 2013-12-13 | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESH4-CME to ESM4-CME occurs at 2014-03-14 | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESM4-CME to ESU4-CME occurs at 2014-06-13 | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESU4-CME to ESZ4-CME occurs at 2014-09-12 | 2014-11-04 15:06:32
ESZ4-CME [CV] 10 Sec #15 | Symbols used for continuous contract chart: | 2014-11-04 15:06:32
ESZ4-CME [CV] 10 Sec #15: Checking for volume based rollover dates. | 2014-11-04 15:06:32
ESZ4-CME [CV] 10 Sec #15: Volume based rollover from ESH4-CME to ESM4-CME occurs at 2014-03-14 | 2014-11-04 15:06:32
ESZ4-CME [CV] 10 Sec #15: Volume based rollover from ESM4-CME to ESU4-CME occurs at 2014-06-13 | 2014-11-04 15:06:32
ESZ4-CME [CV] 10 Sec #15: Volume based rollover from ESU4-CME to ESZ4-CME occurs at 2014-09-12 | 2014-11-04 15:06:32
Date rule based rollover from ZBU4-CBOT to next contract occurs at 2014-08-29. | 2014-11-04 15:06:33
Date rule based rollover from ZBZ4-CBOT to next contract occurs at 2014-11-28. | 2014-11-04 15:06:33
Checking Intraday data file for symbol ZBU4-CBOT for the date range from 2014-05-30 to 2014-08-29. | 2014-11-04 15:06:33
Checking Daily data file for symbol ZBU14 for the date range from 2014-05-30 to 2014-08-29. | 2014-11-04 15:06:33
Checking Intraday data file for symbol ZBZ4-CBOT for the date range from 2014-08-29 to 0. | 2014-11-04 15:06:33
Checking Daily data file for symbol ZBZ14 for the date range from 2014-08-29 to 2014-11-04. | 2014-11-04 15:06:33
ZBZ4-CBOT [CV] 5 Min #1 | Symbols used for continuous contract chart: | 2014-11-04 15:06:33
ZBU4-CBOT | 2014-11-04 15:06:33
ZBZ4-CBOT | 2014-11-04 15:06:33
ZBZ4-CBOT [CV] 5 Min #1: Checking for volume based rollover dates. | 2014-11-04 15:06:33
ZBZ4-CBOT [CV] 5 Min #1: Volume based rollover from ZBU4-CBOT to ZBZ4-CBOT occurs at 2014-08-29 | 2014-11-04 15:06:33
Notice: The study 'Opening Range' has sc.FreeDLL set to true. Use only during development! Set to false to reduce CPU time. | 2014-11-04 15:06:33
Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2014-11-04 15:06:33
Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 0. | 2014-11-04 15:06:33
Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-11-04. | 2014-11-04 15:06:33
ESZ4-CME [CV] 2000 Volume #17 | Symbols used for continuous contract chart: | 2014-11-04 15:06:33
ESZ4-CME | 2014-11-04 15:06:33
ESZ4-CME [CV] 2000 Volume #17: Checking for volume based rollover dates. | 2014-11-04 15:06:33
Date rule based rollover from ESH4-CME to next contract occurs at 2014-03-13. | 2014-11-04 15:06:34
Date rule based rollover from ESM4-CME to next contract occurs at 2014-06-12. | 2014-11-04 15:06:34
Date rule based rollover from ESU4-CME to next contract occurs at 2014-09-11. | 2014-11-04 15:06:34
Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2014-11-04 15:06:34
Checking Intraday data file for symbol ESH4-CME for the date range from 2013-12-12 to 2014-03-13. | 2014-11-04 15:06:34
Checking Intraday data file for symbol ESM4-CME for the date range from 2014-03-13 to 2014-06-12. | 2014-11-04 15:06:34
Checking Intraday data file for symbol ESU4-CME for the date range from 2014-06-12 to 2014-09-11. | 2014-11-04 15:06:34
Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 0. | 2014-11-04 15:06:34
ESZ4-CME [C] 1 Min #20 | Symbols used for continuous contract chart: | 2014-11-04 15:06:34
ESH4-CME | 2014-11-04 15:06:34
ESM4-CME | 2014-11-04 15:06:34
ESU4-CME | 2014-11-04 15:06:34
ESZ4-CME | 2014-11-04 15:06:34
ZBZ4-CBOT [CV] 5 Min #1 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-08-10 14:55:01. Next Bar Date Time: 2014-08-08 13:55:01. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ZBZ4-CBOT.scid | 2014-11-04 15:06:34
ZBZ4-CBOT [CV] 5 Min #1 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-08-10 16:00:01. Next Bar Date Time: 2014-08-10 15:50:01. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ZBZ4-CBOT.scid | 2014-11-04 15:06:34
ZBZ4-CBOT [CV] 5 Min #1 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-08-10 20:10:01. Next Bar Date Time: 2014-08-10 20:00:01. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ZBZ4-CBOT.scid | 2014-11-04 15:06:34
ZBZ4-CBOT [CV] 5 Min #1 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-08-10 21:05:01. Next Bar Date Time: 2014-08-10 20:55:01. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ZBZ4-CBOT.scid | 2014-11-04 15:06:34
ZBZ4-CBOT [CV] 5 Min #1 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-08-10 22:35:01. Next Bar Date Time: 2014-08-10 22:25:01. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ZBZ4-CBOT.scid | 2014-11-04 15:06:34
ZBZ4-CBOT [CV] 5 Min #1 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-08-11 02:30:01. Next Bar Date Time: 2014-08-11 02:20:01. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ZBZ4-CBOT.scid | 2014-11-04 15:06:34
ZBZ4-CBOT [CV] 5 Min #1 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-08-11 14:55:01. Next Bar Date Time: 2014-08-11 13:55:01. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ZBZ4-CBOT.scid | 2014-11-04 15:06:34
ZBZ4-CBOT [CV] 5 Min #1 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-08-11 16:00:01. Next Bar Date Time: 2014-08-11 15:50:01. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ZBZ4-CBOT.scid | 2014-11-04 15:06:34
ZBZ4-CBOT [CV] 5 Min #1 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-08-11 19:00:01. Next Bar Date Time: 2014-08-11 18:45:01. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ZBZ4-CBOT.scid | 2014-11-04 15:06:34
ZBZ4-CBOT [CV] 5 Min #1 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-08-11 20:20:01. Next Bar Date Time: 2014-08-11 19:45:01. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ZBZ4-CBOT.scid | 2014-11-04 15:06:34
ZBZ4-CBOT [CV] 5 Min #1 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-08-11 20:55:01. Next Bar Date Time: 2014-08-11 20:45:01. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ZBZ4-CBOT.scid | 2014-11-04 15:06:34
ZBZ4-CBOT [CV] 5 Min #1 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-08-11 21:25:01. Next Bar Date Time: 2014-08-11 21:15:01. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ZBZ4-CBOT.scid | 2014-11-04 15:06:34
ZBZ4-CBOT [CV] 5 Min #1 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-08-12 14:55:01. Next Bar Date Time: 2014-08-12 13:55:01. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ZBZ4-CBOT.scid | 2014-11-04 15:06:34
Date rule based rollover from ESZ3-CME to next contract occurs at 2013-12-12. | 2014-11-04 15:06:34
Checking Intraday data file for symbol ESZ3-CME for the date range from 2013-09-12 to 2013-12-12. | 2014-11-04 15:06:34
Checking Daily data file for symbol ESZ13 for the date range from 2013-09-12 to 2013-12-12. | 2014-11-04 15:06:34
Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-13. | 2014-11-04 15:06:34
Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2014-11-04 15:06:34
Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2014-11-04 15:06:34
Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-11-04. | 2014-11-04 15:06:34
ESZ4-CME [CV] 30 Min #23 | Symbols used for continuous contract chart: | 2014-11-04 15:06:34
ESZ3-CME | 2014-11-04 15:06:34
ESZ4-CME [CV] 30 Min #23: Checking for volume based rollover dates. | 2014-11-04 15:06:34
ESZ4-CME [CV] 30 Min #23: Volume based rollover from ESZ3-CME to ESH4-CME occurs at 2013-12-13 | 2014-11-04 15:06:34
ESZ4-CME [CV] 30 Min #23: Volume based rollover from ESH4-CME to ESM4-CME occurs at 2014-03-14 | 2014-11-04 15:06:34
ESZ4-CME [CV] 30 Min #23: Volume based rollover from ESM4-CME to ESU4-CME occurs at 2014-06-13 | 2014-11-04 15:06:34
ESZ4-CME [CV] 30 Min #23: Volume based rollover from ESU4-CME to ESZ4-CME occurs at 2014-09-12 | 2014-11-04 15:06:34
Date rule based rollover from ESM3-CME to next contract occurs at 2013-06-13. | 2014-11-04 15:06:34
Date rule based rollover from ESU3-CME to next contract occurs at 2013-09-12. | 2014-11-04 15:06:34
Checking Intraday data file for symbol ESM3-CME for the date range from 2013-03-07 to 2013-06-13. | 2014-11-04 15:06:34
Checking Daily data file for symbol ESM13 for the date range from 2013-03-07 to 2013-06-13. | 2014-11-04 15:06:34
Checking Intraday data file for symbol ESU3-CME for the date range from 2013-06-13 to 2013-09-12. | 2014-11-04 15:06:34
Checking Daily data file for symbol ESU13 for the date range from 2013-06-13 to 2013-09-12. | 2014-11-04 15:06:34
ESZ4-CME [CV] 2.50 Range #22 | Symbols used for continuous contract chart: | 2014-11-04 15:06:34
ESM3-CME | 2014-11-04 15:06:34
ESU3-CME | 2014-11-04 15:06:34
ESZ4-CME [CV] 2.50 Range #22: Checking for volume based rollover dates. | 2014-11-04 15:06:34
ESZ4-CME [CV] 2.50 Range #22: Volume based rollover from ESM3-CME to ESU3-CME occurs at 2013-06-14 | 2014-11-04 15:06:34
ESZ4-CME [CV] 2.50 Range #22: Volume based rollover from ESU3-CME to ESZ3-CME occurs at 2013-09-13 | 2014-11-04 15:06:34
ESZ4-CME [CV] 2.50 Range #22: Volume based rollover from ESZ3-CME to ESH4-CME occurs at 2013-12-13 | 2014-11-04 15:06:34
ESZ4-CME [CV] 2.50 Range #22: Volume based rollover from ESH4-CME to ESM4-CME occurs at 2014-03-14 | 2014-11-04 15:06:34
ESZ4-CME [CV] 2.50 Range #22: Volume based rollover from ESM4-CME to ESU4-CME occurs at 2014-06-13 | 2014-11-04 15:06:34
ESZ4-CME [CV] 2.50 Range #22: Volume based rollover from ESU4-CME to ESZ4-CME occurs at 2014-09-12 | 2014-11-04 15:06:34
ZBZ4-CBOT [CV] 5 Min #1 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-08-18 14:55:01. Next Bar Date Time: 2014-08-18 13:55:01. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ZBZ4-CBOT.scid | 2014-11-04 15:06:34
ZBZ4-CBOT [CV] 5 Min #1 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-08-18 17:45:01. Next Bar Date Time: 2014-08-18 17:35:01. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ZBZ4-CBOT.scid | 2014-11-04 15:06:34
ZBZ4-CBOT [CV] 5 Min #1 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-08-18 19:45:01. Next Bar Date Time: 2014-08-18 19:35:01. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ZBZ4-CBOT.scid | 2014-11-04 15:06:34
ZBZ4-CBOT [CV] 5 Min #1 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-08-18 20:05:01. Next Bar Date Time: 2014-08-18 19:55:01. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ZBZ4-CBOT.scid | 2014-11-04 15:06:34
ZBZ4-CBOT [CV] 5 Min #1 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-08-18 20:35:01. Next Bar Date Time: 2014-08-18 20:25:01. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ZBZ4-CBOT.scid | 2014-11-04 15:06:34
ZBZ4-CBOT [CV] 5 Min #1 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-08-18 21:25:01. Next Bar Date Time: 2014-08-18 21:15:01. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ZBZ4-CBOT.scid | 2014-11-04 15:06:34
ZBZ4-CBOT [CV] 5 Min #1 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-08-18 21:35:01. Next Bar Date Time: 2014-08-18 21:25:01. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ZBZ4-CBOT.scid | 2014-11-04 15:06:34
ESZ4-CME [CV] 1 Min #4 | Symbols used for continuous contract chart: | 2014-11-04 15:06:34
ESZ4-CME [CV] 1 Min #4: Checking for volume based rollover dates. | 2014-11-04 15:06:34
Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2014-11-04 15:06:35
Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 0. | 2014-11-04 15:06:35
Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-11-04. | 2014-11-04 15:06:35
ESZ4-CME [CV] 15 Min #24 | Symbols used for continuous contract chart: | 2014-11-04 15:06:35
ESZ4-CME | 2014-11-04 15:06:35
ESZ4-CME [CV] 15 Min #24: Checking for volume based rollover dates. | 2014-11-04 15:06:35
ESZ4-CME [CV] 1.25 Range #25 | Symbols used for continuous contract chart: | 2014-11-04 15:06:35
ESZ4-CME [CV] 1.25 Range #25: Checking for volume based rollover dates. | 2014-11-04 15:06:35
Date rule based rollover from ESH4-CME to next contract occurs at 2014-03-13. | 2014-11-04 15:06:35
Date rule based rollover from ESM4-CME to next contract occurs at 2014-06-12. | 2014-11-04 15:06:35
Date rule based rollover from ESU4-CME to next contract occurs at 2014-09-11. | 2014-11-04 15:06:35
Checking Intraday data file for symbol ESH4-CME for the date range from 2013-12-12 to 2014-03-13. | 2014-11-04 15:06:35
Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-13. | 2014-11-04 15:06:35
Checking Intraday data file for symbol ESM4-CME for the date range from 2014-03-13 to 2014-06-12. | 2014-11-04 15:06:35
Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2014-11-04 15:06:35
Checking Intraday data file for symbol ESU4-CME for the date range from 2014-06-12 to 2014-09-11. | 2014-11-04 15:06:35
Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2014-11-04 15:06:35
ESZ4-CME [CV] 1.25 Range #19 | Symbols used for continuous contract chart: | 2014-11-04 15:06:35
ESH4-CME | 2014-11-04 15:06:35
ESM4-CME | 2014-11-04 15:06:35
ESU4-CME | 2014-11-04 15:06:35
ESZ4-CME [CV] 1.25 Range #19: Checking for volume based rollover dates. | 2014-11-04 15:06:35
ESZ4-CME [CV] 1.25 Range #19: Volume based rollover from ESH4-CME to ESM4-CME occurs at 2014-03-14 | 2014-11-04 15:06:35
ESZ4-CME [CV] 1.25 Range #19: Volume based rollover from ESM4-CME to ESU4-CME occurs at 2014-06-13 | 2014-11-04 15:06:35
ESZ4-CME [CV] 1.25 Range #19: Volume based rollover from ESU4-CME to ESZ4-CME occurs at 2014-09-12 | 2014-11-04 15:06:35
Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2014-11-04 15:06:36
Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 0. | 2014-11-04 15:06:36
Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-11-04. | 2014-11-04 15:06:36
ESZ4-CME [CV] 1.25 Range #13 | Symbols used for continuous contract chart: | 2014-11-04 15:06:36
ESH4-CME | 2014-11-04 15:06:36
ESM4-CME | 2014-11-04 15:06:36
ESU4-CME | 2014-11-04 15:06:36
ESZ4-CME | 2014-11-04 15:06:36
ESZ4-CME [CV] 1.25 Range #13: Checking for volume based rollover dates. | 2014-11-04 15:06:36
ESZ4-CME [CV] 1.25 Range #13: Volume based rollover from ESH4-CME to ESM4-CME occurs at 2014-03-14 | 2014-11-04 15:06:36
ESZ4-CME [CV] 1.25 Range #13: Volume based rollover from ESM4-CME to ESU4-CME occurs at 2014-06-13 | 2014-11-04 15:06:36
ESZ4-CME [CV] 1.25 Range #13: Volume based rollover from ESU4-CME to ESZ4-CME occurs at 2014-09-12 | 2014-11-04 15:06:36
Intraday data recording state for symbol NISS-SP is set to pending. | 2014-11-04 15:06:36
HD Request # 2 | Downloading Intraday chart data for NISS-SP to the file NISS-SP.scid. Service: statscalc | 2014-11-04 15:06:36
HD Request # 2 | Download start Date-Time: 2014-11-04 13:00:05.0 | 2014-11-04 15:06:36
HD Request # 2 | Using server: ds5.sierracharts.com port 10149 | 2014-11-04 15:06:36
Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-11-04 15:06:36
Intraday data recording state for symbol TICK-NYSE is set to pending. | 2014-11-04 15:06:36
HD Request # 3 | Downloading Historical Daily chart data for ESZ14. Starting date: 2014-11-03. Service: rim | 2014-11-04 15:06:36
HD Request # 3 | Requesting historical Daily data for ESZ14 starting at 2014-11-02 | 2014-11-04 15:06:36
Intraday data recording state for symbol NISS-NYSE is set to pending. | 2014-11-04 15:06:36
Intraday data recording state for symbol NISS-TF is set to pending. | 2014-11-04 15:06:36
HTTP connection to www.sierrachart.com:80 (1068) | Closed. No error. | 2014-11-04 15:06:36
HTTP connection to www.sierrachart.com:80 (1068) | Shutdown and closed. | 2014-11-04 15:06:36
Socket (1752) | Connected. | 2014-11-04 15:06:36
HD Request # 2 | Sending historical data logon request message. | 2014-11-04 15:06:36
HD Request # 3 | Receiving historical Daily data for ESZ14 starting at 2014-11-03 | 2014-11-04 15:06:37
Writing historical Daily data for ESZ14 to the file ESZ14.dly | 2014-11-04 15:06:37
HD Request # 3 | Received 2 records from 2014-11-03 00:00:00 to 2014-11-04 00:00:00 (2.0 days) and wrote 2 records for ESZ14 | 2014-11-04 15:06:37
HD Request # 3 | Daily download COMPLETE for ESZ14. Completion time: 1s. Unique request ID: 3 | 2014-11-04 15:06:37
Removed historical data download ID 3 | 2014-11-04 15:06:37
Date rule based rollover from ESZ11 to next contract occurs at 2011-12-08. | 2014-11-04 15:06:37
Date rule based rollover from ESH12 to next contract occurs at 2012-03-08. | 2014-11-04 15:06:37
Date rule based rollover from ESM12 to next contract occurs at 2012-06-07. | 2014-11-04 15:06:37
Date rule based rollover from ESU12 to next contract occurs at 2012-09-13. | 2014-11-04 15:06:37
Date rule based rollover from ESZ12 to next contract occurs at 2012-12-13. | 2014-11-04 15:06:37
Date rule based rollover from ESH13 to next contract occurs at 2013-03-07. | 2014-11-04 15:06:37
Date rule based rollover from ESM13 to next contract occurs at 2013-06-13. | 2014-11-04 15:06:37
Date rule based rollover from ESU13 to next contract occurs at 2013-09-12. | 2014-11-04 15:06:37
Date rule based rollover from ESZ13 to next contract occurs at 2013-12-12. | 2014-11-04 15:06:37
Date rule based rollover from ESH14 to next contract occurs at 2014-03-13. | 2014-11-04 15:06:37
Date rule based rollover from ESM14 to next contract occurs at 2014-06-12. | 2014-11-04 15:06:37
Date rule based rollover from ESU14 to next contract occurs at 2014-09-11. | 2014-11-04 15:06:37
Date rule based rollover from ESZ14 to next contract occurs at 2014-12-11. | 2014-11-04 15:06:37
Checking Daily data file for symbol ESZ11 for the date range from 2011-09-08 to 2011-12-08. | 2014-11-04 15:06:37
Checking Daily data file for symbol ESH12 for the date range from 2011-12-08 to 2012-03-08. | 2014-11-04 15:06:37
Checking Daily data file for symbol ESM12 for the date range from 2012-03-08 to 2012-06-07. | 2014-11-04 15:06:37
Checking Daily data file for symbol ESU12 for the date range from 2012-06-07 to 2012-09-13. | 2014-11-04 15:06:37
Checking Daily data file for symbol ESZ12 for the date range from 2012-09-13 to 2012-12-13. | 2014-11-04 15:06:37
Checking Daily data file for symbol ESH13 for the date range from 2012-12-13 to 2013-03-07. | 2014-11-04 15:06:37
Checking Daily data file for symbol ESM13 for the date range from 2013-03-07 to 2013-06-13. | 2014-11-04 15:06:37
Checking Daily data file for symbol ESU13 for the date range from 2013-06-13 to 2013-09-12. | 2014-11-04 15:06:37
Checking Daily data file for symbol ESZ13 for the date range from 2013-09-12 to 2013-12-12. | 2014-11-04 15:06:37
Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-13. | 2014-11-04 15:06:37
Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2014-11-04 15:06:37
Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2014-11-04 15:06:37
Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-11-04. | 2014-11-04 15:06:37
ESZ14/ESZ4-CME [CV] Weekly #5 | Symbols used for continuous contract chart: | 2014-11-04 15:06:37
ESZ11 | 2014-11-04 15:06:37
ESH12 | 2014-11-04 15:06:37
ESM12 | 2014-11-04 15:06:37
ESU12 | 2014-11-04 15:06:37
ESZ12 | 2014-11-04 15:06:37
ESH13 | 2014-11-04 15:06:37
ESM13 | 2014-11-04 15:06:37
ESU13 | 2014-11-04 15:06:37
ESZ13 | 2014-11-04 15:06:37
ESH14 | 2014-11-04 15:06:37
ESM14 | 2014-11-04 15:06:37
ESU14 | 2014-11-04 15:06:37
ESZ14/ESZ4-CME [CV] Weekly #5 | Waiting for historical downloads to complete with the IDs: 3, | 2014-11-04 15:06:37
Rithmic Trading | Port for executable: 55495 | 2014-11-04 15:06:38
Listening socket (1800), port 55495 | Closed. | 2014-11-04 15:06:38
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-11-04 15:06:38
ESZ14/ESZ4-CME [CV] Weekly #5: Download is complete for all contract months in chart. Proceeding with data load. | 2014-11-04 15:06:38
ESZ14/ESZ4-CME [CV] Weekly #5: Checking for volume based rollover dates. | 2014-11-04 15:06:38
ESZ14/ESZ4-CME [CV] Weekly #5: Volume based rollover from ESZ11 to ESH12 occurs at 2011-12-09 | 2014-11-04 15:06:38
ESZ14/ESZ4-CME [CV] Weekly #5: Volume based rollover from ESH12 to ESM12 occurs at 2012-03-09 | 2014-11-04 15:06:38
ESZ14/ESZ4-CME [CV] Weekly #5: Volume based rollover from ESM12 to ESU12 occurs at 2012-06-08 | 2014-11-04 15:06:38
ESZ14/ESZ4-CME [CV] Weekly #5: Volume based rollover from ESU12 to ESZ12 occurs at 2012-09-14 | 2014-11-04 15:06:38
ESZ14/ESZ4-CME [CV] Weekly #5: Volume based rollover from ESZ12 to ESH13 occurs at 2012-12-14 | 2014-11-04 15:06:38
ESZ14/ESZ4-CME [CV] Weekly #5: Volume based rollover from ESH13 to ESM13 occurs at 2013-03-08 | 2014-11-04 15:06:38
ESZ14/ESZ4-CME [CV] Weekly #5: Volume based rollover from ESM13 to ESU13 occurs at 2013-06-14 | 2014-11-04 15:06:38
ESZ14/ESZ4-CME [CV] Weekly #5: Volume based rollover from ESU13 to ESZ13 occurs at 2013-09-13 | 2014-11-04 15:06:38
ESZ14/ESZ4-CME [CV] Weekly #5: Volume based rollover from ESZ13 to ESH14 occurs at 2013-12-13 | 2014-11-04 15:06:38
ESZ14/ESZ4-CME [CV] Weekly #5: Volume based rollover from ESH14 to ESM14 occurs at 2014-03-14 | 2014-11-04 15:06:38
ESZ14/ESZ4-CME [CV] Weekly #5: Volume based rollover from ESM14 to ESU14 occurs at 2014-06-13 | 2014-11-04 15:06:38
ESZ14/ESZ4-CME [CV] Weekly #5: Volume based rollover from ESU14 to ESZ14 occurs at 2014-09-12 | 2014-11-04 15:06:38
HD Request # 2 | Requesting Intraday data. Start Date-Time: 2014-11-04 13:00:05. Record interval: 0. Symbol: NISS-SP | 2014-11-04 15:06:38
HD Request # 2 | Decompressing data. | 2014-11-04 15:06:39
HD Request # 2 | Receiving Intraday data for NISS-SP starting at 2014-11-04 13:00:05 | 2014-11-04 15:06:39
HD Request # 2 | Timestamp of first Intraday data file record written: 2014-11-04 13:00:06 | 2014-11-04 15:06:39
Rithmic Trading | Connecting to the server 127.0.0.1. Port 55495 | 2014-11-04 15:06:40
Socket (1808) | Connected. | 2014-11-04 15:06:40
Rithmic Trading | Connected to server. | 2014-11-04 15:06:40
Rithmic Trading | Sending logon request message. | 2014-11-04 15:06:40
Rithmic Trading | Starting the connection process to data and trading service. | 2014-11-04 15:06:40
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2014-11-04 15:06:40
Rithmic Trading | Connecting to Rithmic 01 US server. | 2014-11-04 15:06:40
Socket (1752) | Shutdown and closed. | 2014-11-04 15:06:40
HD Request # 2 | Historical data for NISS-SP is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2014-11-04 15:06:40
The network socket for historical data has been closed. | 2014-11-04 15:06:40
HD Request # 2 | Received 5957 records from 2014-11-04 13:00:05 to 2014-11-04 15:06:33 (2.1 hours) and wrote 5956 records for NISS-SP | 2014-11-04 15:06:40
HD Request # 2 | Intraday download COMPLETE for NISS-SP. Completion time: 4s. Unique request ID: 1 | 2014-11-04 15:06:40
Removed historical data download ID 1 | 2014-11-04 15:06:40
HD Request # 4 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc | 2014-11-04 15:06:40
HD Request # 4 | Download start Date-Time: 2014-11-04 13:00:05.0 | 2014-11-04 15:06:40
HD Request # 4 | Using server: ds3.sierracharts.com port 10149 | 2014-11-04 15:06:40
Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-11-04 15:06:40
Chart #18 has tagged chart #4 for full recalculation. Chartbook: ES - VZones.cht | 2014-11-04 15:06:40
Chart #10 has tagged chart #12 for full recalculation. Chartbook: ES - VZones.cht | 2014-11-04 15:06:40
Chart #12 is performing a full recalculation because it has been tagged. Chartbook: ES - VZones.cht | 2014-11-04 15:06:40
Chart #4 is performing a full recalculation because it has been tagged. Chartbook: ES - VZones.cht | 2014-11-04 15:06:41
Socket (1760) | Connected. | 2014-11-04 15:06:41
HD Request # 4 | Sending historical data logon request message. | 2014-11-04 15:06:41
HD Request # 4 | Requesting Intraday data. Start Date-Time: 2014-11-04 13:00:05. Record interval: 0. Symbol: TICK-NYSE | 2014-11-04 15:06:42
HD Request # 4 | Decompressing data. | 2014-11-04 15:06:43
HD Request # 4 | Receiving Intraday data for TICK-NYSE starting at 2014-11-04 13:00:05 | 2014-11-04 15:06:43
HD Request # 4 | Timestamp of first Intraday data file record written: 2014-11-04 13:00:06 | 2014-11-04 15:06:43
Socket (1760) | Shutdown and closed. | 2014-11-04 15:06:45
HD Request # 4 | Historical data for TICK-NYSE is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2014-11-04 15:06:45
The network socket for historical data has been closed. | 2014-11-04 15:06:45
HD Request # 4 | Received 5959 records from 2014-11-04 13:00:05 to 2014-11-04 15:06:40 (2.1 hours) and wrote 5958 records for TICK-NYSE | 2014-11-04 15:06:45
HD Request # 4 | Intraday download COMPLETE for TICK-NYSE. Completion time: 5s. Unique request ID: 2 | 2014-11-04 15:06:45
Removed historical data download ID 2 | 2014-11-04 15:06:45
HD Request # 5 | Downloading Intraday chart data for NISS-NYSE to the file NISS-NYSE.scid. Service: statscalc | 2014-11-04 15:06:45
HD Request # 5 | Download start Date-Time: 2014-11-04 13:00:05.0 | 2014-11-04 15:06:45
HD Request # 5 | Using server: ds4.sierracharts.com port 10149 | 2014-11-04 15:06:45
Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-11-04 15:06:45
Chart #8 has tagged chart #12 for full recalculation. Chartbook: ES - VZones.cht | 2014-11-04 15:06:46
Chart #6 has tagged chart #4 for full recalculation. Chartbook: ES - VZones.cht | 2014-11-04 15:06:46
Chart #12 is performing a full recalculation because it has been tagged. Chartbook: ES - VZones.cht | 2014-11-04 15:06:46
Chart #4 is performing a full recalculation because it has been tagged. Chartbook: ES - VZones.cht | 2014-11-04 15:06:46
Socket (1076) | Connected. | 2014-11-04 15:06:46
HD Request # 5 | Sending historical data logon request message. | 2014-11-04 15:06:46
HD Request # 5 | Requesting Intraday data. Start Date-Time: 2014-11-04 13:00:05. Record interval: 0. Symbol: NISS-NYSE | 2014-11-04 15:06:47
HD Request # 5 | Decompressing data. | 2014-11-04 15:06:48
HD Request # 5 | Receiving Intraday data for NISS-NYSE starting at 2014-11-04 13:00:05 | 2014-11-04 15:06:48
HD Request # 5 | Timestamp of first Intraday data file record written: 2014-11-04 13:00:06 | 2014-11-04 15:06:48
Rithmic Trading | Server Alert: Market Data Connection Opened | 2014-11-04 15:06:49
Socket (1076) | Shutdown and closed. | 2014-11-04 15:06:49
The network socket for historical data has been closed. | 2014-11-04 15:06:49
HD Request # 5 | Historical data for NISS-NYSE is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2014-11-04 15:06:49
HD Request # 5 | Received 5961 records from 2014-11-04 13:00:05 to 2014-11-04 15:06:46 (2.1 hours) and wrote 5960 records for NISS-NYSE | 2014-11-04 15:06:49
HD Request # 5 | Intraday download COMPLETE for NISS-NYSE. Completion time: 4s. Unique request ID: 4 | 2014-11-04 15:06:49
Removed historical data download ID 4 | 2014-11-04 15:06:49
HD Request # 6 | Downloading Intraday chart data for NISS-TF to the file NISS-TF.scid. Service: statscalc | 2014-11-04 15:06:49
HD Request # 6 | Download start Date-Time: 2014-11-04 13:00:05.0 | 2014-11-04 15:06:49
HD Request # 6 | Using server: ds5.sierracharts.com port 10149 | 2014-11-04 15:06:49
Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-11-04 15:06:49
Rithmic Trading | Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2014-11-04 15:06:49
Socket (1688) | Connected. | 2014-11-04 15:06:49
HD Request # 6 | Sending historical data logon request message. | 2014-11-04 15:06:49
HD Request # 6 | Requesting Intraday data. Start Date-Time: 2014-11-04 13:00:05. Record interval: 0. Symbol: NISS-TF | 2014-11-04 15:06:49
HD Request # 6 | Decompressing data. | 2014-11-04 15:06:50
HD Request # 6 | Receiving Intraday data for NISS-TF starting at 2014-11-04 13:00:05 | 2014-11-04 15:06:50
HD Request # 6 | Timestamp of first Intraday data file record written: 2014-11-04 13:00:06 | 2014-11-04 15:06:50
Rithmic Trading | Server Alert: Trading System Connection Opened | 2014-11-04 15:06:50
Socket (1688) | Shutdown and closed. | 2014-11-04 15:06:50
HD Request # 6 | Historical data for NISS-TF is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2014-11-04 15:06:50
The network socket for historical data has been closed. | 2014-11-04 15:06:50
HD Request # 6 | Received 5962 records from 2014-11-04 13:00:05 to 2014-11-04 15:06:49 (2.1 hours) and wrote 5961 records for NISS-TF | 2014-11-04 15:06:50
HD Request # 6 | Intraday download COMPLETE for NISS-TF. Completion time: 0s. Unique request ID: 5 | 2014-11-04 15:06:50
Removed historical data download ID 5 | 2014-11-04 15:06:50
Rithmic Trading | Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2014-11-04 15:06:50
Rithmic Trading | subscribeTradeRoute error. Error code: API_ALREADY_EXISTS | 2014-11-04 15:06:50
Rithmic Trading | Server Alert: PnL Connection Opened | 2014-11-04 15:06:50
Rithmic Trading | Server Alert: PnL Connection Login Complete. Result text: "ok" | 2014-11-04 15:06:50
Rithmic Trading | Server Alert: Intraday History Connection Opened | 2014-11-04 15:06:51
Rithmic Trading | Server Alert: Intraday History Connection Login Complete. Result text: "ok" | 2014-11-04 15:06:51
Rithmic Trading | Server Info - Server Name: SC DTC Bridge. | 2014-11-04 15:06:52
Rithmic Trading | Server protocol version: 4. Client protocol version: 4. There is a protocol match. | 2014-11-04 15:06:52
Rithmic Trading | Successfully connected. IB='OptimusFutures'. | 2014-11-04 15:06:52
Rithmic Trading | Trading is supported. | 2014-11-04 15:06:52
Rithmic Trading | Order cancel and replace is supported. | 2014-11-04 15:06:52
Rithmic Trading | OCO Orders supported. | 2014-11-04 15:06:52
Rithmic Trading | Starting real-time market data updates for: ESZ4-CME. ID: 1 | 2014-11-04 15:06:52
Intraday data recording state for symbol ESZ4-CME is set to pending. | 2014-11-04 15:06:52
HD Request # 7 | Downloading Intraday chart data for ESZ4-CME to the file ESZ4-CME.scid. Service: rim | 2014-11-04 15:06:52
HD Request # 7 | Download start Date-Time: 2014-11-04 13:00:05.0 | 2014-11-04 15:06:52
HD Request # 7 | Using server: ds3.sierracharts.com port 10149 | 2014-11-04 15:06:52
Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-11-04 15:06:52
SC Market Stats | Starting real-time market data updates for: NISS-NYSE. ID: 2 | 2014-11-04 15:06:52
SC Market Stats | Connecting to the server ds4.sierracharts.com. Port 443 | 2014-11-04 15:06:52
Intraday data recording state for symbol NISS-NYSE is set to pending. | 2014-11-04 15:06:52
SC Market Stats | Starting real-time market data updates for: NISS-TF. ID: 3 | 2014-11-04 15:06:52
Intraday data recording state for symbol NISS-TF is set to pending. | 2014-11-04 15:06:52
Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-11-04 15:06:52
Socket (1652) | Connected. | 2014-11-04 15:06:52
SC Market Stats | Connected to server. | 2014-11-04 15:06:52
SC Market Stats | Sending logon request message. | 2014-11-04 15:06:52
SC Market Stats | Starting real-time market data updates for: NISS-SP. ID: 4 | 2014-11-04 15:06:52
Intraday data recording state for symbol NISS-SP is set to pending. | 2014-11-04 15:06:52
Socket (1688) | Connected. | 2014-11-04 15:06:52
HD Request # 7 | Sending historical data logon request message. | 2014-11-04 15:06:52
HD Request # 7 | Requesting Intraday data. Start Date-Time: 2014-11-04 13:00:05. Record interval: 0. Symbol: ESZ4-CME | 2014-11-04 15:06:52
SC Market Stats | Starting real-time market data updates for: TICK-NYSE. ID: 5 | 2014-11-04 15:06:52
Intraday data recording state for symbol TICK-NYSE is set to pending. | 2014-11-04 15:06:52
HD Request # 7 | Decompressing data. | 2014-11-04 15:06:52
HD Request # 7 | Receiving Intraday data for ESZ4-CME starting at 2014-11-04 13:00:05 | 2014-11-04 15:06:52
Rithmic Trading | Starting real-time market data updates for: ZBZ4-CBOT. ID: 6 | 2014-11-04 15:06:52
Intraday data recording state for symbol ZBZ4-CBOT is set to pending. | 2014-11-04 15:06:52
HD Request # 7 | Timestamp of first Intraday data file record written: 2014-11-04 13:00:05 | 2014-11-04 15:06:52
Socket (1688) | Shutdown and closed. | 2014-11-04 15:06:53
The network socket for historical data has been closed. | 2014-11-04 15:06:53
HD Request # 7 | Received 11179 records from 2014-11-04 13:00:05 to 2014-11-04 15:06:40 (2.1 hours) and wrote 11146 records for ESZ4-CME | 2014-11-04 15:06:53
HD Request # 7 | Intraday download COMPLETE for ESZ4-CME. Completion time: 1s. Unique request ID: 6 | 2014-11-04 15:06:53
Removed historical data download ID 6 | 2014-11-04 15:06:53
Real-time Intraday chart data file updates started for ESZ4-CME | 2014-11-04 15:06:53
HD Request # 8 | Downloading Intraday chart data for NISS-NYSE to the file NISS-NYSE.scid. Service: statscalc | 2014-11-04 15:06:53
HD Request # 8 | Download start Date-Time: 2014-11-04 15:06:46.0 | 2014-11-04 15:06:53
HD Request # 8 | Using server: ds5.sierracharts.com port 10149 | 2014-11-04 15:06:53
Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-11-04 15:06:53
Socket (1648) | Connected. | 2014-11-04 15:06:53
HD Request # 8 | Sending historical data logon request message. | 2014-11-04 15:06:53
SC Market Stats | Server Info - Server Name: . | 2014-11-04 15:06:53
SC Market Stats | Server protocol version: 4. Client protocol version: 4. There is a protocol match. | 2014-11-04 15:06:53
SC Market Stats | Successfully connected. | 2014-11-04 15:06:53
SC Market Stats | Restarting real-time data updates for symbol: NISS-NYSE | 2014-11-04 15:06:53
SC Market Stats | Restarting real-time data updates for symbol: NISS-SP | 2014-11-04 15:06:53
SC Market Stats | Restarting real-time data updates for symbol: NISS-TF | 2014-11-04 15:06:53
SC Market Stats | Restarting real-time data updates for symbol: TICK-NYSE | 2014-11-04 15:06:53
HD Request # 8 | Requesting Intraday data. Start Date-Time: 2014-11-04 15:06:46. Record interval: 0. Symbol: NISS-NYSE | 2014-11-04 15:06:53
HD Request # 8 | Decompressing data. | 2014-11-04 15:06:53
HD Request # 8 | Receiving Intraday data for NISS-NYSE starting at 2014-11-04 15:06:46 | 2014-11-04 15:06:53
HD Request # 8 | Timestamp of first Intraday data file record written: 2014-11-04 15:06:49 | 2014-11-04 15:06:53
Socket (1648) | Shutdown and closed. | 2014-11-04 15:06:53
HD Request # 8 | Received 3 records from 2014-11-04 15:06:46 to 2014-11-04 15:06:52 (6.0 seconds) and wrote 2 records for NISS-NYSE | 2014-11-04 15:06:53
HD Request # 8 | Intraday download COMPLETE for NISS-NYSE. Completion time: 0s. Unique request ID: 7 | 2014-11-04 15:06:53
Removed historical data download ID 7 | 2014-11-04 15:06:53
Real-time Intraday chart data file updates started for NISS-NYSE | 2014-11-04 15:06:53
HD Request # 9 | Downloading Intraday chart data for NISS-TF to the file NISS-TF.scid. Service: statscalc | 2014-11-04 15:06:53
HD Request # 9 | Download start Date-Time: 2014-11-04 15:06:49.0 | 2014-11-04 15:06:53
HD Request # 9 | Using server: ds3.sierracharts.com port 10149 | 2014-11-04 15:06:53
Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-11-04 15:06:53
Socket (1740) | Connected. | 2014-11-04 15:06:53
HD Request # 9 | Sending historical data logon request message. | 2014-11-04 15:06:53
HD Request # 9 | Requesting Intraday data. Start Date-Time: 2014-11-04 15:06:49. Record interval: 0. Symbol: NISS-TF | 2014-11-04 15:06:53
HD Request # 9 | Decompressing data. | 2014-11-04 15:06:53
HD Request # 9 | Receiving Intraday data for NISS-TF starting at 2014-11-04 15:06:49 | 2014-11-04 15:06:53
HD Request # 9 | Timestamp of first Intraday data file record written: 2014-11-04 15:06:52 | 2014-11-04 15:06:53
Socket (1740) | Shutdown and closed. | 2014-11-04 15:06:53
HD Request # 9 | Received 2 records from 2014-11-04 15:06:49 to 2014-11-04 15:06:52 (3.0 seconds) and wrote 1 record for NISS-TF | 2014-11-04 15:06:53
HD Request # 9 | Intraday download COMPLETE for NISS-TF. Completion time: 0s. Unique request ID: 8 | 2014-11-04 15:06:53
Removed historical data download ID 8 | 2014-11-04 15:06:53
Real-time Intraday chart data file updates started for NISS-TF | 2014-11-04 15:06:53
HD Request # 10 | Downloading Intraday chart data for NISS-SP to the file NISS-SP.scid. Service: statscalc | 2014-11-04 15:06:53
HD Request # 10 | Download start Date-Time: 2014-11-04 15:06:33.0 | 2014-11-04 15:06:53
HD Request # 10 | Using server: ds4.sierracharts.com port 10149 | 2014-11-04 15:06:53
Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-11-04 15:06:53
Socket (1632) | Connected. | 2014-11-04 15:06:53
HD Request # 10 | Sending historical data logon request message. | 2014-11-04 15:06:53
HD Request # 10 | Requesting Intraday data. Start Date-Time: 2014-11-04 15:06:33. Record interval: 0. Symbol: NISS-SP | 2014-11-04 15:06:53
HD Request # 10 | Decompressing data. | 2014-11-04 15:06:53
HD Request # 10 | Receiving Intraday data for NISS-SP starting at 2014-11-04 15:06:33 | 2014-11-04 15:06:53
HD Request # 10 | Timestamp of first Intraday data file record written: 2014-11-04 15:06:39 | 2014-11-04 15:06:53
Socket (1632) | Shutdown and closed. | 2014-11-04 15:06:53
HD Request # 10 | Received 7 records from 2014-11-04 15:06:33 to 2014-11-04 15:06:52 (19.0 seconds) and wrote 6 records for NISS-SP | 2014-11-04 15:06:53
HD Request # 10 | Intraday download COMPLETE for NISS-SP. Completion time: 0s. Unique request ID: 9 | 2014-11-04 15:06:53
Removed historical data download ID 9 | 2014-11-04 15:06:53
Real-time Intraday chart data file updates started for NISS-SP | 2014-11-04 15:06:53
HD Request # 11 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc | 2014-11-04 15:06:53
HD Request # 11 | Download start Date-Time: 2014-11-04 15:06:40.0 | 2014-11-04 15:06:53
HD Request # 11 | Using server: ds5.sierracharts.com port 10149 | 2014-11-04 15:06:53
Socket (1640) | Connected. | 2014-11-04 15:06:54
HD Request # 11 | Sending historical data logon request message. | 2014-11-04 15:06:54
Chart #18 has tagged chart #4 for full recalculation. Chartbook: ES - VZones.cht | 2014-11-04 15:06:54
HD Request # 11 | Requesting Intraday data. Start Date-Time: 2014-11-04 15:06:40. Record interval: 0. Symbol: TICK-NYSE | 2014-11-04 15:06:54
HD Request # 11 | Decompressing data. | 2014-11-04 15:06:54
HD Request # 11 | Receiving Intraday data for TICK-NYSE starting at 2014-11-04 15:06:40 | 2014-11-04 15:06:54
HD Request # 11 | Timestamp of first Intraday data file record written: 2014-11-04 15:06:43 | 2014-11-04 15:06:54
Socket (1640) | Shutdown and closed. | 2014-11-04 15:06:54
The network socket for historical data has been closed. | 2014-11-04 15:06:54
HD Request # 11 | Received 5 records from 2014-11-04 15:06:40 to 2014-11-04 15:06:52 (12.0 seconds) and wrote 4 records for TICK-NYSE | 2014-11-04 15:06:54
HD Request # 11 | Intraday download COMPLETE for TICK-NYSE. Completion time: 1s. Unique request ID: 10 | 2014-11-04 15:06:54
Removed historical data download ID 10 | 2014-11-04 15:06:54
Real-time Intraday chart data file updates started for TICK-NYSE | 2014-11-04 15:06:54
HD Request # 12 | Downloading Intraday chart data for ZBZ4-CBOT to the file ZBZ4-CBOT.scid. Service: rim | 2014-11-04 15:06:54
HD Request # 12 | Download start Date-Time: 2014-11-04 13:00:05.0 | 2014-11-04 15:06:54
HD Request # 12 | Using server: ds3.sierracharts.com port 10149 | 2014-11-04 15:06:54
Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-11-04 15:06:54
Chart #10 has tagged chart #12 for full recalculation. Chartbook: ES - VZones.cht | 2014-11-04 15:06:54
Chart #8 has tagged chart #12 for full recalculation. Chartbook: ES - VZones.cht | 2014-11-04 15:06:54
Chart #6 has tagged chart #4 for full recalculation. Chartbook: ES - VZones.cht | 2014-11-04 15:06:54
Chart #12 is performing a full recalculation because it has been tagged. Chartbook: ES - VZones.cht | 2014-11-04 15:06:54
Socket (1076) | Connected. | 2014-11-04 15:06:54
HD Request # 12 | Sending historical data logon request message. | 2014-11-04 15:06:54
HD Request # 12 | Requesting Intraday data. Start Date-Time: 2014-11-04 13:00:05. Record interval: 0. Symbol: ZBZ4-CBOT | 2014-11-04 15:06:54
HD Request # 12 | Decompressing data. | 2014-11-04 15:06:54
HD Request # 12 | Receiving Intraday data for ZBZ4-CBOT starting at 2014-11-04 13:00:05 | 2014-11-04 15:06:54
HD Request # 12 | Timestamp of first Intraday data file record written: 2014-11-04 13:00:05 | 2014-11-04 15:06:54
Chart #4 is performing a full recalculation because it has been tagged. Chartbook: ES - VZones.cht | 2014-11-04 15:06:54
Socket (1076) | Shutdown and closed. | 2014-11-04 15:06:54
HD Request # 12 | Received 1199 records from 2014-11-04 13:00:05 to 2014-11-04 15:06:14 (2.1 hours) and wrote 1195 records for ZBZ4-CBOT | 2014-11-04 15:06:54
HD Request # 12 | Intraday download COMPLETE for ZBZ4-CBOT. Completion time: 0s. Unique request ID: 11 | 2014-11-04 15:06:54
Removed historical data download ID 11 | 2014-11-04 15:06:54
Real-time Intraday chart data file updates started for ZBZ4-CBOT | 2014-11-04 15:06:54
Rithmic Trading | Requesting Trade Positions data. | 2014-11-04 15:06:57
Intraday data recording state for symbol ESZ4-CME is set to pending. | 2014-11-04 15:08:40
HD Request # 13 | Downloading Intraday chart data for ESZ4-CME to the file ESZ4-CME.scid. Service: rim | 2014-11-04 15:08:40
HD Request # 13 | Download start Date-Time: 2014-09-08 17:00:00.0 | 2014-11-04 15:08:40
HD Request # 13 | Using server: ds4.sierracharts.com port 10149 | 2014-11-04 15:08:40
Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-11-04 15:08:40
Socket (1632) | Connected. | 2014-11-04 15:08:40
HD Request # 13 | Sending historical data logon request message. | 2014-11-04 15:08:40
HD Request # 13 | Requesting Intraday data. Start Date-Time: 2014-09-08 17:00:00. Record interval: 0. Symbol: ESZ4-CME | 2014-11-04 15:08:40
HD Request # 13 | Decompressing data. | 2014-11-04 15:08:40
HD Request # 13 | Receiving Intraday data for ESZ4-CME starting at 2014-09-08 17:03:46 | 2014-11-04 15:08:40
HD Request # 13 | Timestamp of first Intraday data file record written: 2014-09-08 17:03:46 | 2014-11-04 15:08:40
ESZ4-CME [CV] 1.25 Range #19 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 15:00:12. Next Bar Date Time: 2014-11-04 06:30:56. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-04 15:10:01
ESZ4-CME [CV] 30 Min #23 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 15:00:00. Next Bar Date Time: 2014-11-04 06:30:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-04 15:10:01
ESZ4-CME [CV] 1 Min #4 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 13:14:00. Next Bar Date Time: 2014-11-04 06:30:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-04 15:10:01
ESZ4-CME [CV] 15 Min #24 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 15:00:00. Next Bar Date Time: 2014-11-04 06:30:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-04 15:10:01
ESZ4-CME [CV] 5 Min #12 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 13:10:00. Next Bar Date Time: 2014-11-04 06:30:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-04 15:10:01
ESZ4-CME [CV] 1 Min #3 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 15:08:00. Next Bar Date Time: 2014-11-04 06:30:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-04 15:10:01
ESZ4-CME [CV] 10 Sec #15 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 15:08:20. Next Bar Date Time: 2014-11-04 06:30:50. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-04 15:10:01
ESZ4-CME [CV] 1.25 Range #13 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 15:00:12. Next Bar Date Time: 2014-11-04 06:30:56. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-04 15:10:01
ESZ4-CME [CV] 1.25 Range #25 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 15:00:12. Next Bar Date Time: 2014-11-04 06:30:56. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-04 15:10:01
ESZ4-CME 15 Min #11 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 15:00:00. Next Bar Date Time: 2014-11-04 06:30:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-04 15:10:01
Socket (1632) | Shutdown and closed. | 2014-11-04 15:10:02
The network socket for historical data has been closed. | 2014-11-04 15:10:02
HD Request # 13 | Received 23226851 records from 2014-09-08 17:03:46 to 2014-11-04 15:09:52 (57.0 days) and wrote 23226851 records for ESZ4-CME | 2014-11-04 15:10:02
HD Request # 13 | Intraday download COMPLETE for ESZ4-CME. Completion time: 1m 22s. Unique request ID: 12 | 2014-11-04 15:10:02
Removed historical data download ID 12 | 2014-11-04 15:10:02
Real-time Intraday chart data file updates started for ESZ4-CME | 2014-11-04 15:10:02
ESZ4-CME [CV] 1 Min #2 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 15:08:00. Next Bar Date Time: 2014-11-04 06:30:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-04 15:10:02
ESZ4-CME [C] 1 Min #20 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 15:08:00. Next Bar Date Time: 2014-11-04 06:30:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-04 15:10:02
ESZ4-CME [CV] 2.50 Range #22 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 15:00:14. Next Bar Date Time: 2014-11-04 06:30:56. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-04 15:10:02
Intraday data recording state for symbol ESZ4-CME is set to pending. | 2014-11-04 15:12:25
Reloading all charts with filename: ESZ4-CME.scid | 2014-11-04 15:12:25
Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2014-11-04 15:12:25
Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 0. | 2014-11-04 15:12:25
Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-11-04. | 2014-11-04 15:12:25
ESZ4-CME [CV] 5 Min #12 | Symbols used for continuous contract chart: | 2014-11-04 15:12:25
ESZ4-CME | 2014-11-04 15:12:25
ESZ4-CME [CV] 5 Min #12: Checking for volume based rollover dates. | 2014-11-04 15:12:25
Date rule based rollover from ESU2-CME to next contract occurs at 2012-09-13. | 2014-11-04 15:12:25
Date rule based rollover from ESZ2-CME to next contract occurs at 2012-12-13. | 2014-11-04 15:12:25
Date rule based rollover from ESH3-CME to next contract occurs at 2013-03-07. | 2014-11-04 15:12:25
Date rule based rollover from ESM3-CME to next contract occurs at 2013-06-13. | 2014-11-04 15:12:25
Date rule based rollover from ESU3-CME to next contract occurs at 2013-09-12. | 2014-11-04 15:12:25
Date rule based rollover from ESZ3-CME to next contract occurs at 2013-12-12. | 2014-11-04 15:12:25
Date rule based rollover from ESH4-CME to next contract occurs at 2014-03-13. | 2014-11-04 15:12:25
Date rule based rollover from ESM4-CME to next contract occurs at 2014-06-12. | 2014-11-04 15:12:25
Date rule based rollover from ESU4-CME to next contract occurs at 2014-09-11. | 2014-11-04 15:12:25
Checking Intraday data file for symbol ESU2-CME for the date range from 2012-06-07 to 2012-09-13. | 2014-11-04 15:12:25
Checking Daily data file for symbol ESU12 for the date range from 2012-06-07 to 2012-09-13. | 2014-11-04 15:12:25
Checking Intraday data file for symbol ESZ2-CME for the date range from 2012-09-13 to 2012-12-13. | 2014-11-04 15:12:25
Checking Daily data file for symbol ESZ12 for the date range from 2012-09-13 to 2012-12-13. | 2014-11-04 15:12:25
Checking Intraday data file for symbol ESH3-CME for the date range from 2012-12-13 to 2013-03-07. | 2014-11-04 15:12:25
Checking Daily data file for symbol ESH13 for the date range from 2012-12-13 to 2013-03-07. | 2014-11-04 15:12:25
Checking Intraday data file for symbol ESM3-CME for the date range from 2013-03-07 to 2013-06-13. | 2014-11-04 15:12:25
Checking Daily data file for symbol ESM13 for the date range from 2013-03-07 to 2013-06-13. | 2014-11-04 15:12:25
Checking Intraday data file for symbol ESU3-CME for the date range from 2013-06-13 to 2013-09-12. | 2014-11-04 15:12:25
Checking Daily data file for symbol ESU13 for the date range from 2013-06-13 to 2013-09-12. | 2014-11-04 15:12:25
Checking Intraday data file for symbol ESZ3-CME for the date range from 2013-09-12 to 2013-12-12. | 2014-11-04 15:12:25
Checking Daily data file for symbol ESZ13 for the date range from 2013-09-12 to 2013-12-12. | 2014-11-04 15:12:25
Checking Intraday data file for symbol ESH4-CME for the date range from 2013-12-12 to 2014-03-13. | 2014-11-04 15:12:25
Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-13. | 2014-11-04 15:12:25
Checking Intraday data file for symbol ESM4-CME for the date range from 2014-03-13 to 2014-06-12. | 2014-11-04 15:12:25
Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2014-11-04 15:12:25
Checking Intraday data file for symbol ESU4-CME for the date range from 2014-06-12 to 2014-09-11. | 2014-11-04 15:12:25
Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Min #3 | Symbols used for continuous contract chart: | 2014-11-04 15:12:25
ESU2-CME | 2014-11-04 15:12:25
ESZ2-CME | 2014-11-04 15:12:25
ESH3-CME | 2014-11-04 15:12:25
ESM3-CME | 2014-11-04 15:12:25
ESU3-CME | 2014-11-04 15:12:25
ESZ3-CME | 2014-11-04 15:12:25
ESH4-CME | 2014-11-04 15:12:25
ESM4-CME | 2014-11-04 15:12:25
ESU4-CME | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Min #3: Checking for volume based rollover dates. | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Min #3: Volume based rollover from ESU2-CME to ESZ2-CME occurs at 2012-09-14 | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Min #3: Volume based rollover from ESZ2-CME to ESH3-CME occurs at 2012-12-14 | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Min #3: Volume based rollover from ESH3-CME to ESM3-CME occurs at 2013-03-08 | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Min #3: Volume based rollover from ESM3-CME to ESU3-CME occurs at 2013-06-14 | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Min #3: Volume based rollover from ESU3-CME to ESZ3-CME occurs at 2013-09-13 | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Min #3: Volume based rollover from ESZ3-CME to ESH4-CME occurs at 2013-12-13 | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Min #3: Volume based rollover from ESH4-CME to ESM4-CME occurs at 2014-03-14 | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Min #3: Volume based rollover from ESM4-CME to ESU4-CME occurs at 2014-06-13 | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Min #3: Volume based rollover from ESU4-CME to ESZ4-CME occurs at 2014-09-12 | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Min #2 | Symbols used for continuous contract chart: | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Min #2: Checking for volume based rollover dates. | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Min #2: Volume based rollover from ESH4-CME to ESM4-CME occurs at 2014-03-14 | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Min #2: Volume based rollover from ESM4-CME to ESU4-CME occurs at 2014-06-13 | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Min #2: Volume based rollover from ESU4-CME to ESZ4-CME occurs at 2014-09-12 | 2014-11-04 15:12:25
Limiting the number of days back for the continuous futures chart to 4.9993155 years based on the account type. | 2014-11-04 15:12:25
Date rule based rollover from ESZ9-CME to next contract occurs at 2009-12-10. | 2014-11-04 15:12:25
Date rule based rollover from ESH0-CME to next contract occurs at 2010-03-11. | 2014-11-04 15:12:25
Date rule based rollover from ESM0-CME to next contract occurs at 2010-06-10. | 2014-11-04 15:12:25
Date rule based rollover from ESU0-CME to next contract occurs at 2010-09-09. | 2014-11-04 15:12:25
Date rule based rollover from ESZ0-CME to next contract occurs at 2010-12-09. | 2014-11-04 15:12:25
Date rule based rollover from ESH1-CME to next contract occurs at 2011-03-10. | 2014-11-04 15:12:25
Date rule based rollover from ESM1-CME to next contract occurs at 2011-06-09. | 2014-11-04 15:12:25
Date rule based rollover from ESU1-CME to next contract occurs at 2011-09-08. | 2014-11-04 15:12:25
Date rule based rollover from ESZ1-CME to next contract occurs at 2011-12-08. | 2014-11-04 15:12:25
Date rule based rollover from ESH2-CME to next contract occurs at 2012-03-08. | 2014-11-04 15:12:25
Date rule based rollover from ESM2-CME to next contract occurs at 2012-06-07. | 2014-11-04 15:12:25
Intraday data file for ESZ9-CME exists and is empty. Skipping Intraday data download. | 2014-11-04 15:12:25
Checking Daily data file for symbol ESZ09 for the date range from 2009-09-10 to 2009-12-10. | 2014-11-04 15:12:25
Intraday data file for ESH0-CME exists and is empty. Skipping Intraday data download. | 2014-11-04 15:12:25
Checking Daily data file for symbol ESH10 for the date range from 2009-12-10 to 2010-03-11. | 2014-11-04 15:12:25
Intraday data file for ESM0-CME exists and is empty. Skipping Intraday data download. | 2014-11-04 15:12:25
Checking Daily data file for symbol ESM10 for the date range from 2010-03-11 to 2010-06-10. | 2014-11-04 15:12:25
Intraday data file for ESU0-CME exists and is empty. Skipping Intraday data download. | 2014-11-04 15:12:25
Checking Daily data file for symbol ESU10 for the date range from 2010-06-10 to 2010-09-09. | 2014-11-04 15:12:25
Intraday data file for ESZ0-CME exists and is empty. Skipping Intraday data download. | 2014-11-04 15:12:25
Checking Daily data file for symbol ESZ10 for the date range from 2010-09-09 to 2010-12-09. | 2014-11-04 15:12:25
Checking Intraday data file for symbol ESH1-CME for the date range from 2010-12-09 to 2011-03-10. | 2014-11-04 15:12:25
Checking Daily data file for symbol ESH11 for the date range from 2010-12-09 to 2011-03-10. | 2014-11-04 15:12:25
Checking Intraday data file for symbol ESM1-CME for the date range from 2011-03-10 to 2011-06-09. | 2014-11-04 15:12:25
Checking Daily data file for symbol ESM11 for the date range from 2011-03-10 to 2011-06-09. | 2014-11-04 15:12:25
Checking Intraday data file for symbol ESU1-CME for the date range from 2011-06-09 to 2011-09-08. | 2014-11-04 15:12:25
Checking Daily data file for symbol ESU11 for the date range from 2011-06-09 to 2011-09-08. | 2014-11-04 15:12:25
Checking Intraday data file for symbol ESZ1-CME for the date range from 2011-09-08 to 2011-12-08. | 2014-11-04 15:12:25
Checking Daily data file for symbol ESZ11 for the date range from 2011-09-08 to 2011-12-08. | 2014-11-04 15:12:25
Checking Intraday data file for symbol ESH2-CME for the date range from 2011-12-08 to 2012-03-08. | 2014-11-04 15:12:25
Checking Daily data file for symbol ESH12 for the date range from 2011-12-08 to 2012-03-08. | 2014-11-04 15:12:25
Checking Intraday data file for symbol ESM2-CME for the date range from 2012-03-08 to 2012-06-07. | 2014-11-04 15:12:25
Checking Daily data file for symbol ESM12 for the date range from 2012-03-08 to 2012-06-07. | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Day #9 | Symbols used for continuous contract chart: | 2014-11-04 15:12:25
ESZ9-CME | 2014-11-04 15:12:25
ESH0-CME | 2014-11-04 15:12:25
ESM0-CME | 2014-11-04 15:12:25
ESU0-CME | 2014-11-04 15:12:25
ESZ0-CME | 2014-11-04 15:12:25
ESH1-CME | 2014-11-04 15:12:25
ESM1-CME | 2014-11-04 15:12:25
ESU1-CME | 2014-11-04 15:12:25
ESZ1-CME | 2014-11-04 15:12:25
ESH2-CME | 2014-11-04 15:12:25
ESM2-CME | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Day #9: Checking for volume based rollover dates. | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESZ9-CME to ESH0-CME occurs at 2009-12-11 | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESH0-CME to ESM0-CME occurs at 2010-03-12 | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESM0-CME to ESU0-CME occurs at 2010-06-11 | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESU0-CME to ESZ0-CME occurs at 2010-09-10 | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESZ0-CME to ESH1-CME occurs at 2010-12-10 | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESH1-CME to ESM1-CME occurs at 2011-03-11 | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESM1-CME to ESU1-CME occurs at 2011-06-10 | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESU1-CME to ESZ1-CME occurs at 2011-09-09 | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESZ1-CME to ESH2-CME occurs at 2011-12-09 | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESH2-CME to ESM2-CME occurs at 2012-03-09 | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESM2-CME to ESU2-CME occurs at 2012-06-08 | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESU2-CME to ESZ2-CME occurs at 2012-09-14 | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESZ2-CME to ESH3-CME occurs at 2012-12-14 | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESH3-CME to ESM3-CME occurs at 2013-03-08 | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESM3-CME to ESU3-CME occurs at 2013-06-14 | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESU3-CME to ESZ3-CME occurs at 2013-09-13 | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESZ3-CME to ESH4-CME occurs at 2013-12-13 | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESH4-CME to ESM4-CME occurs at 2014-03-14 | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESM4-CME to ESU4-CME occurs at 2014-06-13 | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESU4-CME to ESZ4-CME occurs at 2014-09-12 | 2014-11-04 15:12:25
ESZ4-CME [CV] 10 Sec #15 | Symbols used for continuous contract chart: | 2014-11-04 15:12:25
ESZ4-CME [CV] 10 Sec #15: Checking for volume based rollover dates. | 2014-11-04 15:12:25
ESZ4-CME [CV] 10 Sec #15: Volume based rollover from ESH4-CME to ESM4-CME occurs at 2014-03-14 | 2014-11-04 15:12:25
ESZ4-CME [CV] 10 Sec #15: Volume based rollover from ESM4-CME to ESU4-CME occurs at 2014-06-13 | 2014-11-04 15:12:25
ESZ4-CME [CV] 10 Sec #15: Volume based rollover from ESU4-CME to ESZ4-CME occurs at 2014-09-12 | 2014-11-04 15:12:25
ESZ4-CME [CV] 2000 Volume #17 | Symbols used for continuous contract chart: | 2014-11-04 15:12:25
ESZ4-CME [CV] 2000 Volume #17: Checking for volume based rollover dates. | 2014-11-04 15:12:25
Date rule based rollover from ESH4-CME to next contract occurs at 2014-03-13. | 2014-11-04 15:12:26
Date rule based rollover from ESM4-CME to next contract occurs at 2014-06-12. | 2014-11-04 15:12:26
Date rule based rollover from ESU4-CME to next contract occurs at 2014-09-11. | 2014-11-04 15:12:26
Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2014-11-04 15:12:26
Checking Intraday data file for symbol ESH4-CME for the date range from 2013-12-12 to 2014-03-13. | 2014-11-04 15:12:26
Checking Intraday data file for symbol ESM4-CME for the date range from 2014-03-13 to 2014-06-12. | 2014-11-04 15:12:26
Checking Intraday data file for symbol ESU4-CME for the date range from 2014-06-12 to 2014-09-11. | 2014-11-04 15:12:26
Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 0. | 2014-11-04 15:12:26
ESZ4-CME [C] 1 Min #20 | Symbols used for continuous contract chart: | 2014-11-04 15:12:26
ESH4-CME | 2014-11-04 15:12:26
ESM4-CME | 2014-11-04 15:12:26
ESU4-CME | 2014-11-04 15:12:26
ESZ4-CME | 2014-11-04 15:12:26
Date rule based rollover from ESZ3-CME to next contract occurs at 2013-12-12. | 2014-11-04 15:12:26
Checking Intraday data file for symbol ESZ3-CME for the date range from 2013-09-12 to 2013-12-12. | 2014-11-04 15:12:26
Checking Daily data file for symbol ESZ13 for the date range from 2013-09-12 to 2013-12-12. | 2014-11-04 15:12:26
Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-13. | 2014-11-04 15:12:26
Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2014-11-04 15:12:26
Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2014-11-04 15:12:26
Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-11-04. | 2014-11-04 15:12:26
ESZ4-CME [CV] 30 Min #23 | Symbols used for continuous contract chart: | 2014-11-04 15:12:26
ESZ3-CME | 2014-11-04 15:12:26
ESZ4-CME [CV] 30 Min #23: Checking for volume based rollover dates. | 2014-11-04 15:12:26
ESZ4-CME [CV] 30 Min #23: Volume based rollover from ESZ3-CME to ESH4-CME occurs at 2013-12-13 | 2014-11-04 15:12:26
ESZ4-CME [CV] 30 Min #23: Volume based rollover from ESH4-CME to ESM4-CME occurs at 2014-03-14 | 2014-11-04 15:12:26
ESZ4-CME [CV] 30 Min #23: Volume based rollover from ESM4-CME to ESU4-CME occurs at 2014-06-13 | 2014-11-04 15:12:26
ESZ4-CME [CV] 30 Min #23: Volume based rollover from ESU4-CME to ESZ4-CME occurs at 2014-09-12 | 2014-11-04 15:12:26
Date rule based rollover from ESM3-CME to next contract occurs at 2013-06-13. | 2014-11-04 15:12:26
Date rule based rollover from ESU3-CME to next contract occurs at 2013-09-12. | 2014-11-04 15:12:26
Checking Intraday data file for symbol ESM3-CME for the date range from 2013-03-07 to 2013-06-13. | 2014-11-04 15:12:26
Checking Daily data file for symbol ESM13 for the date range from 2013-03-07 to 2013-06-13. | 2014-11-04 15:12:26
Checking Intraday data file for symbol ESU3-CME for the date range from 2013-06-13 to 2013-09-12. | 2014-11-04 15:12:26
Checking Daily data file for symbol ESU13 for the date range from 2013-06-13 to 2013-09-12. | 2014-11-04 15:12:26
ESZ4-CME [CV] 2.50 Range #22 | Symbols used for continuous contract chart: | 2014-11-04 15:12:26
ESM3-CME | 2014-11-04 15:12:26
ESU3-CME | 2014-11-04 15:12:26
ESZ4-CME [CV] 2.50 Range #22: Checking for volume based rollover dates. | 2014-11-04 15:12:26
ESZ4-CME [CV] 2.50 Range #22: Volume based rollover from ESM3-CME to ESU3-CME occurs at 2013-06-14 | 2014-11-04 15:12:26
ESZ4-CME [CV] 2.50 Range #22: Volume based rollover from ESU3-CME to ESZ3-CME occurs at 2013-09-13 | 2014-11-04 15:12:26
ESZ4-CME [CV] 2.50 Range #22: Volume based rollover from ESZ3-CME to ESH4-CME occurs at 2013-12-13 | 2014-11-04 15:12:26
ESZ4-CME [CV] 2.50 Range #22: Volume based rollover from ESH4-CME to ESM4-CME occurs at 2014-03-14 | 2014-11-04 15:12:26
ESZ4-CME [CV] 2.50 Range #22: Volume based rollover from ESM4-CME to ESU4-CME occurs at 2014-06-13 | 2014-11-04 15:12:26
ESZ4-CME [CV] 2.50 Range #22: Volume based rollover from ESU4-CME to ESZ4-CME occurs at 2014-09-12 | 2014-11-04 15:12:26
Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2014-11-04 15:12:27
Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 0. | 2014-11-04 15:12:27
Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-11-04. | 2014-11-04 15:12:27
ESZ4-CME [CV] 1 Min #4 | Symbols used for continuous contract chart: | 2014-11-04 15:12:27
ESZ4-CME | 2014-11-04 15:12:27
ESZ4-CME [CV] 1 Min #4: Checking for volume based rollover dates. | 2014-11-04 15:12:27
ESZ4-CME [CV] 15 Min #24 | Symbols used for continuous contract chart: | 2014-11-04 15:12:27
ESZ4-CME [CV] 15 Min #24: Checking for volume based rollover dates. | 2014-11-04 15:12:27
Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 0. | 2014-11-04 15:12:28
Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-11-04. | 2014-11-04 15:12:28
ESZ4-CME [CV] 1.25 Range #25 | Symbols used for continuous contract chart: | 2014-11-04 15:12:28
ESZ4-CME | 2014-11-04 15:12:28
ESZ4-CME [CV] 1.25 Range #25: Checking for volume based rollover dates. | 2014-11-04 15:12:28
Date rule based rollover from ESH4-CME to next contract occurs at 2014-03-13. | 2014-11-04 15:12:28
Date rule based rollover from ESM4-CME to next contract occurs at 2014-06-12. | 2014-11-04 15:12:28
Date rule based rollover from ESU4-CME to next contract occurs at 2014-09-11. | 2014-11-04 15:12:28
Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2014-11-04 15:12:28
Checking Intraday data file for symbol ESH4-CME for the date range from 2013-12-12 to 2014-03-13. | 2014-11-04 15:12:28
Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-13. | 2014-11-04 15:12:28
Checking Intraday data file for symbol ESM4-CME for the date range from 2014-03-13 to 2014-06-12. | 2014-11-04 15:12:28
Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2014-11-04 15:12:28
Checking Intraday data file for symbol ESU4-CME for the date range from 2014-06-12 to 2014-09-11. | 2014-11-04 15:12:28
Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2014-11-04 15:12:28
ESZ4-CME [CV] 1.25 Range #19 | Symbols used for continuous contract chart: | 2014-11-04 15:12:28
ESH4-CME | 2014-11-04 15:12:28
ESM4-CME | 2014-11-04 15:12:28
ESU4-CME | 2014-11-04 15:12:28
ESZ4-CME [CV] 1.25 Range #19: Checking for volume based rollover dates. | 2014-11-04 15:12:28
ESZ4-CME [CV] 1.25 Range #19: Volume based rollover from ESH4-CME to ESM4-CME occurs at 2014-03-14 | 2014-11-04 15:12:28
ESZ4-CME [CV] 1.25 Range #19: Volume based rollover from ESM4-CME to ESU4-CME occurs at 2014-06-13 | 2014-11-04 15:12:28
ESZ4-CME [CV] 1.25 Range #19: Volume based rollover from ESU4-CME to ESZ4-CME occurs at 2014-09-12 | 2014-11-04 15:12:28
ESZ4-CME [CV] 1.25 Range #13 | Symbols used for continuous contract chart: | 2014-11-04 15:12:28
ESZ4-CME [CV] 1.25 Range #13: Checking for volume based rollover dates. | 2014-11-04 15:12:28
ESZ4-CME [CV] 1.25 Range #13: Volume based rollover from ESH4-CME to ESM4-CME occurs at 2014-03-14 | 2014-11-04 15:12:28
ESZ4-CME [CV] 1.25 Range #13: Volume based rollover from ESM4-CME to ESU4-CME occurs at 2014-06-13 | 2014-11-04 15:12:28
ESZ4-CME [CV] 1.25 Range #13: Volume based rollover from ESU4-CME to ESZ4-CME occurs at 2014-09-12 | 2014-11-04 15:12:28
HD Request # 14 | Downloading Intraday chart data for ESZ4-CME to the file ESZ4-CME.scid. Service: rim | 2014-11-04 15:12:28
HD Request # 14 | Download start Date-Time: 2014-10-26 21:14:59.0 | 2014-11-04 15:12:28
HD Request # 14 | Using server: ds5.sierracharts.com port 10149 | 2014-11-04 15:12:28
Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-11-04 15:12:28
Socket (964) | Connected. | 2014-11-04 15:12:28
HD Request # 14 | Sending historical data logon request message. | 2014-11-04 15:12:28
HD Request # 14 | Requesting Intraday data. Start Date-Time: 2014-10-26 21:14:59. Record interval: 0. Symbol: ESZ4-CME | 2014-11-04 15:12:28
HD Request # 14 | Decompressing data. | 2014-11-04 15:12:29
HD Request # 14 | Receiving Intraday data for ESZ4-CME starting at 2014-10-26 21:15:00 | 2014-11-04 15:12:29
HD Request # 14 | Timestamp of first Intraday data file record written: 2014-10-26 21:15:00 | 2014-11-04 15:12:29
Socket (964) | Shutdown and closed. | 2014-11-04 15:12:41
The network socket for historical data has been closed. | 2014-11-04 15:12:41
HD Request # 14 | Received 3682137 records from 2014-10-26 21:15:00 to 2014-11-04 15:12:24 (8.8 days) and wrote 3682137 records for ESZ4-CME | 2014-11-04 15:12:41
HD Request # 14 | Intraday download COMPLETE for ESZ4-CME. Completion time: 13s. Unique request ID: 13 | 2014-11-04 15:12:41
Removed historical data download ID 13 | 2014-11-04 15:12:41
Real-time Intraday chart data file updates started for ESZ4-CME | 2014-11-04 15:12:41
[2014-11-04 23:34:02]
We need to have the source of the problem isolated.
Disable the Continuous Futures Contract option for the chart to rule that out as a possibility.
Date Time Of Last Edit: 2014-11-04 23:46:58
[2014-11-05 13:57:18]
OneMoreTick - Posts: 79
Here's the chart after disabling continuous contract and doing Delete All Data and Download: http://www.sierrachart.com/image.php?l=1415195637796.png
These are screenshots of a 5 tick range chart after disabling continuous contract and doing Delete All Data and Download: http://www.sierrachart.com/image.php?l=1415195311197.png
This is the exact same chart moments later after another Delete All Data and Download: http://www.sierrachart.com/image.php?l=1415195493409.png
I've left on the "Time Range Highlight" study as it's set to highlight the chart from 6:30 - 13:15 for my time zone(Pacific). It's helpful for me to see the time discrepancies where they are gaps in the highlights.
Software version: 1205 | 2014-11-04 15:06:29
Usage end date: 2015-01-20 | 2014-11-04 15:06:29
Enabled for: Advanced Features. | 2014-11-04 15:06:29
Enabled for: Advanced Features 2. | 2014-11-04 15:06:29
Enabled for: Sierra Chart Historical Data Service. | 2014-11-04 15:06:29
Allow Support for Sierra Chart Data Feeds is enabled. | 2014-11-04 15:06:29
Active service: Rithmic Trading | 2014-11-04 15:06:29
Data/Trade Service Settings automatically set. | 2014-11-04 15:06:29
Time Zone: -08:00:00 (PST-08PDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2014-11-04 15:06:29
2014-11-04 15:06:29 Local computer clock time | 2014-11-04 15:06:29
2014-11-04 23:06:29 GMT time | 2014-11-04 15:06:29
2014-11-04 15:06:29 Time zone adjusted time | 2014-11-04 15:06:29
Time difference to server time: 0 seconds. | 2014-11-04 15:06:29
Program path: C:\SierraChart\ | 2014-11-04 15:06:29
Data Files path: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ | 2014-11-04 15:06:29
OS Version Number: 6.1 | 2014-11-04 15:06:29
Locale Information: C | 2014-11-04 15:06:29
Checking for new symbol settings for rim | 2014-11-04 15:06:29
HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 88.198.13.175 | 2014-11-04 15:06:29
HTTP connection to www.sierrachart.com:80 (1068) | Connected. | 2014-11-04 15:06:29
Symbol settings are up-to-date for rim | 2014-11-04 15:06:31
Files to Open on Start up | Opening file: ES - VZones.cht | 2014-11-04 15:06:32
Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2014-11-04 15:06:32
Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 0. | 2014-11-04 15:06:32
Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-11-04. | 2014-11-04 15:06:32
ESZ4-CME [CV] 5 Min #12 | Symbols used for continuous contract chart: | 2014-11-04 15:06:32
ESZ4-CME | 2014-11-04 15:06:32
ESZ4-CME [CV] 5 Min #12: Checking for volume based rollover dates. | 2014-11-04 15:06:32
Date rule based rollover from ESU2-CME to next contract occurs at 2012-09-13. | 2014-11-04 15:06:32
Date rule based rollover from ESZ2-CME to next contract occurs at 2012-12-13. | 2014-11-04 15:06:32
Date rule based rollover from ESH3-CME to next contract occurs at 2013-03-07. | 2014-11-04 15:06:32
Date rule based rollover from ESM3-CME to next contract occurs at 2013-06-13. | 2014-11-04 15:06:32
Date rule based rollover from ESU3-CME to next contract occurs at 2013-09-12. | 2014-11-04 15:06:32
Date rule based rollover from ESZ3-CME to next contract occurs at 2013-12-12. | 2014-11-04 15:06:32
Date rule based rollover from ESH4-CME to next contract occurs at 2014-03-13. | 2014-11-04 15:06:32
Date rule based rollover from ESM4-CME to next contract occurs at 2014-06-12. | 2014-11-04 15:06:32
Date rule based rollover from ESU4-CME to next contract occurs at 2014-09-11. | 2014-11-04 15:06:32
Checking Intraday data file for symbol ESU2-CME for the date range from 2012-06-07 to 2012-09-13. | 2014-11-04 15:06:32
Checking Daily data file for symbol ESU12 for the date range from 2012-06-07 to 2012-09-13. | 2014-11-04 15:06:32
Checking Intraday data file for symbol ESZ2-CME for the date range from 2012-09-13 to 2012-12-13. | 2014-11-04 15:06:32
Checking Daily data file for symbol ESZ12 for the date range from 2012-09-13 to 2012-12-13. | 2014-11-04 15:06:32
Checking Intraday data file for symbol ESH3-CME for the date range from 2012-12-13 to 2013-03-07. | 2014-11-04 15:06:32
Checking Daily data file for symbol ESH13 for the date range from 2012-12-13 to 2013-03-07. | 2014-11-04 15:06:32
Checking Intraday data file for symbol ESM3-CME for the date range from 2013-03-07 to 2013-06-13. | 2014-11-04 15:06:32
Checking Daily data file for symbol ESM13 for the date range from 2013-03-07 to 2013-06-13. | 2014-11-04 15:06:32
Checking Intraday data file for symbol ESU3-CME for the date range from 2013-06-13 to 2013-09-12. | 2014-11-04 15:06:32
Checking Daily data file for symbol ESU13 for the date range from 2013-06-13 to 2013-09-12. | 2014-11-04 15:06:32
Checking Intraday data file for symbol ESZ3-CME for the date range from 2013-09-12 to 2013-12-12. | 2014-11-04 15:06:32
Checking Daily data file for symbol ESZ13 for the date range from 2013-09-12 to 2013-12-12. | 2014-11-04 15:06:32
Checking Intraday data file for symbol ESH4-CME for the date range from 2013-12-12 to 2014-03-13. | 2014-11-04 15:06:32
Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-13. | 2014-11-04 15:06:32
Checking Intraday data file for symbol ESM4-CME for the date range from 2014-03-13 to 2014-06-12. | 2014-11-04 15:06:32
Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2014-11-04 15:06:32
Checking Intraday data file for symbol ESU4-CME for the date range from 2014-06-12 to 2014-09-11. | 2014-11-04 15:06:32
Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Min #3 | Symbols used for continuous contract chart: | 2014-11-04 15:06:32
ESU2-CME | 2014-11-04 15:06:32
ESZ2-CME | 2014-11-04 15:06:32
ESH3-CME | 2014-11-04 15:06:32
ESM3-CME | 2014-11-04 15:06:32
ESU3-CME | 2014-11-04 15:06:32
ESZ3-CME | 2014-11-04 15:06:32
ESH4-CME | 2014-11-04 15:06:32
ESM4-CME | 2014-11-04 15:06:32
ESU4-CME | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Min #3: Checking for volume based rollover dates. | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Min #3: Volume based rollover from ESU2-CME to ESZ2-CME occurs at 2012-09-14 | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Min #3: Volume based rollover from ESZ2-CME to ESH3-CME occurs at 2012-12-14 | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Min #3: Volume based rollover from ESH3-CME to ESM3-CME occurs at 2013-03-08 | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Min #3: Volume based rollover from ESM3-CME to ESU3-CME occurs at 2013-06-14 | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Min #3: Volume based rollover from ESU3-CME to ESZ3-CME occurs at 2013-09-13 | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Min #3: Volume based rollover from ESZ3-CME to ESH4-CME occurs at 2013-12-13 | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Min #3: Volume based rollover from ESH4-CME to ESM4-CME occurs at 2014-03-14 | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Min #3: Volume based rollover from ESM4-CME to ESU4-CME occurs at 2014-06-13 | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Min #3: Volume based rollover from ESU4-CME to ESZ4-CME occurs at 2014-09-12 | 2014-11-04 15:06:32
TICK-NYSE 3 Min #8 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 09:30:00. Next Bar Date Time: 2014-11-04 09:12:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\TICK-NYSE.scid | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Min #2 | Symbols used for continuous contract chart: | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Min #2: Checking for volume based rollover dates. | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Min #2: Volume based rollover from ESH4-CME to ESM4-CME occurs at 2014-03-14 | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Min #2: Volume based rollover from ESM4-CME to ESU4-CME occurs at 2014-06-13 | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Min #2: Volume based rollover from ESU4-CME to ESZ4-CME occurs at 2014-09-12 | 2014-11-04 15:06:32
Date rule based rollover from ESZ11 to next contract occurs at 2011-12-08. | 2014-11-04 15:06:32
Date rule based rollover from ESH12 to next contract occurs at 2012-03-08. | 2014-11-04 15:06:32
Date rule based rollover from ESM12 to next contract occurs at 2012-06-07. | 2014-11-04 15:06:32
Date rule based rollover from ESU12 to next contract occurs at 2012-09-13. | 2014-11-04 15:06:32
Date rule based rollover from ESZ12 to next contract occurs at 2012-12-13. | 2014-11-04 15:06:32
Date rule based rollover from ESH13 to next contract occurs at 2013-03-07. | 2014-11-04 15:06:32
Date rule based rollover from ESM13 to next contract occurs at 2013-06-13. | 2014-11-04 15:06:32
Date rule based rollover from ESU13 to next contract occurs at 2013-09-12. | 2014-11-04 15:06:32
Date rule based rollover from ESZ13 to next contract occurs at 2013-12-12. | 2014-11-04 15:06:32
Date rule based rollover from ESH14 to next contract occurs at 2014-03-13. | 2014-11-04 15:06:32
Date rule based rollover from ESM14 to next contract occurs at 2014-06-12. | 2014-11-04 15:06:32
Date rule based rollover from ESU14 to next contract occurs at 2014-09-11. | 2014-11-04 15:06:32
Date rule based rollover from ESZ14 to next contract occurs at 2014-12-11. | 2014-11-04 15:06:32
Checking Daily data file for symbol ESZ11 for the date range from 2011-09-08 to 2011-12-08. | 2014-11-04 15:06:32
Checking Daily data file for symbol ESH12 for the date range from 2011-12-08 to 2012-03-08. | 2014-11-04 15:06:32
Checking Daily data file for symbol ESM12 for the date range from 2012-03-08 to 2012-06-07. | 2014-11-04 15:06:32
ESZ14/ESZ4-CME [CV] Weekly #5 | Symbols used for continuous contract chart: | 2014-11-04 15:06:32
ESZ11 | 2014-11-04 15:06:32
ESH12 | 2014-11-04 15:06:32
ESM12 | 2014-11-04 15:06:32
ESU12 | 2014-11-04 15:06:32
ESZ12 | 2014-11-04 15:06:32
ESH13 | 2014-11-04 15:06:32
ESM13 | 2014-11-04 15:06:32
ESU13 | 2014-11-04 15:06:32
ESZ13 | 2014-11-04 15:06:32
ESH14 | 2014-11-04 15:06:32
ESM14 | 2014-11-04 15:06:32
ESU14 | 2014-11-04 15:06:32
ESZ14 | 2014-11-04 15:06:32
ESZ14/ESZ4-CME [CV] Weekly #5: Checking for volume based rollover dates. | 2014-11-04 15:06:32
ESZ14/ESZ4-CME [CV] Weekly #5: Volume based rollover from ESZ11 to ESH12 occurs at 2011-12-09 | 2014-11-04 15:06:32
ESZ14/ESZ4-CME [CV] Weekly #5: Volume based rollover from ESH12 to ESM12 occurs at 2012-03-09 | 2014-11-04 15:06:32
ESZ14/ESZ4-CME [CV] Weekly #5: Volume based rollover from ESM12 to ESU12 occurs at 2012-06-08 | 2014-11-04 15:06:32
ESZ14/ESZ4-CME [CV] Weekly #5: Volume based rollover from ESU12 to ESZ12 occurs at 2012-09-14 | 2014-11-04 15:06:32
ESZ14/ESZ4-CME [CV] Weekly #5: Volume based rollover from ESZ12 to ESH13 occurs at 2012-12-14 | 2014-11-04 15:06:32
ESZ14/ESZ4-CME [CV] Weekly #5: Volume based rollover from ESH13 to ESM13 occurs at 2013-03-08 | 2014-11-04 15:06:32
ESZ14/ESZ4-CME [CV] Weekly #5: Volume based rollover from ESM13 to ESU13 occurs at 2013-06-14 | 2014-11-04 15:06:32
TICK-NYSE 1 Min #6 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 09:30:00. Next Bar Date Time: 2014-11-04 09:13:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\TICK-NYSE.scid | 2014-11-04 15:06:32
ESZ14/ESZ4-CME [CV] Weekly #5: Volume based rollover from ESU13 to ESZ13 occurs at 2013-09-13 | 2014-11-04 15:06:32
ESZ14/ESZ4-CME [CV] Weekly #5: Volume based rollover from ESZ13 to ESH14 occurs at 2013-12-13 | 2014-11-04 15:06:32
ESZ14/ESZ4-CME [CV] Weekly #5: Volume based rollover from ESH14 to ESM14 occurs at 2014-03-14 | 2014-11-04 15:06:32
ESZ14/ESZ4-CME [CV] Weekly #5: Volume based rollover from ESM14 to ESU14 occurs at 2014-06-13 | 2014-11-04 15:06:32
ESZ14/ESZ4-CME [CV] Weekly #5: Volume based rollover from ESU14 to ESZ14 occurs at 2014-09-12 | 2014-11-04 15:06:32
Limiting the number of days back for the continuous futures chart to 4.9993155 years based on the account type. | 2014-11-04 15:06:32
Date rule based rollover from ESZ9-CME to next contract occurs at 2009-12-10. | 2014-11-04 15:06:32
Date rule based rollover from ESH0-CME to next contract occurs at 2010-03-11. | 2014-11-04 15:06:32
Date rule based rollover from ESM0-CME to next contract occurs at 2010-06-10. | 2014-11-04 15:06:32
Date rule based rollover from ESU0-CME to next contract occurs at 2010-09-09. | 2014-11-04 15:06:32
Date rule based rollover from ESZ0-CME to next contract occurs at 2010-12-09. | 2014-11-04 15:06:32
Date rule based rollover from ESH1-CME to next contract occurs at 2011-03-10. | 2014-11-04 15:06:32
Date rule based rollover from ESM1-CME to next contract occurs at 2011-06-09. | 2014-11-04 15:06:32
Date rule based rollover from ESU1-CME to next contract occurs at 2011-09-08. | 2014-11-04 15:06:32
Date rule based rollover from ESZ1-CME to next contract occurs at 2011-12-08. | 2014-11-04 15:06:32
Date rule based rollover from ESH2-CME to next contract occurs at 2012-03-08. | 2014-11-04 15:06:32
Date rule based rollover from ESM2-CME to next contract occurs at 2012-06-07. | 2014-11-04 15:06:32
Intraday data file for ESZ9-CME exists and is empty. Skipping Intraday data download. | 2014-11-04 15:06:32
Checking Daily data file for symbol ESZ09 for the date range from 2009-09-10 to 2009-12-10. | 2014-11-04 15:06:32
Intraday data file for ESH0-CME exists and is empty. Skipping Intraday data download. | 2014-11-04 15:06:32
Checking Daily data file for symbol ESH10 for the date range from 2009-12-10 to 2010-03-11. | 2014-11-04 15:06:32
Intraday data file for ESM0-CME exists and is empty. Skipping Intraday data download. | 2014-11-04 15:06:32
Checking Daily data file for symbol ESM10 for the date range from 2010-03-11 to 2010-06-10. | 2014-11-04 15:06:32
Intraday data file for ESU0-CME exists and is empty. Skipping Intraday data download. | 2014-11-04 15:06:32
Checking Daily data file for symbol ESU10 for the date range from 2010-06-10 to 2010-09-09. | 2014-11-04 15:06:32
Intraday data file for ESZ0-CME exists and is empty. Skipping Intraday data download. | 2014-11-04 15:06:32
Checking Daily data file for symbol ESZ10 for the date range from 2010-09-09 to 2010-12-09. | 2014-11-04 15:06:32
Checking Intraday data file for symbol ESH1-CME for the date range from 2010-12-09 to 2011-03-10. | 2014-11-04 15:06:32
Checking Daily data file for symbol ESH11 for the date range from 2010-12-09 to 2011-03-10. | 2014-11-04 15:06:32
Checking Intraday data file for symbol ESM1-CME for the date range from 2011-03-10 to 2011-06-09. | 2014-11-04 15:06:32
Checking Daily data file for symbol ESM11 for the date range from 2011-03-10 to 2011-06-09. | 2014-11-04 15:06:32
Checking Intraday data file for symbol ESU1-CME for the date range from 2011-06-09 to 2011-09-08. | 2014-11-04 15:06:32
Checking Daily data file for symbol ESU11 for the date range from 2011-06-09 to 2011-09-08. | 2014-11-04 15:06:32
Checking Intraday data file for symbol ESZ1-CME for the date range from 2011-09-08 to 2011-12-08. | 2014-11-04 15:06:32
Checking Intraday data file for symbol ESH2-CME for the date range from 2011-12-08 to 2012-03-08. | 2014-11-04 15:06:32
Checking Intraday data file for symbol ESM2-CME for the date range from 2012-03-08 to 2012-06-07. | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Day #9 | Symbols used for continuous contract chart: | 2014-11-04 15:06:32
ESZ9-CME | 2014-11-04 15:06:32
ESH0-CME | 2014-11-04 15:06:32
ESM0-CME | 2014-11-04 15:06:32
ESU0-CME | 2014-11-04 15:06:32
ESZ0-CME | 2014-11-04 15:06:32
ESH1-CME | 2014-11-04 15:06:32
ESM1-CME | 2014-11-04 15:06:32
ESU1-CME | 2014-11-04 15:06:32
ESZ1-CME | 2014-11-04 15:06:32
ESH2-CME | 2014-11-04 15:06:32
ESM2-CME | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Day #9: Checking for volume based rollover dates. | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESZ9-CME to ESH0-CME occurs at 2009-12-11 | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESH0-CME to ESM0-CME occurs at 2010-03-12 | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESM0-CME to ESU0-CME occurs at 2010-06-11 | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESU0-CME to ESZ0-CME occurs at 2010-09-10 | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESZ0-CME to ESH1-CME occurs at 2010-12-10 | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESH1-CME to ESM1-CME occurs at 2011-03-11 | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESM1-CME to ESU1-CME occurs at 2011-06-10 | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESU1-CME to ESZ1-CME occurs at 2011-09-09 | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESZ1-CME to ESH2-CME occurs at 2011-12-09 | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESH2-CME to ESM2-CME occurs at 2012-03-09 | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESM2-CME to ESU2-CME occurs at 2012-06-08 | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESU2-CME to ESZ2-CME occurs at 2012-09-14 | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESZ2-CME to ESH3-CME occurs at 2012-12-14 | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESH3-CME to ESM3-CME occurs at 2013-03-08 | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESM3-CME to ESU3-CME occurs at 2013-06-14 | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESU3-CME to ESZ3-CME occurs at 2013-09-13 | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESZ3-CME to ESH4-CME occurs at 2013-12-13 | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESH4-CME to ESM4-CME occurs at 2014-03-14 | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESM4-CME to ESU4-CME occurs at 2014-06-13 | 2014-11-04 15:06:32
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESU4-CME to ESZ4-CME occurs at 2014-09-12 | 2014-11-04 15:06:32
ESZ4-CME [CV] 10 Sec #15 | Symbols used for continuous contract chart: | 2014-11-04 15:06:32
ESZ4-CME [CV] 10 Sec #15: Checking for volume based rollover dates. | 2014-11-04 15:06:32
ESZ4-CME [CV] 10 Sec #15: Volume based rollover from ESH4-CME to ESM4-CME occurs at 2014-03-14 | 2014-11-04 15:06:32
ESZ4-CME [CV] 10 Sec #15: Volume based rollover from ESM4-CME to ESU4-CME occurs at 2014-06-13 | 2014-11-04 15:06:32
ESZ4-CME [CV] 10 Sec #15: Volume based rollover from ESU4-CME to ESZ4-CME occurs at 2014-09-12 | 2014-11-04 15:06:32
Date rule based rollover from ZBU4-CBOT to next contract occurs at 2014-08-29. | 2014-11-04 15:06:33
Date rule based rollover from ZBZ4-CBOT to next contract occurs at 2014-11-28. | 2014-11-04 15:06:33
Checking Intraday data file for symbol ZBU4-CBOT for the date range from 2014-05-30 to 2014-08-29. | 2014-11-04 15:06:33
Checking Daily data file for symbol ZBU14 for the date range from 2014-05-30 to 2014-08-29. | 2014-11-04 15:06:33
Checking Intraday data file for symbol ZBZ4-CBOT for the date range from 2014-08-29 to 0. | 2014-11-04 15:06:33
Checking Daily data file for symbol ZBZ14 for the date range from 2014-08-29 to 2014-11-04. | 2014-11-04 15:06:33
ZBZ4-CBOT [CV] 5 Min #1 | Symbols used for continuous contract chart: | 2014-11-04 15:06:33
ZBU4-CBOT | 2014-11-04 15:06:33
ZBZ4-CBOT | 2014-11-04 15:06:33
ZBZ4-CBOT [CV] 5 Min #1: Checking for volume based rollover dates. | 2014-11-04 15:06:33
ZBZ4-CBOT [CV] 5 Min #1: Volume based rollover from ZBU4-CBOT to ZBZ4-CBOT occurs at 2014-08-29 | 2014-11-04 15:06:33
Notice: The study 'Opening Range' has sc.FreeDLL set to true. Use only during development! Set to false to reduce CPU time. | 2014-11-04 15:06:33
Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2014-11-04 15:06:33
Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 0. | 2014-11-04 15:06:33
Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-11-04. | 2014-11-04 15:06:33
ESZ4-CME [CV] 2000 Volume #17 | Symbols used for continuous contract chart: | 2014-11-04 15:06:33
ESZ4-CME | 2014-11-04 15:06:33
ESZ4-CME [CV] 2000 Volume #17: Checking for volume based rollover dates. | 2014-11-04 15:06:33
Date rule based rollover from ESH4-CME to next contract occurs at 2014-03-13. | 2014-11-04 15:06:34
Date rule based rollover from ESM4-CME to next contract occurs at 2014-06-12. | 2014-11-04 15:06:34
Date rule based rollover from ESU4-CME to next contract occurs at 2014-09-11. | 2014-11-04 15:06:34
Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2014-11-04 15:06:34
Checking Intraday data file for symbol ESH4-CME for the date range from 2013-12-12 to 2014-03-13. | 2014-11-04 15:06:34
Checking Intraday data file for symbol ESM4-CME for the date range from 2014-03-13 to 2014-06-12. | 2014-11-04 15:06:34
Checking Intraday data file for symbol ESU4-CME for the date range from 2014-06-12 to 2014-09-11. | 2014-11-04 15:06:34
Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 0. | 2014-11-04 15:06:34
ESZ4-CME [C] 1 Min #20 | Symbols used for continuous contract chart: | 2014-11-04 15:06:34
ESH4-CME | 2014-11-04 15:06:34
ESM4-CME | 2014-11-04 15:06:34
ESU4-CME | 2014-11-04 15:06:34
ESZ4-CME | 2014-11-04 15:06:34
ZBZ4-CBOT [CV] 5 Min #1 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-08-10 14:55:01. Next Bar Date Time: 2014-08-08 13:55:01. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ZBZ4-CBOT.scid | 2014-11-04 15:06:34
ZBZ4-CBOT [CV] 5 Min #1 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-08-10 16:00:01. Next Bar Date Time: 2014-08-10 15:50:01. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ZBZ4-CBOT.scid | 2014-11-04 15:06:34
ZBZ4-CBOT [CV] 5 Min #1 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-08-10 20:10:01. Next Bar Date Time: 2014-08-10 20:00:01. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ZBZ4-CBOT.scid | 2014-11-04 15:06:34
ZBZ4-CBOT [CV] 5 Min #1 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-08-10 21:05:01. Next Bar Date Time: 2014-08-10 20:55:01. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ZBZ4-CBOT.scid | 2014-11-04 15:06:34
ZBZ4-CBOT [CV] 5 Min #1 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-08-10 22:35:01. Next Bar Date Time: 2014-08-10 22:25:01. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ZBZ4-CBOT.scid | 2014-11-04 15:06:34
ZBZ4-CBOT [CV] 5 Min #1 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-08-11 02:30:01. Next Bar Date Time: 2014-08-11 02:20:01. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ZBZ4-CBOT.scid | 2014-11-04 15:06:34
ZBZ4-CBOT [CV] 5 Min #1 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-08-11 14:55:01. Next Bar Date Time: 2014-08-11 13:55:01. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ZBZ4-CBOT.scid | 2014-11-04 15:06:34
ZBZ4-CBOT [CV] 5 Min #1 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-08-11 16:00:01. Next Bar Date Time: 2014-08-11 15:50:01. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ZBZ4-CBOT.scid | 2014-11-04 15:06:34
ZBZ4-CBOT [CV] 5 Min #1 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-08-11 19:00:01. Next Bar Date Time: 2014-08-11 18:45:01. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ZBZ4-CBOT.scid | 2014-11-04 15:06:34
ZBZ4-CBOT [CV] 5 Min #1 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-08-11 20:20:01. Next Bar Date Time: 2014-08-11 19:45:01. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ZBZ4-CBOT.scid | 2014-11-04 15:06:34
ZBZ4-CBOT [CV] 5 Min #1 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-08-11 20:55:01. Next Bar Date Time: 2014-08-11 20:45:01. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ZBZ4-CBOT.scid | 2014-11-04 15:06:34
ZBZ4-CBOT [CV] 5 Min #1 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-08-11 21:25:01. Next Bar Date Time: 2014-08-11 21:15:01. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ZBZ4-CBOT.scid | 2014-11-04 15:06:34
ZBZ4-CBOT [CV] 5 Min #1 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-08-12 14:55:01. Next Bar Date Time: 2014-08-12 13:55:01. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ZBZ4-CBOT.scid | 2014-11-04 15:06:34
Date rule based rollover from ESZ3-CME to next contract occurs at 2013-12-12. | 2014-11-04 15:06:34
Checking Intraday data file for symbol ESZ3-CME for the date range from 2013-09-12 to 2013-12-12. | 2014-11-04 15:06:34
Checking Daily data file for symbol ESZ13 for the date range from 2013-09-12 to 2013-12-12. | 2014-11-04 15:06:34
Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-13. | 2014-11-04 15:06:34
Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2014-11-04 15:06:34
Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2014-11-04 15:06:34
Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-11-04. | 2014-11-04 15:06:34
ESZ4-CME [CV] 30 Min #23 | Symbols used for continuous contract chart: | 2014-11-04 15:06:34
ESZ3-CME | 2014-11-04 15:06:34
ESZ4-CME [CV] 30 Min #23: Checking for volume based rollover dates. | 2014-11-04 15:06:34
ESZ4-CME [CV] 30 Min #23: Volume based rollover from ESZ3-CME to ESH4-CME occurs at 2013-12-13 | 2014-11-04 15:06:34
ESZ4-CME [CV] 30 Min #23: Volume based rollover from ESH4-CME to ESM4-CME occurs at 2014-03-14 | 2014-11-04 15:06:34
ESZ4-CME [CV] 30 Min #23: Volume based rollover from ESM4-CME to ESU4-CME occurs at 2014-06-13 | 2014-11-04 15:06:34
ESZ4-CME [CV] 30 Min #23: Volume based rollover from ESU4-CME to ESZ4-CME occurs at 2014-09-12 | 2014-11-04 15:06:34
Date rule based rollover from ESM3-CME to next contract occurs at 2013-06-13. | 2014-11-04 15:06:34
Date rule based rollover from ESU3-CME to next contract occurs at 2013-09-12. | 2014-11-04 15:06:34
Checking Intraday data file for symbol ESM3-CME for the date range from 2013-03-07 to 2013-06-13. | 2014-11-04 15:06:34
Checking Daily data file for symbol ESM13 for the date range from 2013-03-07 to 2013-06-13. | 2014-11-04 15:06:34
Checking Intraday data file for symbol ESU3-CME for the date range from 2013-06-13 to 2013-09-12. | 2014-11-04 15:06:34
Checking Daily data file for symbol ESU13 for the date range from 2013-06-13 to 2013-09-12. | 2014-11-04 15:06:34
ESZ4-CME [CV] 2.50 Range #22 | Symbols used for continuous contract chart: | 2014-11-04 15:06:34
ESM3-CME | 2014-11-04 15:06:34
ESU3-CME | 2014-11-04 15:06:34
ESZ4-CME [CV] 2.50 Range #22: Checking for volume based rollover dates. | 2014-11-04 15:06:34
ESZ4-CME [CV] 2.50 Range #22: Volume based rollover from ESM3-CME to ESU3-CME occurs at 2013-06-14 | 2014-11-04 15:06:34
ESZ4-CME [CV] 2.50 Range #22: Volume based rollover from ESU3-CME to ESZ3-CME occurs at 2013-09-13 | 2014-11-04 15:06:34
ESZ4-CME [CV] 2.50 Range #22: Volume based rollover from ESZ3-CME to ESH4-CME occurs at 2013-12-13 | 2014-11-04 15:06:34
ESZ4-CME [CV] 2.50 Range #22: Volume based rollover from ESH4-CME to ESM4-CME occurs at 2014-03-14 | 2014-11-04 15:06:34
ESZ4-CME [CV] 2.50 Range #22: Volume based rollover from ESM4-CME to ESU4-CME occurs at 2014-06-13 | 2014-11-04 15:06:34
ESZ4-CME [CV] 2.50 Range #22: Volume based rollover from ESU4-CME to ESZ4-CME occurs at 2014-09-12 | 2014-11-04 15:06:34
ZBZ4-CBOT [CV] 5 Min #1 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-08-18 14:55:01. Next Bar Date Time: 2014-08-18 13:55:01. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ZBZ4-CBOT.scid | 2014-11-04 15:06:34
ZBZ4-CBOT [CV] 5 Min #1 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-08-18 17:45:01. Next Bar Date Time: 2014-08-18 17:35:01. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ZBZ4-CBOT.scid | 2014-11-04 15:06:34
ZBZ4-CBOT [CV] 5 Min #1 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-08-18 19:45:01. Next Bar Date Time: 2014-08-18 19:35:01. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ZBZ4-CBOT.scid | 2014-11-04 15:06:34
ZBZ4-CBOT [CV] 5 Min #1 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-08-18 20:05:01. Next Bar Date Time: 2014-08-18 19:55:01. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ZBZ4-CBOT.scid | 2014-11-04 15:06:34
ZBZ4-CBOT [CV] 5 Min #1 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-08-18 20:35:01. Next Bar Date Time: 2014-08-18 20:25:01. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ZBZ4-CBOT.scid | 2014-11-04 15:06:34
ZBZ4-CBOT [CV] 5 Min #1 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-08-18 21:25:01. Next Bar Date Time: 2014-08-18 21:15:01. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ZBZ4-CBOT.scid | 2014-11-04 15:06:34
ZBZ4-CBOT [CV] 5 Min #1 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-08-18 21:35:01. Next Bar Date Time: 2014-08-18 21:25:01. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ZBZ4-CBOT.scid | 2014-11-04 15:06:34
ESZ4-CME [CV] 1 Min #4 | Symbols used for continuous contract chart: | 2014-11-04 15:06:34
ESZ4-CME [CV] 1 Min #4: Checking for volume based rollover dates. | 2014-11-04 15:06:34
Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2014-11-04 15:06:35
Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 0. | 2014-11-04 15:06:35
Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-11-04. | 2014-11-04 15:06:35
ESZ4-CME [CV] 15 Min #24 | Symbols used for continuous contract chart: | 2014-11-04 15:06:35
ESZ4-CME | 2014-11-04 15:06:35
ESZ4-CME [CV] 15 Min #24: Checking for volume based rollover dates. | 2014-11-04 15:06:35
ESZ4-CME [CV] 1.25 Range #25 | Symbols used for continuous contract chart: | 2014-11-04 15:06:35
ESZ4-CME [CV] 1.25 Range #25: Checking for volume based rollover dates. | 2014-11-04 15:06:35
Date rule based rollover from ESH4-CME to next contract occurs at 2014-03-13. | 2014-11-04 15:06:35
Date rule based rollover from ESM4-CME to next contract occurs at 2014-06-12. | 2014-11-04 15:06:35
Date rule based rollover from ESU4-CME to next contract occurs at 2014-09-11. | 2014-11-04 15:06:35
Checking Intraday data file for symbol ESH4-CME for the date range from 2013-12-12 to 2014-03-13. | 2014-11-04 15:06:35
Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-13. | 2014-11-04 15:06:35
Checking Intraday data file for symbol ESM4-CME for the date range from 2014-03-13 to 2014-06-12. | 2014-11-04 15:06:35
Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2014-11-04 15:06:35
Checking Intraday data file for symbol ESU4-CME for the date range from 2014-06-12 to 2014-09-11. | 2014-11-04 15:06:35
Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2014-11-04 15:06:35
ESZ4-CME [CV] 1.25 Range #19 | Symbols used for continuous contract chart: | 2014-11-04 15:06:35
ESH4-CME | 2014-11-04 15:06:35
ESM4-CME | 2014-11-04 15:06:35
ESU4-CME | 2014-11-04 15:06:35
ESZ4-CME [CV] 1.25 Range #19: Checking for volume based rollover dates. | 2014-11-04 15:06:35
ESZ4-CME [CV] 1.25 Range #19: Volume based rollover from ESH4-CME to ESM4-CME occurs at 2014-03-14 | 2014-11-04 15:06:35
ESZ4-CME [CV] 1.25 Range #19: Volume based rollover from ESM4-CME to ESU4-CME occurs at 2014-06-13 | 2014-11-04 15:06:35
ESZ4-CME [CV] 1.25 Range #19: Volume based rollover from ESU4-CME to ESZ4-CME occurs at 2014-09-12 | 2014-11-04 15:06:35
Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2014-11-04 15:06:36
Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 0. | 2014-11-04 15:06:36
Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-11-04. | 2014-11-04 15:06:36
ESZ4-CME [CV] 1.25 Range #13 | Symbols used for continuous contract chart: | 2014-11-04 15:06:36
ESH4-CME | 2014-11-04 15:06:36
ESM4-CME | 2014-11-04 15:06:36
ESU4-CME | 2014-11-04 15:06:36
ESZ4-CME | 2014-11-04 15:06:36
ESZ4-CME [CV] 1.25 Range #13: Checking for volume based rollover dates. | 2014-11-04 15:06:36
ESZ4-CME [CV] 1.25 Range #13: Volume based rollover from ESH4-CME to ESM4-CME occurs at 2014-03-14 | 2014-11-04 15:06:36
ESZ4-CME [CV] 1.25 Range #13: Volume based rollover from ESM4-CME to ESU4-CME occurs at 2014-06-13 | 2014-11-04 15:06:36
ESZ4-CME [CV] 1.25 Range #13: Volume based rollover from ESU4-CME to ESZ4-CME occurs at 2014-09-12 | 2014-11-04 15:06:36
Intraday data recording state for symbol NISS-SP is set to pending. | 2014-11-04 15:06:36
HD Request # 2 | Downloading Intraday chart data for NISS-SP to the file NISS-SP.scid. Service: statscalc | 2014-11-04 15:06:36
HD Request # 2 | Download start Date-Time: 2014-11-04 13:00:05.0 | 2014-11-04 15:06:36
HD Request # 2 | Using server: ds5.sierracharts.com port 10149 | 2014-11-04 15:06:36
Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-11-04 15:06:36
Intraday data recording state for symbol TICK-NYSE is set to pending. | 2014-11-04 15:06:36
HD Request # 3 | Downloading Historical Daily chart data for ESZ14. Starting date: 2014-11-03. Service: rim | 2014-11-04 15:06:36
HD Request # 3 | Requesting historical Daily data for ESZ14 starting at 2014-11-02 | 2014-11-04 15:06:36
Intraday data recording state for symbol NISS-NYSE is set to pending. | 2014-11-04 15:06:36
Intraday data recording state for symbol NISS-TF is set to pending. | 2014-11-04 15:06:36
HTTP connection to www.sierrachart.com:80 (1068) | Closed. No error. | 2014-11-04 15:06:36
HTTP connection to www.sierrachart.com:80 (1068) | Shutdown and closed. | 2014-11-04 15:06:36
Socket (1752) | Connected. | 2014-11-04 15:06:36
HD Request # 2 | Sending historical data logon request message. | 2014-11-04 15:06:36
HD Request # 3 | Receiving historical Daily data for ESZ14 starting at 2014-11-03 | 2014-11-04 15:06:37
Writing historical Daily data for ESZ14 to the file ESZ14.dly | 2014-11-04 15:06:37
HD Request # 3 | Received 2 records from 2014-11-03 00:00:00 to 2014-11-04 00:00:00 (2.0 days) and wrote 2 records for ESZ14 | 2014-11-04 15:06:37
HD Request # 3 | Daily download COMPLETE for ESZ14. Completion time: 1s. Unique request ID: 3 | 2014-11-04 15:06:37
Removed historical data download ID 3 | 2014-11-04 15:06:37
Date rule based rollover from ESZ11 to next contract occurs at 2011-12-08. | 2014-11-04 15:06:37
Date rule based rollover from ESH12 to next contract occurs at 2012-03-08. | 2014-11-04 15:06:37
Date rule based rollover from ESM12 to next contract occurs at 2012-06-07. | 2014-11-04 15:06:37
Date rule based rollover from ESU12 to next contract occurs at 2012-09-13. | 2014-11-04 15:06:37
Date rule based rollover from ESZ12 to next contract occurs at 2012-12-13. | 2014-11-04 15:06:37
Date rule based rollover from ESH13 to next contract occurs at 2013-03-07. | 2014-11-04 15:06:37
Date rule based rollover from ESM13 to next contract occurs at 2013-06-13. | 2014-11-04 15:06:37
Date rule based rollover from ESU13 to next contract occurs at 2013-09-12. | 2014-11-04 15:06:37
Date rule based rollover from ESZ13 to next contract occurs at 2013-12-12. | 2014-11-04 15:06:37
Date rule based rollover from ESH14 to next contract occurs at 2014-03-13. | 2014-11-04 15:06:37
Date rule based rollover from ESM14 to next contract occurs at 2014-06-12. | 2014-11-04 15:06:37
Date rule based rollover from ESU14 to next contract occurs at 2014-09-11. | 2014-11-04 15:06:37
Date rule based rollover from ESZ14 to next contract occurs at 2014-12-11. | 2014-11-04 15:06:37
Checking Daily data file for symbol ESZ11 for the date range from 2011-09-08 to 2011-12-08. | 2014-11-04 15:06:37
Checking Daily data file for symbol ESH12 for the date range from 2011-12-08 to 2012-03-08. | 2014-11-04 15:06:37
Checking Daily data file for symbol ESM12 for the date range from 2012-03-08 to 2012-06-07. | 2014-11-04 15:06:37
Checking Daily data file for symbol ESU12 for the date range from 2012-06-07 to 2012-09-13. | 2014-11-04 15:06:37
Checking Daily data file for symbol ESZ12 for the date range from 2012-09-13 to 2012-12-13. | 2014-11-04 15:06:37
Checking Daily data file for symbol ESH13 for the date range from 2012-12-13 to 2013-03-07. | 2014-11-04 15:06:37
Checking Daily data file for symbol ESM13 for the date range from 2013-03-07 to 2013-06-13. | 2014-11-04 15:06:37
Checking Daily data file for symbol ESU13 for the date range from 2013-06-13 to 2013-09-12. | 2014-11-04 15:06:37
Checking Daily data file for symbol ESZ13 for the date range from 2013-09-12 to 2013-12-12. | 2014-11-04 15:06:37
Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-13. | 2014-11-04 15:06:37
Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2014-11-04 15:06:37
Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2014-11-04 15:06:37
Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-11-04. | 2014-11-04 15:06:37
ESZ14/ESZ4-CME [CV] Weekly #5 | Symbols used for continuous contract chart: | 2014-11-04 15:06:37
ESZ11 | 2014-11-04 15:06:37
ESH12 | 2014-11-04 15:06:37
ESM12 | 2014-11-04 15:06:37
ESU12 | 2014-11-04 15:06:37
ESZ12 | 2014-11-04 15:06:37
ESH13 | 2014-11-04 15:06:37
ESM13 | 2014-11-04 15:06:37
ESU13 | 2014-11-04 15:06:37
ESZ13 | 2014-11-04 15:06:37
ESH14 | 2014-11-04 15:06:37
ESM14 | 2014-11-04 15:06:37
ESU14 | 2014-11-04 15:06:37
ESZ14/ESZ4-CME [CV] Weekly #5 | Waiting for historical downloads to complete with the IDs: 3, | 2014-11-04 15:06:37
Rithmic Trading | Port for executable: 55495 | 2014-11-04 15:06:38
Listening socket (1800), port 55495 | Closed. | 2014-11-04 15:06:38
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-11-04 15:06:38
ESZ14/ESZ4-CME [CV] Weekly #5: Download is complete for all contract months in chart. Proceeding with data load. | 2014-11-04 15:06:38
ESZ14/ESZ4-CME [CV] Weekly #5: Checking for volume based rollover dates. | 2014-11-04 15:06:38
ESZ14/ESZ4-CME [CV] Weekly #5: Volume based rollover from ESZ11 to ESH12 occurs at 2011-12-09 | 2014-11-04 15:06:38
ESZ14/ESZ4-CME [CV] Weekly #5: Volume based rollover from ESH12 to ESM12 occurs at 2012-03-09 | 2014-11-04 15:06:38
ESZ14/ESZ4-CME [CV] Weekly #5: Volume based rollover from ESM12 to ESU12 occurs at 2012-06-08 | 2014-11-04 15:06:38
ESZ14/ESZ4-CME [CV] Weekly #5: Volume based rollover from ESU12 to ESZ12 occurs at 2012-09-14 | 2014-11-04 15:06:38
ESZ14/ESZ4-CME [CV] Weekly #5: Volume based rollover from ESZ12 to ESH13 occurs at 2012-12-14 | 2014-11-04 15:06:38
ESZ14/ESZ4-CME [CV] Weekly #5: Volume based rollover from ESH13 to ESM13 occurs at 2013-03-08 | 2014-11-04 15:06:38
ESZ14/ESZ4-CME [CV] Weekly #5: Volume based rollover from ESM13 to ESU13 occurs at 2013-06-14 | 2014-11-04 15:06:38
ESZ14/ESZ4-CME [CV] Weekly #5: Volume based rollover from ESU13 to ESZ13 occurs at 2013-09-13 | 2014-11-04 15:06:38
ESZ14/ESZ4-CME [CV] Weekly #5: Volume based rollover from ESZ13 to ESH14 occurs at 2013-12-13 | 2014-11-04 15:06:38
ESZ14/ESZ4-CME [CV] Weekly #5: Volume based rollover from ESH14 to ESM14 occurs at 2014-03-14 | 2014-11-04 15:06:38
ESZ14/ESZ4-CME [CV] Weekly #5: Volume based rollover from ESM14 to ESU14 occurs at 2014-06-13 | 2014-11-04 15:06:38
ESZ14/ESZ4-CME [CV] Weekly #5: Volume based rollover from ESU14 to ESZ14 occurs at 2014-09-12 | 2014-11-04 15:06:38
HD Request # 2 | Requesting Intraday data. Start Date-Time: 2014-11-04 13:00:05. Record interval: 0. Symbol: NISS-SP | 2014-11-04 15:06:38
HD Request # 2 | Decompressing data. | 2014-11-04 15:06:39
HD Request # 2 | Receiving Intraday data for NISS-SP starting at 2014-11-04 13:00:05 | 2014-11-04 15:06:39
HD Request # 2 | Timestamp of first Intraday data file record written: 2014-11-04 13:00:06 | 2014-11-04 15:06:39
Rithmic Trading | Connecting to the server 127.0.0.1. Port 55495 | 2014-11-04 15:06:40
Socket (1808) | Connected. | 2014-11-04 15:06:40
Rithmic Trading | Connected to server. | 2014-11-04 15:06:40
Rithmic Trading | Sending logon request message. | 2014-11-04 15:06:40
Rithmic Trading | Starting the connection process to data and trading service. | 2014-11-04 15:06:40
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2014-11-04 15:06:40
Rithmic Trading | Connecting to Rithmic 01 US server. | 2014-11-04 15:06:40
Socket (1752) | Shutdown and closed. | 2014-11-04 15:06:40
HD Request # 2 | Historical data for NISS-SP is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2014-11-04 15:06:40
The network socket for historical data has been closed. | 2014-11-04 15:06:40
HD Request # 2 | Received 5957 records from 2014-11-04 13:00:05 to 2014-11-04 15:06:33 (2.1 hours) and wrote 5956 records for NISS-SP | 2014-11-04 15:06:40
HD Request # 2 | Intraday download COMPLETE for NISS-SP. Completion time: 4s. Unique request ID: 1 | 2014-11-04 15:06:40
Removed historical data download ID 1 | 2014-11-04 15:06:40
HD Request # 4 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc | 2014-11-04 15:06:40
HD Request # 4 | Download start Date-Time: 2014-11-04 13:00:05.0 | 2014-11-04 15:06:40
HD Request # 4 | Using server: ds3.sierracharts.com port 10149 | 2014-11-04 15:06:40
Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-11-04 15:06:40
Chart #18 has tagged chart #4 for full recalculation. Chartbook: ES - VZones.cht | 2014-11-04 15:06:40
Chart #10 has tagged chart #12 for full recalculation. Chartbook: ES - VZones.cht | 2014-11-04 15:06:40
Chart #12 is performing a full recalculation because it has been tagged. Chartbook: ES - VZones.cht | 2014-11-04 15:06:40
Chart #4 is performing a full recalculation because it has been tagged. Chartbook: ES - VZones.cht | 2014-11-04 15:06:41
Socket (1760) | Connected. | 2014-11-04 15:06:41
HD Request # 4 | Sending historical data logon request message. | 2014-11-04 15:06:41
HD Request # 4 | Requesting Intraday data. Start Date-Time: 2014-11-04 13:00:05. Record interval: 0. Symbol: TICK-NYSE | 2014-11-04 15:06:42
HD Request # 4 | Decompressing data. | 2014-11-04 15:06:43
HD Request # 4 | Receiving Intraday data for TICK-NYSE starting at 2014-11-04 13:00:05 | 2014-11-04 15:06:43
HD Request # 4 | Timestamp of first Intraday data file record written: 2014-11-04 13:00:06 | 2014-11-04 15:06:43
Socket (1760) | Shutdown and closed. | 2014-11-04 15:06:45
HD Request # 4 | Historical data for TICK-NYSE is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2014-11-04 15:06:45
The network socket for historical data has been closed. | 2014-11-04 15:06:45
HD Request # 4 | Received 5959 records from 2014-11-04 13:00:05 to 2014-11-04 15:06:40 (2.1 hours) and wrote 5958 records for TICK-NYSE | 2014-11-04 15:06:45
HD Request # 4 | Intraday download COMPLETE for TICK-NYSE. Completion time: 5s. Unique request ID: 2 | 2014-11-04 15:06:45
Removed historical data download ID 2 | 2014-11-04 15:06:45
HD Request # 5 | Downloading Intraday chart data for NISS-NYSE to the file NISS-NYSE.scid. Service: statscalc | 2014-11-04 15:06:45
HD Request # 5 | Download start Date-Time: 2014-11-04 13:00:05.0 | 2014-11-04 15:06:45
HD Request # 5 | Using server: ds4.sierracharts.com port 10149 | 2014-11-04 15:06:45
Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-11-04 15:06:45
Chart #8 has tagged chart #12 for full recalculation. Chartbook: ES - VZones.cht | 2014-11-04 15:06:46
Chart #6 has tagged chart #4 for full recalculation. Chartbook: ES - VZones.cht | 2014-11-04 15:06:46
Chart #12 is performing a full recalculation because it has been tagged. Chartbook: ES - VZones.cht | 2014-11-04 15:06:46
Chart #4 is performing a full recalculation because it has been tagged. Chartbook: ES - VZones.cht | 2014-11-04 15:06:46
Socket (1076) | Connected. | 2014-11-04 15:06:46
HD Request # 5 | Sending historical data logon request message. | 2014-11-04 15:06:46
HD Request # 5 | Requesting Intraday data. Start Date-Time: 2014-11-04 13:00:05. Record interval: 0. Symbol: NISS-NYSE | 2014-11-04 15:06:47
HD Request # 5 | Decompressing data. | 2014-11-04 15:06:48
HD Request # 5 | Receiving Intraday data for NISS-NYSE starting at 2014-11-04 13:00:05 | 2014-11-04 15:06:48
HD Request # 5 | Timestamp of first Intraday data file record written: 2014-11-04 13:00:06 | 2014-11-04 15:06:48
Rithmic Trading | Server Alert: Market Data Connection Opened | 2014-11-04 15:06:49
Socket (1076) | Shutdown and closed. | 2014-11-04 15:06:49
The network socket for historical data has been closed. | 2014-11-04 15:06:49
HD Request # 5 | Historical data for NISS-NYSE is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2014-11-04 15:06:49
HD Request # 5 | Received 5961 records from 2014-11-04 13:00:05 to 2014-11-04 15:06:46 (2.1 hours) and wrote 5960 records for NISS-NYSE | 2014-11-04 15:06:49
HD Request # 5 | Intraday download COMPLETE for NISS-NYSE. Completion time: 4s. Unique request ID: 4 | 2014-11-04 15:06:49
Removed historical data download ID 4 | 2014-11-04 15:06:49
HD Request # 6 | Downloading Intraday chart data for NISS-TF to the file NISS-TF.scid. Service: statscalc | 2014-11-04 15:06:49
HD Request # 6 | Download start Date-Time: 2014-11-04 13:00:05.0 | 2014-11-04 15:06:49
HD Request # 6 | Using server: ds5.sierracharts.com port 10149 | 2014-11-04 15:06:49
Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-11-04 15:06:49
Rithmic Trading | Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2014-11-04 15:06:49
Socket (1688) | Connected. | 2014-11-04 15:06:49
HD Request # 6 | Sending historical data logon request message. | 2014-11-04 15:06:49
HD Request # 6 | Requesting Intraday data. Start Date-Time: 2014-11-04 13:00:05. Record interval: 0. Symbol: NISS-TF | 2014-11-04 15:06:49
HD Request # 6 | Decompressing data. | 2014-11-04 15:06:50
HD Request # 6 | Receiving Intraday data for NISS-TF starting at 2014-11-04 13:00:05 | 2014-11-04 15:06:50
HD Request # 6 | Timestamp of first Intraday data file record written: 2014-11-04 13:00:06 | 2014-11-04 15:06:50
Rithmic Trading | Server Alert: Trading System Connection Opened | 2014-11-04 15:06:50
Socket (1688) | Shutdown and closed. | 2014-11-04 15:06:50
HD Request # 6 | Historical data for NISS-TF is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2014-11-04 15:06:50
The network socket for historical data has been closed. | 2014-11-04 15:06:50
HD Request # 6 | Received 5962 records from 2014-11-04 13:00:05 to 2014-11-04 15:06:49 (2.1 hours) and wrote 5961 records for NISS-TF | 2014-11-04 15:06:50
HD Request # 6 | Intraday download COMPLETE for NISS-TF. Completion time: 0s. Unique request ID: 5 | 2014-11-04 15:06:50
Removed historical data download ID 5 | 2014-11-04 15:06:50
Rithmic Trading | Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2014-11-04 15:06:50
Rithmic Trading | subscribeTradeRoute error. Error code: API_ALREADY_EXISTS | 2014-11-04 15:06:50
Rithmic Trading | Server Alert: PnL Connection Opened | 2014-11-04 15:06:50
Rithmic Trading | Server Alert: PnL Connection Login Complete. Result text: "ok" | 2014-11-04 15:06:50
Rithmic Trading | Server Alert: Intraday History Connection Opened | 2014-11-04 15:06:51
Rithmic Trading | Server Alert: Intraday History Connection Login Complete. Result text: "ok" | 2014-11-04 15:06:51
Rithmic Trading | Server Info - Server Name: SC DTC Bridge. | 2014-11-04 15:06:52
Rithmic Trading | Server protocol version: 4. Client protocol version: 4. There is a protocol match. | 2014-11-04 15:06:52
Rithmic Trading | Successfully connected. IB='OptimusFutures'. | 2014-11-04 15:06:52
Rithmic Trading | Trading is supported. | 2014-11-04 15:06:52
Rithmic Trading | Order cancel and replace is supported. | 2014-11-04 15:06:52
Rithmic Trading | OCO Orders supported. | 2014-11-04 15:06:52
Rithmic Trading | Starting real-time market data updates for: ESZ4-CME. ID: 1 | 2014-11-04 15:06:52
Intraday data recording state for symbol ESZ4-CME is set to pending. | 2014-11-04 15:06:52
HD Request # 7 | Downloading Intraday chart data for ESZ4-CME to the file ESZ4-CME.scid. Service: rim | 2014-11-04 15:06:52
HD Request # 7 | Download start Date-Time: 2014-11-04 13:00:05.0 | 2014-11-04 15:06:52
HD Request # 7 | Using server: ds3.sierracharts.com port 10149 | 2014-11-04 15:06:52
Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-11-04 15:06:52
SC Market Stats | Starting real-time market data updates for: NISS-NYSE. ID: 2 | 2014-11-04 15:06:52
SC Market Stats | Connecting to the server ds4.sierracharts.com. Port 443 | 2014-11-04 15:06:52
Intraday data recording state for symbol NISS-NYSE is set to pending. | 2014-11-04 15:06:52
SC Market Stats | Starting real-time market data updates for: NISS-TF. ID: 3 | 2014-11-04 15:06:52
Intraday data recording state for symbol NISS-TF is set to pending. | 2014-11-04 15:06:52
Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-11-04 15:06:52
Socket (1652) | Connected. | 2014-11-04 15:06:52
SC Market Stats | Connected to server. | 2014-11-04 15:06:52
SC Market Stats | Sending logon request message. | 2014-11-04 15:06:52
SC Market Stats | Starting real-time market data updates for: NISS-SP. ID: 4 | 2014-11-04 15:06:52
Intraday data recording state for symbol NISS-SP is set to pending. | 2014-11-04 15:06:52
Socket (1688) | Connected. | 2014-11-04 15:06:52
HD Request # 7 | Sending historical data logon request message. | 2014-11-04 15:06:52
HD Request # 7 | Requesting Intraday data. Start Date-Time: 2014-11-04 13:00:05. Record interval: 0. Symbol: ESZ4-CME | 2014-11-04 15:06:52
SC Market Stats | Starting real-time market data updates for: TICK-NYSE. ID: 5 | 2014-11-04 15:06:52
Intraday data recording state for symbol TICK-NYSE is set to pending. | 2014-11-04 15:06:52
HD Request # 7 | Decompressing data. | 2014-11-04 15:06:52
HD Request # 7 | Receiving Intraday data for ESZ4-CME starting at 2014-11-04 13:00:05 | 2014-11-04 15:06:52
Rithmic Trading | Starting real-time market data updates for: ZBZ4-CBOT. ID: 6 | 2014-11-04 15:06:52
Intraday data recording state for symbol ZBZ4-CBOT is set to pending. | 2014-11-04 15:06:52
HD Request # 7 | Timestamp of first Intraday data file record written: 2014-11-04 13:00:05 | 2014-11-04 15:06:52
Socket (1688) | Shutdown and closed. | 2014-11-04 15:06:53
The network socket for historical data has been closed. | 2014-11-04 15:06:53
HD Request # 7 | Received 11179 records from 2014-11-04 13:00:05 to 2014-11-04 15:06:40 (2.1 hours) and wrote 11146 records for ESZ4-CME | 2014-11-04 15:06:53
HD Request # 7 | Intraday download COMPLETE for ESZ4-CME. Completion time: 1s. Unique request ID: 6 | 2014-11-04 15:06:53
Removed historical data download ID 6 | 2014-11-04 15:06:53
Real-time Intraday chart data file updates started for ESZ4-CME | 2014-11-04 15:06:53
HD Request # 8 | Downloading Intraday chart data for NISS-NYSE to the file NISS-NYSE.scid. Service: statscalc | 2014-11-04 15:06:53
HD Request # 8 | Download start Date-Time: 2014-11-04 15:06:46.0 | 2014-11-04 15:06:53
HD Request # 8 | Using server: ds5.sierracharts.com port 10149 | 2014-11-04 15:06:53
Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-11-04 15:06:53
Socket (1648) | Connected. | 2014-11-04 15:06:53
HD Request # 8 | Sending historical data logon request message. | 2014-11-04 15:06:53
SC Market Stats | Server Info - Server Name: . | 2014-11-04 15:06:53
SC Market Stats | Server protocol version: 4. Client protocol version: 4. There is a protocol match. | 2014-11-04 15:06:53
SC Market Stats | Successfully connected. | 2014-11-04 15:06:53
SC Market Stats | Restarting real-time data updates for symbol: NISS-NYSE | 2014-11-04 15:06:53
SC Market Stats | Restarting real-time data updates for symbol: NISS-SP | 2014-11-04 15:06:53
SC Market Stats | Restarting real-time data updates for symbol: NISS-TF | 2014-11-04 15:06:53
SC Market Stats | Restarting real-time data updates for symbol: TICK-NYSE | 2014-11-04 15:06:53
HD Request # 8 | Requesting Intraday data. Start Date-Time: 2014-11-04 15:06:46. Record interval: 0. Symbol: NISS-NYSE | 2014-11-04 15:06:53
HD Request # 8 | Decompressing data. | 2014-11-04 15:06:53
HD Request # 8 | Receiving Intraday data for NISS-NYSE starting at 2014-11-04 15:06:46 | 2014-11-04 15:06:53
HD Request # 8 | Timestamp of first Intraday data file record written: 2014-11-04 15:06:49 | 2014-11-04 15:06:53
Socket (1648) | Shutdown and closed. | 2014-11-04 15:06:53
HD Request # 8 | Received 3 records from 2014-11-04 15:06:46 to 2014-11-04 15:06:52 (6.0 seconds) and wrote 2 records for NISS-NYSE | 2014-11-04 15:06:53
HD Request # 8 | Intraday download COMPLETE for NISS-NYSE. Completion time: 0s. Unique request ID: 7 | 2014-11-04 15:06:53
Removed historical data download ID 7 | 2014-11-04 15:06:53
Real-time Intraday chart data file updates started for NISS-NYSE | 2014-11-04 15:06:53
HD Request # 9 | Downloading Intraday chart data for NISS-TF to the file NISS-TF.scid. Service: statscalc | 2014-11-04 15:06:53
HD Request # 9 | Download start Date-Time: 2014-11-04 15:06:49.0 | 2014-11-04 15:06:53
HD Request # 9 | Using server: ds3.sierracharts.com port 10149 | 2014-11-04 15:06:53
Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-11-04 15:06:53
Socket (1740) | Connected. | 2014-11-04 15:06:53
HD Request # 9 | Sending historical data logon request message. | 2014-11-04 15:06:53
HD Request # 9 | Requesting Intraday data. Start Date-Time: 2014-11-04 15:06:49. Record interval: 0. Symbol: NISS-TF | 2014-11-04 15:06:53
HD Request # 9 | Decompressing data. | 2014-11-04 15:06:53
HD Request # 9 | Receiving Intraday data for NISS-TF starting at 2014-11-04 15:06:49 | 2014-11-04 15:06:53
HD Request # 9 | Timestamp of first Intraday data file record written: 2014-11-04 15:06:52 | 2014-11-04 15:06:53
Socket (1740) | Shutdown and closed. | 2014-11-04 15:06:53
HD Request # 9 | Received 2 records from 2014-11-04 15:06:49 to 2014-11-04 15:06:52 (3.0 seconds) and wrote 1 record for NISS-TF | 2014-11-04 15:06:53
HD Request # 9 | Intraday download COMPLETE for NISS-TF. Completion time: 0s. Unique request ID: 8 | 2014-11-04 15:06:53
Removed historical data download ID 8 | 2014-11-04 15:06:53
Real-time Intraday chart data file updates started for NISS-TF | 2014-11-04 15:06:53
HD Request # 10 | Downloading Intraday chart data for NISS-SP to the file NISS-SP.scid. Service: statscalc | 2014-11-04 15:06:53
HD Request # 10 | Download start Date-Time: 2014-11-04 15:06:33.0 | 2014-11-04 15:06:53
HD Request # 10 | Using server: ds4.sierracharts.com port 10149 | 2014-11-04 15:06:53
Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-11-04 15:06:53
Socket (1632) | Connected. | 2014-11-04 15:06:53
HD Request # 10 | Sending historical data logon request message. | 2014-11-04 15:06:53
HD Request # 10 | Requesting Intraday data. Start Date-Time: 2014-11-04 15:06:33. Record interval: 0. Symbol: NISS-SP | 2014-11-04 15:06:53
HD Request # 10 | Decompressing data. | 2014-11-04 15:06:53
HD Request # 10 | Receiving Intraday data for NISS-SP starting at 2014-11-04 15:06:33 | 2014-11-04 15:06:53
HD Request # 10 | Timestamp of first Intraday data file record written: 2014-11-04 15:06:39 | 2014-11-04 15:06:53
Socket (1632) | Shutdown and closed. | 2014-11-04 15:06:53
HD Request # 10 | Received 7 records from 2014-11-04 15:06:33 to 2014-11-04 15:06:52 (19.0 seconds) and wrote 6 records for NISS-SP | 2014-11-04 15:06:53
HD Request # 10 | Intraday download COMPLETE for NISS-SP. Completion time: 0s. Unique request ID: 9 | 2014-11-04 15:06:53
Removed historical data download ID 9 | 2014-11-04 15:06:53
Real-time Intraday chart data file updates started for NISS-SP | 2014-11-04 15:06:53
HD Request # 11 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc | 2014-11-04 15:06:53
HD Request # 11 | Download start Date-Time: 2014-11-04 15:06:40.0 | 2014-11-04 15:06:53
HD Request # 11 | Using server: ds5.sierracharts.com port 10149 | 2014-11-04 15:06:53
Socket (1640) | Connected. | 2014-11-04 15:06:54
HD Request # 11 | Sending historical data logon request message. | 2014-11-04 15:06:54
Chart #18 has tagged chart #4 for full recalculation. Chartbook: ES - VZones.cht | 2014-11-04 15:06:54
HD Request # 11 | Requesting Intraday data. Start Date-Time: 2014-11-04 15:06:40. Record interval: 0. Symbol: TICK-NYSE | 2014-11-04 15:06:54
HD Request # 11 | Decompressing data. | 2014-11-04 15:06:54
HD Request # 11 | Receiving Intraday data for TICK-NYSE starting at 2014-11-04 15:06:40 | 2014-11-04 15:06:54
HD Request # 11 | Timestamp of first Intraday data file record written: 2014-11-04 15:06:43 | 2014-11-04 15:06:54
Socket (1640) | Shutdown and closed. | 2014-11-04 15:06:54
The network socket for historical data has been closed. | 2014-11-04 15:06:54
HD Request # 11 | Received 5 records from 2014-11-04 15:06:40 to 2014-11-04 15:06:52 (12.0 seconds) and wrote 4 records for TICK-NYSE | 2014-11-04 15:06:54
HD Request # 11 | Intraday download COMPLETE for TICK-NYSE. Completion time: 1s. Unique request ID: 10 | 2014-11-04 15:06:54
Removed historical data download ID 10 | 2014-11-04 15:06:54
Real-time Intraday chart data file updates started for TICK-NYSE | 2014-11-04 15:06:54
HD Request # 12 | Downloading Intraday chart data for ZBZ4-CBOT to the file ZBZ4-CBOT.scid. Service: rim | 2014-11-04 15:06:54
HD Request # 12 | Download start Date-Time: 2014-11-04 13:00:05.0 | 2014-11-04 15:06:54
HD Request # 12 | Using server: ds3.sierracharts.com port 10149 | 2014-11-04 15:06:54
Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-11-04 15:06:54
Chart #10 has tagged chart #12 for full recalculation. Chartbook: ES - VZones.cht | 2014-11-04 15:06:54
Chart #8 has tagged chart #12 for full recalculation. Chartbook: ES - VZones.cht | 2014-11-04 15:06:54
Chart #6 has tagged chart #4 for full recalculation. Chartbook: ES - VZones.cht | 2014-11-04 15:06:54
Chart #12 is performing a full recalculation because it has been tagged. Chartbook: ES - VZones.cht | 2014-11-04 15:06:54
Socket (1076) | Connected. | 2014-11-04 15:06:54
HD Request # 12 | Sending historical data logon request message. | 2014-11-04 15:06:54
HD Request # 12 | Requesting Intraday data. Start Date-Time: 2014-11-04 13:00:05. Record interval: 0. Symbol: ZBZ4-CBOT | 2014-11-04 15:06:54
HD Request # 12 | Decompressing data. | 2014-11-04 15:06:54
HD Request # 12 | Receiving Intraday data for ZBZ4-CBOT starting at 2014-11-04 13:00:05 | 2014-11-04 15:06:54
HD Request # 12 | Timestamp of first Intraday data file record written: 2014-11-04 13:00:05 | 2014-11-04 15:06:54
Chart #4 is performing a full recalculation because it has been tagged. Chartbook: ES - VZones.cht | 2014-11-04 15:06:54
Socket (1076) | Shutdown and closed. | 2014-11-04 15:06:54
HD Request # 12 | Received 1199 records from 2014-11-04 13:00:05 to 2014-11-04 15:06:14 (2.1 hours) and wrote 1195 records for ZBZ4-CBOT | 2014-11-04 15:06:54
HD Request # 12 | Intraday download COMPLETE for ZBZ4-CBOT. Completion time: 0s. Unique request ID: 11 | 2014-11-04 15:06:54
Removed historical data download ID 11 | 2014-11-04 15:06:54
Real-time Intraday chart data file updates started for ZBZ4-CBOT | 2014-11-04 15:06:54
Rithmic Trading | Requesting Trade Positions data. | 2014-11-04 15:06:57
Intraday data recording state for symbol ESZ4-CME is set to pending. | 2014-11-04 15:08:40
HD Request # 13 | Downloading Intraday chart data for ESZ4-CME to the file ESZ4-CME.scid. Service: rim | 2014-11-04 15:08:40
HD Request # 13 | Download start Date-Time: 2014-09-08 17:00:00.0 | 2014-11-04 15:08:40
HD Request # 13 | Using server: ds4.sierracharts.com port 10149 | 2014-11-04 15:08:40
Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-11-04 15:08:40
Socket (1632) | Connected. | 2014-11-04 15:08:40
HD Request # 13 | Sending historical data logon request message. | 2014-11-04 15:08:40
HD Request # 13 | Requesting Intraday data. Start Date-Time: 2014-09-08 17:00:00. Record interval: 0. Symbol: ESZ4-CME | 2014-11-04 15:08:40
HD Request # 13 | Decompressing data. | 2014-11-04 15:08:40
HD Request # 13 | Receiving Intraday data for ESZ4-CME starting at 2014-09-08 17:03:46 | 2014-11-04 15:08:40
HD Request # 13 | Timestamp of first Intraday data file record written: 2014-09-08 17:03:46 | 2014-11-04 15:08:40
ESZ4-CME [CV] 1.25 Range #19 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 15:00:12. Next Bar Date Time: 2014-11-04 06:30:56. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-04 15:10:01
ESZ4-CME [CV] 30 Min #23 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 15:00:00. Next Bar Date Time: 2014-11-04 06:30:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-04 15:10:01
ESZ4-CME [CV] 1 Min #4 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 13:14:00. Next Bar Date Time: 2014-11-04 06:30:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-04 15:10:01
ESZ4-CME [CV] 15 Min #24 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 15:00:00. Next Bar Date Time: 2014-11-04 06:30:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-04 15:10:01
ESZ4-CME [CV] 5 Min #12 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 13:10:00. Next Bar Date Time: 2014-11-04 06:30:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-04 15:10:01
ESZ4-CME [CV] 1 Min #3 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 15:08:00. Next Bar Date Time: 2014-11-04 06:30:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-04 15:10:01
ESZ4-CME [CV] 10 Sec #15 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 15:08:20. Next Bar Date Time: 2014-11-04 06:30:50. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-04 15:10:01
ESZ4-CME [CV] 1.25 Range #13 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 15:00:12. Next Bar Date Time: 2014-11-04 06:30:56. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-04 15:10:01
ESZ4-CME [CV] 1.25 Range #25 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 15:00:12. Next Bar Date Time: 2014-11-04 06:30:56. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-04 15:10:01
ESZ4-CME 15 Min #11 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 15:00:00. Next Bar Date Time: 2014-11-04 06:30:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-04 15:10:01
Socket (1632) | Shutdown and closed. | 2014-11-04 15:10:02
The network socket for historical data has been closed. | 2014-11-04 15:10:02
HD Request # 13 | Received 23226851 records from 2014-09-08 17:03:46 to 2014-11-04 15:09:52 (57.0 days) and wrote 23226851 records for ESZ4-CME | 2014-11-04 15:10:02
HD Request # 13 | Intraday download COMPLETE for ESZ4-CME. Completion time: 1m 22s. Unique request ID: 12 | 2014-11-04 15:10:02
Removed historical data download ID 12 | 2014-11-04 15:10:02
Real-time Intraday chart data file updates started for ESZ4-CME | 2014-11-04 15:10:02
ESZ4-CME [CV] 1 Min #2 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 15:08:00. Next Bar Date Time: 2014-11-04 06:30:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-04 15:10:02
ESZ4-CME [C] 1 Min #20 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 15:08:00. Next Bar Date Time: 2014-11-04 06:30:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-04 15:10:02
ESZ4-CME [CV] 2.50 Range #22 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 15:00:14. Next Bar Date Time: 2014-11-04 06:30:56. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-04 15:10:02
Intraday data recording state for symbol ESZ4-CME is set to pending. | 2014-11-04 15:12:25
Reloading all charts with filename: ESZ4-CME.scid | 2014-11-04 15:12:25
Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2014-11-04 15:12:25
Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 0. | 2014-11-04 15:12:25
Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-11-04. | 2014-11-04 15:12:25
ESZ4-CME [CV] 5 Min #12 | Symbols used for continuous contract chart: | 2014-11-04 15:12:25
ESZ4-CME | 2014-11-04 15:12:25
ESZ4-CME [CV] 5 Min #12: Checking for volume based rollover dates. | 2014-11-04 15:12:25
Date rule based rollover from ESU2-CME to next contract occurs at 2012-09-13. | 2014-11-04 15:12:25
Date rule based rollover from ESZ2-CME to next contract occurs at 2012-12-13. | 2014-11-04 15:12:25
Date rule based rollover from ESH3-CME to next contract occurs at 2013-03-07. | 2014-11-04 15:12:25
Date rule based rollover from ESM3-CME to next contract occurs at 2013-06-13. | 2014-11-04 15:12:25
Date rule based rollover from ESU3-CME to next contract occurs at 2013-09-12. | 2014-11-04 15:12:25
Date rule based rollover from ESZ3-CME to next contract occurs at 2013-12-12. | 2014-11-04 15:12:25
Date rule based rollover from ESH4-CME to next contract occurs at 2014-03-13. | 2014-11-04 15:12:25
Date rule based rollover from ESM4-CME to next contract occurs at 2014-06-12. | 2014-11-04 15:12:25
Date rule based rollover from ESU4-CME to next contract occurs at 2014-09-11. | 2014-11-04 15:12:25
Checking Intraday data file for symbol ESU2-CME for the date range from 2012-06-07 to 2012-09-13. | 2014-11-04 15:12:25
Checking Daily data file for symbol ESU12 for the date range from 2012-06-07 to 2012-09-13. | 2014-11-04 15:12:25
Checking Intraday data file for symbol ESZ2-CME for the date range from 2012-09-13 to 2012-12-13. | 2014-11-04 15:12:25
Checking Daily data file for symbol ESZ12 for the date range from 2012-09-13 to 2012-12-13. | 2014-11-04 15:12:25
Checking Intraday data file for symbol ESH3-CME for the date range from 2012-12-13 to 2013-03-07. | 2014-11-04 15:12:25
Checking Daily data file for symbol ESH13 for the date range from 2012-12-13 to 2013-03-07. | 2014-11-04 15:12:25
Checking Intraday data file for symbol ESM3-CME for the date range from 2013-03-07 to 2013-06-13. | 2014-11-04 15:12:25
Checking Daily data file for symbol ESM13 for the date range from 2013-03-07 to 2013-06-13. | 2014-11-04 15:12:25
Checking Intraday data file for symbol ESU3-CME for the date range from 2013-06-13 to 2013-09-12. | 2014-11-04 15:12:25
Checking Daily data file for symbol ESU13 for the date range from 2013-06-13 to 2013-09-12. | 2014-11-04 15:12:25
Checking Intraday data file for symbol ESZ3-CME for the date range from 2013-09-12 to 2013-12-12. | 2014-11-04 15:12:25
Checking Daily data file for symbol ESZ13 for the date range from 2013-09-12 to 2013-12-12. | 2014-11-04 15:12:25
Checking Intraday data file for symbol ESH4-CME for the date range from 2013-12-12 to 2014-03-13. | 2014-11-04 15:12:25
Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-13. | 2014-11-04 15:12:25
Checking Intraday data file for symbol ESM4-CME for the date range from 2014-03-13 to 2014-06-12. | 2014-11-04 15:12:25
Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2014-11-04 15:12:25
Checking Intraday data file for symbol ESU4-CME for the date range from 2014-06-12 to 2014-09-11. | 2014-11-04 15:12:25
Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Min #3 | Symbols used for continuous contract chart: | 2014-11-04 15:12:25
ESU2-CME | 2014-11-04 15:12:25
ESZ2-CME | 2014-11-04 15:12:25
ESH3-CME | 2014-11-04 15:12:25
ESM3-CME | 2014-11-04 15:12:25
ESU3-CME | 2014-11-04 15:12:25
ESZ3-CME | 2014-11-04 15:12:25
ESH4-CME | 2014-11-04 15:12:25
ESM4-CME | 2014-11-04 15:12:25
ESU4-CME | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Min #3: Checking for volume based rollover dates. | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Min #3: Volume based rollover from ESU2-CME to ESZ2-CME occurs at 2012-09-14 | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Min #3: Volume based rollover from ESZ2-CME to ESH3-CME occurs at 2012-12-14 | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Min #3: Volume based rollover from ESH3-CME to ESM3-CME occurs at 2013-03-08 | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Min #3: Volume based rollover from ESM3-CME to ESU3-CME occurs at 2013-06-14 | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Min #3: Volume based rollover from ESU3-CME to ESZ3-CME occurs at 2013-09-13 | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Min #3: Volume based rollover from ESZ3-CME to ESH4-CME occurs at 2013-12-13 | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Min #3: Volume based rollover from ESH4-CME to ESM4-CME occurs at 2014-03-14 | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Min #3: Volume based rollover from ESM4-CME to ESU4-CME occurs at 2014-06-13 | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Min #3: Volume based rollover from ESU4-CME to ESZ4-CME occurs at 2014-09-12 | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Min #2 | Symbols used for continuous contract chart: | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Min #2: Checking for volume based rollover dates. | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Min #2: Volume based rollover from ESH4-CME to ESM4-CME occurs at 2014-03-14 | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Min #2: Volume based rollover from ESM4-CME to ESU4-CME occurs at 2014-06-13 | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Min #2: Volume based rollover from ESU4-CME to ESZ4-CME occurs at 2014-09-12 | 2014-11-04 15:12:25
Limiting the number of days back for the continuous futures chart to 4.9993155 years based on the account type. | 2014-11-04 15:12:25
Date rule based rollover from ESZ9-CME to next contract occurs at 2009-12-10. | 2014-11-04 15:12:25
Date rule based rollover from ESH0-CME to next contract occurs at 2010-03-11. | 2014-11-04 15:12:25
Date rule based rollover from ESM0-CME to next contract occurs at 2010-06-10. | 2014-11-04 15:12:25
Date rule based rollover from ESU0-CME to next contract occurs at 2010-09-09. | 2014-11-04 15:12:25
Date rule based rollover from ESZ0-CME to next contract occurs at 2010-12-09. | 2014-11-04 15:12:25
Date rule based rollover from ESH1-CME to next contract occurs at 2011-03-10. | 2014-11-04 15:12:25
Date rule based rollover from ESM1-CME to next contract occurs at 2011-06-09. | 2014-11-04 15:12:25
Date rule based rollover from ESU1-CME to next contract occurs at 2011-09-08. | 2014-11-04 15:12:25
Date rule based rollover from ESZ1-CME to next contract occurs at 2011-12-08. | 2014-11-04 15:12:25
Date rule based rollover from ESH2-CME to next contract occurs at 2012-03-08. | 2014-11-04 15:12:25
Date rule based rollover from ESM2-CME to next contract occurs at 2012-06-07. | 2014-11-04 15:12:25
Intraday data file for ESZ9-CME exists and is empty. Skipping Intraday data download. | 2014-11-04 15:12:25
Checking Daily data file for symbol ESZ09 for the date range from 2009-09-10 to 2009-12-10. | 2014-11-04 15:12:25
Intraday data file for ESH0-CME exists and is empty. Skipping Intraday data download. | 2014-11-04 15:12:25
Checking Daily data file for symbol ESH10 for the date range from 2009-12-10 to 2010-03-11. | 2014-11-04 15:12:25
Intraday data file for ESM0-CME exists and is empty. Skipping Intraday data download. | 2014-11-04 15:12:25
Checking Daily data file for symbol ESM10 for the date range from 2010-03-11 to 2010-06-10. | 2014-11-04 15:12:25
Intraday data file for ESU0-CME exists and is empty. Skipping Intraday data download. | 2014-11-04 15:12:25
Checking Daily data file for symbol ESU10 for the date range from 2010-06-10 to 2010-09-09. | 2014-11-04 15:12:25
Intraday data file for ESZ0-CME exists and is empty. Skipping Intraday data download. | 2014-11-04 15:12:25
Checking Daily data file for symbol ESZ10 for the date range from 2010-09-09 to 2010-12-09. | 2014-11-04 15:12:25
Checking Intraday data file for symbol ESH1-CME for the date range from 2010-12-09 to 2011-03-10. | 2014-11-04 15:12:25
Checking Daily data file for symbol ESH11 for the date range from 2010-12-09 to 2011-03-10. | 2014-11-04 15:12:25
Checking Intraday data file for symbol ESM1-CME for the date range from 2011-03-10 to 2011-06-09. | 2014-11-04 15:12:25
Checking Daily data file for symbol ESM11 for the date range from 2011-03-10 to 2011-06-09. | 2014-11-04 15:12:25
Checking Intraday data file for symbol ESU1-CME for the date range from 2011-06-09 to 2011-09-08. | 2014-11-04 15:12:25
Checking Daily data file for symbol ESU11 for the date range from 2011-06-09 to 2011-09-08. | 2014-11-04 15:12:25
Checking Intraday data file for symbol ESZ1-CME for the date range from 2011-09-08 to 2011-12-08. | 2014-11-04 15:12:25
Checking Daily data file for symbol ESZ11 for the date range from 2011-09-08 to 2011-12-08. | 2014-11-04 15:12:25
Checking Intraday data file for symbol ESH2-CME for the date range from 2011-12-08 to 2012-03-08. | 2014-11-04 15:12:25
Checking Daily data file for symbol ESH12 for the date range from 2011-12-08 to 2012-03-08. | 2014-11-04 15:12:25
Checking Intraday data file for symbol ESM2-CME for the date range from 2012-03-08 to 2012-06-07. | 2014-11-04 15:12:25
Checking Daily data file for symbol ESM12 for the date range from 2012-03-08 to 2012-06-07. | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Day #9 | Symbols used for continuous contract chart: | 2014-11-04 15:12:25
ESZ9-CME | 2014-11-04 15:12:25
ESH0-CME | 2014-11-04 15:12:25
ESM0-CME | 2014-11-04 15:12:25
ESU0-CME | 2014-11-04 15:12:25
ESZ0-CME | 2014-11-04 15:12:25
ESH1-CME | 2014-11-04 15:12:25
ESM1-CME | 2014-11-04 15:12:25
ESU1-CME | 2014-11-04 15:12:25
ESZ1-CME | 2014-11-04 15:12:25
ESH2-CME | 2014-11-04 15:12:25
ESM2-CME | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Day #9: Checking for volume based rollover dates. | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESZ9-CME to ESH0-CME occurs at 2009-12-11 | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESH0-CME to ESM0-CME occurs at 2010-03-12 | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESM0-CME to ESU0-CME occurs at 2010-06-11 | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESU0-CME to ESZ0-CME occurs at 2010-09-10 | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESZ0-CME to ESH1-CME occurs at 2010-12-10 | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESH1-CME to ESM1-CME occurs at 2011-03-11 | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESM1-CME to ESU1-CME occurs at 2011-06-10 | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESU1-CME to ESZ1-CME occurs at 2011-09-09 | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESZ1-CME to ESH2-CME occurs at 2011-12-09 | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESH2-CME to ESM2-CME occurs at 2012-03-09 | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESM2-CME to ESU2-CME occurs at 2012-06-08 | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESU2-CME to ESZ2-CME occurs at 2012-09-14 | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESZ2-CME to ESH3-CME occurs at 2012-12-14 | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESH3-CME to ESM3-CME occurs at 2013-03-08 | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESM3-CME to ESU3-CME occurs at 2013-06-14 | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESU3-CME to ESZ3-CME occurs at 2013-09-13 | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESZ3-CME to ESH4-CME occurs at 2013-12-13 | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESH4-CME to ESM4-CME occurs at 2014-03-14 | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESM4-CME to ESU4-CME occurs at 2014-06-13 | 2014-11-04 15:12:25
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESU4-CME to ESZ4-CME occurs at 2014-09-12 | 2014-11-04 15:12:25
ESZ4-CME [CV] 10 Sec #15 | Symbols used for continuous contract chart: | 2014-11-04 15:12:25
ESZ4-CME [CV] 10 Sec #15: Checking for volume based rollover dates. | 2014-11-04 15:12:25
ESZ4-CME [CV] 10 Sec #15: Volume based rollover from ESH4-CME to ESM4-CME occurs at 2014-03-14 | 2014-11-04 15:12:25
ESZ4-CME [CV] 10 Sec #15: Volume based rollover from ESM4-CME to ESU4-CME occurs at 2014-06-13 | 2014-11-04 15:12:25
ESZ4-CME [CV] 10 Sec #15: Volume based rollover from ESU4-CME to ESZ4-CME occurs at 2014-09-12 | 2014-11-04 15:12:25
ESZ4-CME [CV] 2000 Volume #17 | Symbols used for continuous contract chart: | 2014-11-04 15:12:25
ESZ4-CME [CV] 2000 Volume #17: Checking for volume based rollover dates. | 2014-11-04 15:12:25
Date rule based rollover from ESH4-CME to next contract occurs at 2014-03-13. | 2014-11-04 15:12:26
Date rule based rollover from ESM4-CME to next contract occurs at 2014-06-12. | 2014-11-04 15:12:26
Date rule based rollover from ESU4-CME to next contract occurs at 2014-09-11. | 2014-11-04 15:12:26
Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2014-11-04 15:12:26
Checking Intraday data file for symbol ESH4-CME for the date range from 2013-12-12 to 2014-03-13. | 2014-11-04 15:12:26
Checking Intraday data file for symbol ESM4-CME for the date range from 2014-03-13 to 2014-06-12. | 2014-11-04 15:12:26
Checking Intraday data file for symbol ESU4-CME for the date range from 2014-06-12 to 2014-09-11. | 2014-11-04 15:12:26
Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 0. | 2014-11-04 15:12:26
ESZ4-CME [C] 1 Min #20 | Symbols used for continuous contract chart: | 2014-11-04 15:12:26
ESH4-CME | 2014-11-04 15:12:26
ESM4-CME | 2014-11-04 15:12:26
ESU4-CME | 2014-11-04 15:12:26
ESZ4-CME | 2014-11-04 15:12:26
Date rule based rollover from ESZ3-CME to next contract occurs at 2013-12-12. | 2014-11-04 15:12:26
Checking Intraday data file for symbol ESZ3-CME for the date range from 2013-09-12 to 2013-12-12. | 2014-11-04 15:12:26
Checking Daily data file for symbol ESZ13 for the date range from 2013-09-12 to 2013-12-12. | 2014-11-04 15:12:26
Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-13. | 2014-11-04 15:12:26
Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2014-11-04 15:12:26
Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2014-11-04 15:12:26
Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-11-04. | 2014-11-04 15:12:26
ESZ4-CME [CV] 30 Min #23 | Symbols used for continuous contract chart: | 2014-11-04 15:12:26
ESZ3-CME | 2014-11-04 15:12:26
ESZ4-CME [CV] 30 Min #23: Checking for volume based rollover dates. | 2014-11-04 15:12:26
ESZ4-CME [CV] 30 Min #23: Volume based rollover from ESZ3-CME to ESH4-CME occurs at 2013-12-13 | 2014-11-04 15:12:26
ESZ4-CME [CV] 30 Min #23: Volume based rollover from ESH4-CME to ESM4-CME occurs at 2014-03-14 | 2014-11-04 15:12:26
ESZ4-CME [CV] 30 Min #23: Volume based rollover from ESM4-CME to ESU4-CME occurs at 2014-06-13 | 2014-11-04 15:12:26
ESZ4-CME [CV] 30 Min #23: Volume based rollover from ESU4-CME to ESZ4-CME occurs at 2014-09-12 | 2014-11-04 15:12:26
Date rule based rollover from ESM3-CME to next contract occurs at 2013-06-13. | 2014-11-04 15:12:26
Date rule based rollover from ESU3-CME to next contract occurs at 2013-09-12. | 2014-11-04 15:12:26
Checking Intraday data file for symbol ESM3-CME for the date range from 2013-03-07 to 2013-06-13. | 2014-11-04 15:12:26
Checking Daily data file for symbol ESM13 for the date range from 2013-03-07 to 2013-06-13. | 2014-11-04 15:12:26
Checking Intraday data file for symbol ESU3-CME for the date range from 2013-06-13 to 2013-09-12. | 2014-11-04 15:12:26
Checking Daily data file for symbol ESU13 for the date range from 2013-06-13 to 2013-09-12. | 2014-11-04 15:12:26
ESZ4-CME [CV] 2.50 Range #22 | Symbols used for continuous contract chart: | 2014-11-04 15:12:26
ESM3-CME | 2014-11-04 15:12:26
ESU3-CME | 2014-11-04 15:12:26
ESZ4-CME [CV] 2.50 Range #22: Checking for volume based rollover dates. | 2014-11-04 15:12:26
ESZ4-CME [CV] 2.50 Range #22: Volume based rollover from ESM3-CME to ESU3-CME occurs at 2013-06-14 | 2014-11-04 15:12:26
ESZ4-CME [CV] 2.50 Range #22: Volume based rollover from ESU3-CME to ESZ3-CME occurs at 2013-09-13 | 2014-11-04 15:12:26
ESZ4-CME [CV] 2.50 Range #22: Volume based rollover from ESZ3-CME to ESH4-CME occurs at 2013-12-13 | 2014-11-04 15:12:26
ESZ4-CME [CV] 2.50 Range #22: Volume based rollover from ESH4-CME to ESM4-CME occurs at 2014-03-14 | 2014-11-04 15:12:26
ESZ4-CME [CV] 2.50 Range #22: Volume based rollover from ESM4-CME to ESU4-CME occurs at 2014-06-13 | 2014-11-04 15:12:26
ESZ4-CME [CV] 2.50 Range #22: Volume based rollover from ESU4-CME to ESZ4-CME occurs at 2014-09-12 | 2014-11-04 15:12:26
Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2014-11-04 15:12:27
Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 0. | 2014-11-04 15:12:27
Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-11-04. | 2014-11-04 15:12:27
ESZ4-CME [CV] 1 Min #4 | Symbols used for continuous contract chart: | 2014-11-04 15:12:27
ESZ4-CME | 2014-11-04 15:12:27
ESZ4-CME [CV] 1 Min #4: Checking for volume based rollover dates. | 2014-11-04 15:12:27
ESZ4-CME [CV] 15 Min #24 | Symbols used for continuous contract chart: | 2014-11-04 15:12:27
ESZ4-CME [CV] 15 Min #24: Checking for volume based rollover dates. | 2014-11-04 15:12:27
Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 0. | 2014-11-04 15:12:28
Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-11-04. | 2014-11-04 15:12:28
ESZ4-CME [CV] 1.25 Range #25 | Symbols used for continuous contract chart: | 2014-11-04 15:12:28
ESZ4-CME | 2014-11-04 15:12:28
ESZ4-CME [CV] 1.25 Range #25: Checking for volume based rollover dates. | 2014-11-04 15:12:28
Date rule based rollover from ESH4-CME to next contract occurs at 2014-03-13. | 2014-11-04 15:12:28
Date rule based rollover from ESM4-CME to next contract occurs at 2014-06-12. | 2014-11-04 15:12:28
Date rule based rollover from ESU4-CME to next contract occurs at 2014-09-11. | 2014-11-04 15:12:28
Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2014-11-04 15:12:28
Checking Intraday data file for symbol ESH4-CME for the date range from 2013-12-12 to 2014-03-13. | 2014-11-04 15:12:28
Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-13. | 2014-11-04 15:12:28
Checking Intraday data file for symbol ESM4-CME for the date range from 2014-03-13 to 2014-06-12. | 2014-11-04 15:12:28
Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2014-11-04 15:12:28
Checking Intraday data file for symbol ESU4-CME for the date range from 2014-06-12 to 2014-09-11. | 2014-11-04 15:12:28
Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2014-11-04 15:12:28
ESZ4-CME [CV] 1.25 Range #19 | Symbols used for continuous contract chart: | 2014-11-04 15:12:28
ESH4-CME | 2014-11-04 15:12:28
ESM4-CME | 2014-11-04 15:12:28
ESU4-CME | 2014-11-04 15:12:28
ESZ4-CME [CV] 1.25 Range #19: Checking for volume based rollover dates. | 2014-11-04 15:12:28
ESZ4-CME [CV] 1.25 Range #19: Volume based rollover from ESH4-CME to ESM4-CME occurs at 2014-03-14 | 2014-11-04 15:12:28
ESZ4-CME [CV] 1.25 Range #19: Volume based rollover from ESM4-CME to ESU4-CME occurs at 2014-06-13 | 2014-11-04 15:12:28
ESZ4-CME [CV] 1.25 Range #19: Volume based rollover from ESU4-CME to ESZ4-CME occurs at 2014-09-12 | 2014-11-04 15:12:28
ESZ4-CME [CV] 1.25 Range #13 | Symbols used for continuous contract chart: | 2014-11-04 15:12:28
ESZ4-CME [CV] 1.25 Range #13: Checking for volume based rollover dates. | 2014-11-04 15:12:28
ESZ4-CME [CV] 1.25 Range #13: Volume based rollover from ESH4-CME to ESM4-CME occurs at 2014-03-14 | 2014-11-04 15:12:28
ESZ4-CME [CV] 1.25 Range #13: Volume based rollover from ESM4-CME to ESU4-CME occurs at 2014-06-13 | 2014-11-04 15:12:28
ESZ4-CME [CV] 1.25 Range #13: Volume based rollover from ESU4-CME to ESZ4-CME occurs at 2014-09-12 | 2014-11-04 15:12:28
HD Request # 14 | Downloading Intraday chart data for ESZ4-CME to the file ESZ4-CME.scid. Service: rim | 2014-11-04 15:12:28
HD Request # 14 | Download start Date-Time: 2014-10-26 21:14:59.0 | 2014-11-04 15:12:28
HD Request # 14 | Using server: ds5.sierracharts.com port 10149 | 2014-11-04 15:12:28
Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-11-04 15:12:28
Socket (964) | Connected. | 2014-11-04 15:12:28
HD Request # 14 | Sending historical data logon request message. | 2014-11-04 15:12:28
HD Request # 14 | Requesting Intraday data. Start Date-Time: 2014-10-26 21:14:59. Record interval: 0. Symbol: ESZ4-CME | 2014-11-04 15:12:28
HD Request # 14 | Decompressing data. | 2014-11-04 15:12:29
HD Request # 14 | Receiving Intraday data for ESZ4-CME starting at 2014-10-26 21:15:00 | 2014-11-04 15:12:29
HD Request # 14 | Timestamp of first Intraday data file record written: 2014-10-26 21:15:00 | 2014-11-04 15:12:29
Socket (964) | Shutdown and closed. | 2014-11-04 15:12:41
The network socket for historical data has been closed. | 2014-11-04 15:12:41
HD Request # 14 | Received 3682137 records from 2014-10-26 21:15:00 to 2014-11-04 15:12:24 (8.8 days) and wrote 3682137 records for ESZ4-CME | 2014-11-04 15:12:41
HD Request # 14 | Intraday download COMPLETE for ESZ4-CME. Completion time: 13s. Unique request ID: 13 | 2014-11-04 15:12:41
Removed historical data download ID 13 | 2014-11-04 15:12:41
Real-time Intraday chart data file updates started for ESZ4-CME | 2014-11-04 15:12:41
Date rule based rollover from ESM3-CME to next contract occurs at 2013-06-13. | 2014-11-04 15:20:41
Date rule based rollover from ESU3-CME to next contract occurs at 2013-09-12. | 2014-11-04 15:20:41
Date rule based rollover from ESZ3-CME to next contract occurs at 2013-12-12. | 2014-11-04 15:20:41
Date rule based rollover from ESH4-CME to next contract occurs at 2014-03-13. | 2014-11-04 15:20:41
Date rule based rollover from ESM4-CME to next contract occurs at 2014-06-12. | 2014-11-04 15:20:41
Date rule based rollover from ESU4-CME to next contract occurs at 2014-09-11. | 2014-11-04 15:20:41
Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2014-11-04 15:20:41
Checking Intraday data file for symbol ESM3-CME for the date range from 2013-03-07 to 2013-06-13. | 2014-11-04 15:20:41
Checking Daily data file for symbol ESM13 for the date range from 2013-03-07 to 2013-06-13. | 2014-11-04 15:20:41
Checking Intraday data file for symbol ESU3-CME for the date range from 2013-06-13 to 2013-09-12. | 2014-11-04 15:20:41
Checking Daily data file for symbol ESU13 for the date range from 2013-06-13 to 2013-09-12. | 2014-11-04 15:20:41
Checking Intraday data file for symbol ESZ3-CME for the date range from 2013-09-12 to 2013-12-12. | 2014-11-04 15:20:41
Checking Daily data file for symbol ESZ13 for the date range from 2013-09-12 to 2013-12-12. | 2014-11-04 15:20:41
Checking Intraday data file for symbol ESH4-CME for the date range from 2013-12-12 to 2014-03-13. | 2014-11-04 15:20:41
Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-13. | 2014-11-04 15:20:41
Checking Intraday data file for symbol ESM4-CME for the date range from 2014-03-13 to 2014-06-12. | 2014-11-04 15:20:41
Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2014-11-04 15:20:41
Checking Intraday data file for symbol ESU4-CME for the date range from 2014-06-12 to 2014-09-11. | 2014-11-04 15:20:41
Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2014-11-04 15:20:41
Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 0. | 2014-11-04 15:20:41
Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-11-04. | 2014-11-04 15:20:41
ESZ4-CME [CV] 15 Min #11 | Symbols used for continuous contract chart: | 2014-11-04 15:20:41
ESM3-CME | 2014-11-04 15:20:41
ESU3-CME | 2014-11-04 15:20:41
ESZ3-CME | 2014-11-04 15:20:41
ESH4-CME | 2014-11-04 15:20:41
ESM4-CME | 2014-11-04 15:20:41
ESU4-CME | 2014-11-04 15:20:41
ESZ4-CME | 2014-11-04 15:20:41
ESZ4-CME [CV] 15 Min #11: Checking for volume based rollover dates. | 2014-11-04 15:20:41
ESZ4-CME [CV] 15 Min #11: Volume based rollover from ESM3-CME to ESU3-CME occurs at 2013-06-14 | 2014-11-04 15:20:41
ESZ4-CME [CV] 15 Min #11: Volume based rollover from ESU3-CME to ESZ3-CME occurs at 2013-09-13 | 2014-11-04 15:20:41
ESZ4-CME [CV] 15 Min #11: Volume based rollover from ESZ3-CME to ESH4-CME occurs at 2013-12-13 | 2014-11-04 15:20:41
ESZ4-CME [CV] 15 Min #11: Volume based rollover from ESH4-CME to ESM4-CME occurs at 2014-03-14 | 2014-11-04 15:20:41
ESZ4-CME [CV] 15 Min #11: Volume based rollover from ESM4-CME to ESU4-CME occurs at 2014-06-13 | 2014-11-04 15:20:41
ESZ4-CME [CV] 15 Min #11: Volume based rollover from ESU4-CME to ESZ4-CME occurs at 2014-09-12 | 2014-11-04 15:20:41
Remote instance connected: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart2 - Trading PC\SierraChart.exe | 2014-11-04 15:25:52
ESZ4-CME [CV] 1 Min #3 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 15:27:00. Next Bar Date Time: 2014-11-04 13:10:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-04 15:29:24
ESZ4-CME [CV] 15 Min #24 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 15:15:00. Next Bar Date Time: 2014-11-04 13:00:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-04 15:29:24
ESZ4-CME [CV] 10 Sec #15 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 15:27:50. Next Bar Date Time: 2014-11-04 13:10:40. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-04 15:29:24
ESZ4-CME [CV] 1.25 Range #25 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 15:14:49. Next Bar Date Time: 2014-11-04 13:10:43. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-04 15:29:24
ESZ4-CME [C] 1 Min #20 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 15:27:00. Next Bar Date Time: 2014-11-04 13:10:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-04 15:29:24
ESZ4-CME [CV] 1.25 Range #19 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 15:14:49. Next Bar Date Time: 2014-11-04 13:10:43. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-04 15:29:24
ESZ4-CME [CV] 30 Min #23 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 15:00:00. Next Bar Date Time: 2014-11-04 13:00:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-04 15:29:24
ESZ4-CME [CV] 15 Min #11 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 15:15:00. Next Bar Date Time: 2014-11-04 13:00:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-04 15:29:24
ESZ4-CME [CV] 2.50 Range #22 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 15:00:14. Next Bar Date Time: 2014-11-04 13:10:43. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-04 15:29:24
ESZ4-CME [CV] 1.25 Range #13 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 15:14:49. Next Bar Date Time: 2014-11-04 13:10:43. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-04 15:29:24
ESZ4-CME [CV] 1 Min #2 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 15:27:00. Next Bar Date Time: 2014-11-04 13:10:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-04 15:29:24
ESZ4-CME 15 Min #11 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 15:15:00. Next Bar Date Time: 2014-09-22 11:15:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-04 16:25:31
ESZ4-CME 15 Min #11 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 15:30:00. Next Bar Date Time: 2014-09-22 13:00:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-04 16:25:31
ESZ4-CME 15 Min #11 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 15:30:00. Next Bar Date Time: 2014-09-30 12:45:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-04 16:25:32
ESZ4-CME 15 Min #11 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 15:30:00. Next Bar Date Time: 2014-10-01 07:30:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-04 16:25:32
ESZ4-CME 15 Min #11 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 15:30:00. Next Bar Date Time: 2014-10-03 12:00:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-04 16:25:33
ESZ4-CME 15 Min #11 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 15:30:00. Next Bar Date Time: 2014-10-15 11:15:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-04 16:25:35
ESZ4-CME 15 Min #11 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 15:30:00. Next Bar Date Time: 2014-10-30 00:45:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-04 16:25:37
ESZ4-CME 15 Min #11 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 16:00:00. Next Bar Date Time: 2014-11-04 15:45:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-04 16:25:38
Date rule based rollover from ESM3-CME to next contract occurs at 2013-06-13. | 2014-11-04 16:26:12
Date rule based rollover from ESU3-CME to next contract occurs at 2013-09-12. | 2014-11-04 16:26:12
Date rule based rollover from ESZ3-CME to next contract occurs at 2013-12-12. | 2014-11-04 16:26:12
Date rule based rollover from ESH4-CME to next contract occurs at 2014-03-13. | 2014-11-04 16:26:12
Date rule based rollover from ESM4-CME to next contract occurs at 2014-06-12. | 2014-11-04 16:26:12
Date rule based rollover from ESU4-CME to next contract occurs at 2014-09-11. | 2014-11-04 16:26:12
Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2014-11-04 16:26:12
Checking Intraday data file for symbol ESM3-CME for the date range from 2013-03-07 to 2013-06-13. | 2014-11-04 16:26:12
Checking Daily data file for symbol ESM13 for the date range from 2013-03-07 to 2013-06-13. | 2014-11-04 16:26:12
Checking Intraday data file for symbol ESU3-CME for the date range from 2013-06-13 to 2013-09-12. | 2014-11-04 16:26:12
Checking Daily data file for symbol ESU13 for the date range from 2013-06-13 to 2013-09-12. | 2014-11-04 16:26:12
Checking Intraday data file for symbol ESZ3-CME for the date range from 2013-09-12 to 2013-12-12. | 2014-11-04 16:26:12
Checking Daily data file for symbol ESZ13 for the date range from 2013-09-12 to 2013-12-12. | 2014-11-04 16:26:12
Checking Intraday data file for symbol ESH4-CME for the date range from 2013-12-12 to 2014-03-13. | 2014-11-04 16:26:12
Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-13. | 2014-11-04 16:26:12
Checking Intraday data file for symbol ESM4-CME for the date range from 2014-03-13 to 2014-06-12. | 2014-11-04 16:26:12
Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2014-11-04 16:26:12
Checking Intraday data file for symbol ESU4-CME for the date range from 2014-06-12 to 2014-09-11. | 2014-11-04 16:26:12
Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2014-11-04 16:26:12
Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 0. | 2014-11-04 16:26:12
Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-11-04. | 2014-11-04 16:26:12
ESZ4-CME [CV] 15 Min #11 | Symbols used for continuous contract chart: | 2014-11-04 16:26:12
ESM3-CME | 2014-11-04 16:26:12
ESU3-CME | 2014-11-04 16:26:12
ESZ3-CME | 2014-11-04 16:26:12
ESH4-CME | 2014-11-04 16:26:12
ESM4-CME | 2014-11-04 16:26:12
ESU4-CME | 2014-11-04 16:26:12
ESZ4-CME | 2014-11-04 16:26:12
ESZ4-CME [CV] 15 Min #11: Checking for volume based rollover dates. | 2014-11-04 16:26:12
ESZ4-CME [CV] 15 Min #11: Volume based rollover from ESM3-CME to ESU3-CME occurs at 2013-06-14 | 2014-11-04 16:26:12
ESZ4-CME [CV] 15 Min #11: Volume based rollover from ESU3-CME to ESZ3-CME occurs at 2013-09-13 | 2014-11-04 16:26:12
ESZ4-CME [CV] 15 Min #11: Volume based rollover from ESZ3-CME to ESH4-CME occurs at 2013-12-13 | 2014-11-04 16:26:12
ESZ4-CME [CV] 15 Min #11: Volume based rollover from ESH4-CME to ESM4-CME occurs at 2014-03-14 | 2014-11-04 16:26:12
ESZ4-CME [CV] 15 Min #11: Volume based rollover from ESM4-CME to ESU4-CME occurs at 2014-06-13 | 2014-11-04 16:26:12
ESZ4-CME [CV] 15 Min #11: Volume based rollover from ESU4-CME to ESZ4-CME occurs at 2014-09-12 | 2014-11-04 16:26:12
ESZ4-CME [CV] 15 Min #11 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 15:15:00. Next Bar Date Time: 2014-09-22 11:15:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-04 16:26:37
ESZ4-CME [CV] 15 Min #11 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 15:30:00. Next Bar Date Time: 2014-09-22 13:00:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-04 16:26:37
ESZ4-CME [CV] 15 Min #11 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 15:30:00. Next Bar Date Time: 2014-09-30 12:45:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-04 16:26:38
ESZ4-CME [CV] 15 Min #11 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 15:30:00. Next Bar Date Time: 2014-10-01 07:30:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-04 16:26:38
ESZ4-CME [CV] 15 Min #11 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 15:30:00. Next Bar Date Time: 2014-10-03 12:00:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-04 16:26:38
ESZ4-CME [CV] 15 Min #11 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 15:30:00. Next Bar Date Time: 2014-10-15 11:15:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-04 16:26:40
ESZ4-CME [CV] 15 Min #11 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 15:30:00. Next Bar Date Time: 2014-10-30 00:45:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-04 16:26:43
ESZ4-CME [CV] 15 Min #11 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 16:00:00. Next Bar Date Time: 2014-11-04 15:45:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-04 16:26:43
Rithmic Trading | Requesting Trade Positions data. | 2014-11-04 19:06:29
Rithmic Trading | Requesting Trade Positions data. | 2014-11-04 23:06:29
Rithmic Trading | Requesting Trade Positions data. | 2014-11-05 03:06:29
Date rule based rollover from ESH4-CME to next contract occurs at 2014-03-13. | 2014-11-05 05:04:02
Date rule based rollover from ESM4-CME to next contract occurs at 2014-06-12. | 2014-11-05 05:04:02
Date rule based rollover from ESU4-CME to next contract occurs at 2014-09-11. | 2014-11-05 05:04:02
Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2014-11-05 05:04:02
Checking Intraday data file for symbol ESH4-CME for the date range from 2013-12-12 to 2014-03-13. | 2014-11-05 05:04:02
Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-13. | 2014-11-05 05:04:02
Checking Intraday data file for symbol ESM4-CME for the date range from 2014-03-13 to 2014-06-12. | 2014-11-05 05:04:02
Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2014-11-05 05:04:02
Checking Intraday data file for symbol ESU4-CME for the date range from 2014-06-12 to 2014-09-11. | 2014-11-05 05:04:02
Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2014-11-05 05:04:02
Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 0. | 2014-11-05 05:04:02
Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-11-05. | 2014-11-05 05:04:02
Skipping Daily data download for symbol ESZ14 since download was already done in last 24 hours. | 2014-11-05 05:04:02
ESZ4-CME [CV] 1.25 Range #7 | Symbols used for continuous contract chart: | 2014-11-05 05:04:02
ESH4-CME | 2014-11-05 05:04:02
ESM4-CME | 2014-11-05 05:04:02
ESU4-CME | 2014-11-05 05:04:02
ESZ4-CME | 2014-11-05 05:04:02
ESZ4-CME [CV] 1.25 Range #7: Checking for volume based rollover dates. | 2014-11-05 05:04:02
ESZ4-CME [CV] 1.25 Range #7: Volume based rollover from ESH4-CME to ESM4-CME occurs at 2014-03-14 | 2014-11-05 05:04:02
ESZ4-CME [CV] 1.25 Range #7: Volume based rollover from ESM4-CME to ESU4-CME occurs at 2014-06-13 | 2014-11-05 05:04:02
ESZ4-CME [CV] 1.25 Range #7: Volume based rollover from ESU4-CME to ESZ4-CME occurs at 2014-09-12 | 2014-11-05 05:04:02
ESZ4-CME [CV] 1.25 Range #7 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 15:29:42. Next Bar Date Time: 2014-09-22 11:24:39. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:04:33
ESZ4-CME [CV] 1.25 Range #7 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 15:30:00. Next Bar Date Time: 2014-09-22 13:00:05. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:04:33
ESZ4-CME [CV] 1.25 Range #7 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 15:30:00. Next Bar Date Time: 2014-09-30 12:58:46. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:04:34
ESZ4-CME [CV] 1.25 Range #7 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 15:30:09. Next Bar Date Time: 2014-10-01 07:43:53. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:04:35
ESZ4-CME [CV] 1.25 Range #7 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 15:30:11. Next Bar Date Time: 2014-10-03 12:06:39. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:04:35
Date rule based rollover from ESM3-CME to next contract occurs at 2013-06-13. | 2014-11-05 05:04:36
Date rule based rollover from ESU3-CME to next contract occurs at 2013-09-12. | 2014-11-05 05:04:36
Date rule based rollover from ESZ3-CME to next contract occurs at 2013-12-12. | 2014-11-05 05:04:36
Date rule based rollover from ESH4-CME to next contract occurs at 2014-03-13. | 2014-11-05 05:04:36
Date rule based rollover from ESM4-CME to next contract occurs at 2014-06-12. | 2014-11-05 05:04:36
Date rule based rollover from ESU4-CME to next contract occurs at 2014-09-11. | 2014-11-05 05:04:36
Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2014-11-05 05:04:36
Checking Intraday data file for symbol ESM3-CME for the date range from 2013-03-07 to 2013-06-13. | 2014-11-05 05:04:36
Checking Daily data file for symbol ESM13 for the date range from 2013-03-07 to 2013-06-13. | 2014-11-05 05:04:36
Checking Intraday data file for symbol ESU3-CME for the date range from 2013-06-13 to 2013-09-12. | 2014-11-05 05:04:36
Checking Daily data file for symbol ESU13 for the date range from 2013-06-13 to 2013-09-12. | 2014-11-05 05:04:36
Checking Intraday data file for symbol ESZ3-CME for the date range from 2013-09-12 to 2013-12-12. | 2014-11-05 05:04:36
Checking Daily data file for symbol ESZ13 for the date range from 2013-09-12 to 2013-12-12. | 2014-11-05 05:04:36
Checking Intraday data file for symbol ESH4-CME for the date range from 2013-12-12 to 2014-03-13. | 2014-11-05 05:04:36
Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-13. | 2014-11-05 05:04:36
Checking Intraday data file for symbol ESM4-CME for the date range from 2014-03-13 to 2014-06-12. | 2014-11-05 05:04:36
Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2014-11-05 05:04:36
Checking Intraday data file for symbol ESU4-CME for the date range from 2014-06-12 to 2014-09-11. | 2014-11-05 05:04:36
Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2014-11-05 05:04:36
Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 0. | 2014-11-05 05:04:36
Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-11-05. | 2014-11-05 05:04:36
Skipping Daily data download for symbol ESZ14 since download was already done in last 24 hours. | 2014-11-05 05:04:36
ESZ4-CME [CV] 15 Min #21 | Symbols used for continuous contract chart: | 2014-11-05 05:04:36
ESM3-CME | 2014-11-05 05:04:36
ESU3-CME | 2014-11-05 05:04:36
ESZ3-CME | 2014-11-05 05:04:36
ESH4-CME | 2014-11-05 05:04:36
ESM4-CME | 2014-11-05 05:04:36
ESU4-CME | 2014-11-05 05:04:36
ESZ4-CME | 2014-11-05 05:04:36
ESZ4-CME [CV] 15 Min #21: Checking for volume based rollover dates. | 2014-11-05 05:04:36
ESZ4-CME [CV] 15 Min #21: Volume based rollover from ESM3-CME to ESU3-CME occurs at 2013-06-14 | 2014-11-05 05:04:36
ESZ4-CME [CV] 15 Min #21: Volume based rollover from ESU3-CME to ESZ3-CME occurs at 2013-09-13 | 2014-11-05 05:04:36
ESZ4-CME [CV] 15 Min #21: Volume based rollover from ESZ3-CME to ESH4-CME occurs at 2013-12-13 | 2014-11-05 05:04:36
ESZ4-CME [CV] 15 Min #21: Volume based rollover from ESH4-CME to ESM4-CME occurs at 2014-03-14 | 2014-11-05 05:04:36
ESZ4-CME [CV] 15 Min #21: Volume based rollover from ESM4-CME to ESU4-CME occurs at 2014-06-13 | 2014-11-05 05:04:36
ESZ4-CME [CV] 15 Min #21: Volume based rollover from ESU4-CME to ESZ4-CME occurs at 2014-09-12 | 2014-11-05 05:04:36
ESZ4-CME [CV] 1.25 Range #7 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 15:30:15. Next Bar Date Time: 2014-10-15 11:28:24. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:04:38
ESZ4-CME [CV] 1.25 Range #7 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 15:30:36. Next Bar Date Time: 2014-10-30 00:46:44. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:04:41
ESZ4-CME [CV] 15 Min #21 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 15:15:00. Next Bar Date Time: 2014-09-22 11:15:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:05:00
ESZ4-CME [CV] 15 Min #21 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 15:30:00. Next Bar Date Time: 2014-09-22 13:00:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:05:00
ESZ4-CME [CV] 15 Min #21 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 15:30:00. Next Bar Date Time: 2014-09-30 12:45:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:05:01
ESZ4-CME [CV] 15 Min #21 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 15:30:00. Next Bar Date Time: 2014-10-01 07:30:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:05:01
ESZ4-CME [CV] 15 Min #21 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 15:30:00. Next Bar Date Time: 2014-10-03 12:00:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:05:02
ESZ4-CME [CV] 15 Min #21 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 15:30:00. Next Bar Date Time: 2014-10-15 11:15:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:05:04
ESZ4-CME [CV] 15 Min #21 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 15:30:00. Next Bar Date Time: 2014-10-30 00:45:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:05:06
ESZ4-CME [CV] 15 Min #21 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-04 16:00:00. Next Bar Date Time: 2014-11-04 15:45:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:05:07
Intraday data recording state for symbol ESZ4-CME is set to pending. | 2014-11-05 05:06:46
HD Request # 15 | Downloading Intraday chart data for ESZ4-CME to the file ESZ4-CME.scid. Service: rim | 2014-11-05 05:06:46
HD Request # 15 | Download start Date-Time: 2014-09-08 17:00:00.0 | 2014-11-05 05:06:46
HD Request # 15 | Using server: ds3.sierracharts.com port 10149 | 2014-11-05 05:06:46
HD Request # 16 | Downloading Historical Daily chart data for ESH14. Starting date: 2014-03-20. Service: rim | 2014-11-05 05:06:46
Historical data download counter reset. | 2014-11-05 05:06:46
HD Request # 16 | Requesting historical Daily data for ESH14 starting at 2014-03-19 | 2014-11-05 05:06:46
Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-11-05 05:06:46
Socket (1904) | Connected. | 2014-11-05 05:06:46
HD Request # 15 | Sending historical data logon request message. | 2014-11-05 05:06:46
HD Request # 16 | Receiving historical Daily data for ESH14 starting at 2014-03-19 | 2014-11-05 05:06:46
Writing historical Daily data for ESH14 to the file ESH14.dly | 2014-11-05 05:06:46
HD Request # 16 | Received 3 records from 2014-03-19 00:00:00 to 2014-03-21 00:00:00 (3.0 days) and wrote 2 records for ESH14 | 2014-11-05 05:06:46
HD Request # 16 | Daily download COMPLETE for ESH14. Completion time: 0s. Unique request ID: 15 | 2014-11-05 05:06:46
Removed historical data download ID 15 | 2014-11-05 05:06:46
HD Request # 15 | Requesting Intraday data. Start Date-Time: 2014-09-08 17:00:00. Record interval: 0. Symbol: ESZ4-CME | 2014-11-05 05:06:46
HD Request # 15 | Decompressing data. | 2014-11-05 05:06:46
HD Request # 15 | Receiving Intraday data for ESZ4-CME starting at 2014-09-08 17:03:46 | 2014-11-05 05:06:46
HD Request # 15 | Timestamp of first Intraday data file record written: 2014-09-08 17:03:46 | 2014-11-05 05:06:46
Socket (1904) | Shutdown and closed. | 2014-11-05 05:08:06
The network socket for historical data has been closed. | 2014-11-05 05:08:06
HD Request # 15 | Received 23255176 records from 2014-09-08 17:03:46 to 2014-11-05 05:08:00 (57.5 days) and wrote 23255176 records for ESZ4-CME | 2014-11-05 05:08:06
Added 54 Time and Sales records to Intraday data file for ESZ4-CME after download. | 2014-11-05 05:08:06
HD Request # 15 | Intraday download COMPLETE for ESZ4-CME. Completion time: 1m 20s. Unique request ID: 14 | 2014-11-05 05:08:06
Removed historical data download ID 14 | 2014-11-05 05:08:06
Real-time Intraday chart data file updates started for ESZ4-CME | 2014-11-05 05:08:06
ESZ4-CME [CV] 1.25 Range #19: Download is complete for all contract months in chart. Proceeding with data load. | 2014-11-05 05:08:06
ESZ4-CME [CV] 1.25 Range #19: Checking for volume based rollover dates. | 2014-11-05 05:08:06
ESZ4-CME [CV] 1.25 Range #19: Volume based rollover from ESH4-CME to ESM4-CME occurs at 2014-03-14 | 2014-11-05 05:08:06
ESZ4-CME [CV] 1.25 Range #19: Volume based rollover from ESM4-CME to ESU4-CME occurs at 2014-06-13 | 2014-11-05 05:08:06
ESZ4-CME [CV] 1.25 Range #19: Volume based rollover from ESU4-CME to ESZ4-CME occurs at 2014-09-12 | 2014-11-05 05:08:06
ESZ4-CME [CV] 1.25 Range #19 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:06:41. Next Bar Date Time: 2014-09-19 06:32:22. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:08:37
ESZ4-CME [CV] 1.25 Range #19 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:06:54. Next Bar Date Time: 2014-09-19 06:47:13. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:08:37
ESZ4-CME [CV] 1.25 Range #19 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:06:55. Next Bar Date Time: 2014-09-19 09:10:27. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:08:37
ESZ4-CME [CV] 1.25 Range #19 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:06:55. Next Bar Date Time: 2014-09-19 11:47:22. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:08:37
ESZ4-CME [CV] 1.25 Range #19 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:06:56. Next Bar Date Time: 2014-09-19 12:58:10. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:08:37
ESZ4-CME [CV] 1.25 Range #19 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:06:56. Next Bar Date Time: 2014-09-22 08:17:43. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:08:37
ESZ4-CME [CV] 1.25 Range #19 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:06:57. Next Bar Date Time: 2014-09-24 07:42:45. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:08:38
ESZ4-CME [CV] 1.25 Range #19 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:06:59. Next Bar Date Time: 2014-09-25 08:23:04. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:08:38
ESZ4-CME [CV] 1.25 Range #19 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:07:02. Next Bar Date Time: 2014-09-25 11:53:37. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:08:38
ESZ4-CME [CV] 1.25 Range #19 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:07:02. Next Bar Date Time: 2014-09-26 02:14:01. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:08:38
ESZ4-CME [CV] 1.25 Range #19 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:07:03. Next Bar Date Time: 2014-09-29 06:41:19. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:08:38
ESZ4-CME [CV] 1.25 Range #19 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:07:04. Next Bar Date Time: 2014-09-30 00:18:32. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:08:39
ESZ4-CME [CV] 1.25 Range #19 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:07:06. Next Bar Date Time: 2014-10-01 05:40:53. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:08:39
ESZ4-CME [CV] 1.25 Range #19 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:07:08. Next Bar Date Time: 2014-10-01 07:22:11. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:08:39
ESZ4-CME [CV] 1.25 Range #19 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:07:09. Next Bar Date Time: 2014-10-01 10:06:18. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:08:39
ESZ4-CME [CV] 1.25 Range #19 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:07:09. Next Bar Date Time: 2014-10-02 06:52:23. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:08:39
ESZ4-CME [CV] 1.25 Range #19 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:07:11. Next Bar Date Time: 2014-10-02 08:32:39. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:08:39
ESZ4-CME [CV] 1.25 Range #19 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:07:12. Next Bar Date Time: 2014-10-03 06:32:44. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:08:40
ESZ4-CME [CV] 1.25 Range #19 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:07:13. Next Bar Date Time: 2014-10-03 08:01:45. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:08:40
ESZ4-CME [CV] 1.25 Range #19 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:07:14. Next Bar Date Time: 2014-10-05 23:15:22. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:08:40
ESZ4-CME 1.25 Range #19 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:06:41. Next Bar Date Time: 2014-09-19 06:32:22. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:13:25
ESZ4-CME 1.25 Range #19 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:06:54. Next Bar Date Time: 2014-09-19 06:47:13. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:13:25
ESZ4-CME 1.25 Range #19 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:06:55. Next Bar Date Time: 2014-09-19 09:10:27. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:13:25
ESZ4-CME 1.25 Range #19 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:06:55. Next Bar Date Time: 2014-09-19 11:47:22. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:13:25
ESZ4-CME 1.25 Range #19 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:06:56. Next Bar Date Time: 2014-09-19 12:58:10. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:13:25
ESZ4-CME 1.25 Range #19 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:06:56. Next Bar Date Time: 2014-09-22 08:17:43. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:13:25
ESZ4-CME 1.25 Range #19 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:06:57. Next Bar Date Time: 2014-09-24 07:42:45. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:13:25
ESZ4-CME 1.25 Range #19 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:06:59. Next Bar Date Time: 2014-09-25 08:23:04. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:13:26
ESZ4-CME 1.25 Range #19 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:07:02. Next Bar Date Time: 2014-09-25 11:53:37. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:13:26
ESZ4-CME 1.25 Range #19 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:07:02. Next Bar Date Time: 2014-09-26 02:14:01. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:13:26
ESZ4-CME 1.25 Range #19 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:07:03. Next Bar Date Time: 2014-09-29 06:41:19. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:13:26
ESZ4-CME 1.25 Range #19 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:07:04. Next Bar Date Time: 2014-09-30 00:18:32. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:13:26
ESZ4-CME 1.25 Range #19 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:07:06. Next Bar Date Time: 2014-10-01 05:40:53. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:13:27
ESZ4-CME 1.25 Range #19 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:07:08. Next Bar Date Time: 2014-10-01 07:22:11. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:13:27
ESZ4-CME 1.25 Range #19 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:07:09. Next Bar Date Time: 2014-10-01 10:06:18. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:13:27
ESZ4-CME 1.25 Range #19 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:07:09. Next Bar Date Time: 2014-10-02 06:52:23. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:13:27
ESZ4-CME 1.25 Range #19 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:07:11. Next Bar Date Time: 2014-10-02 08:32:39. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:13:27
ESZ4-CME 1.25 Range #19 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:07:12. Next Bar Date Time: 2014-10-03 06:32:44. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:13:27
ESZ4-CME 1.25 Range #19 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:07:13. Next Bar Date Time: 2014-10-03 08:01:45. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:13:27
ESZ4-CME 1.25 Range #19 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:07:14. Next Bar Date Time: 2014-10-05 23:15:22. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:13:27
Intraday data recording state for symbol ESZ4-CME is set to pending. | 2014-11-05 05:41:38
Reloading all charts with filename: ESZ4-CME.scid | 2014-11-05 05:41:38
Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2014-11-05 05:41:38
Intraday data file for ESZ4-CME exists and is empty. Skipping Intraday data download. | 2014-11-05 05:41:38
Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-11-05. | 2014-11-05 05:41:38
Skipping Daily data download for symbol ESZ14 since download was already done in last 24 hours. | 2014-11-05 05:41:38
ESZ4-CME [CV] 5 Min #12 | Symbols used for continuous contract chart: | 2014-11-05 05:41:38
ESZ4-CME | 2014-11-05 05:41:38
ESZ4-CME [CV] 5 Min #12 | Waiting for historical downloads to complete with the IDs: 16, | 2014-11-05 05:41:38
Date rule based rollover from ESU2-CME to next contract occurs at 2012-09-13. | 2014-11-05 05:41:38
Date rule based rollover from ESZ2-CME to next contract occurs at 2012-12-13. | 2014-11-05 05:41:38
Date rule based rollover from ESH3-CME to next contract occurs at 2013-03-07. | 2014-11-05 05:41:38
Date rule based rollover from ESM3-CME to next contract occurs at 2013-06-13. | 2014-11-05 05:41:38
Date rule based rollover from ESU3-CME to next contract occurs at 2013-09-12. | 2014-11-05 05:41:38
Date rule based rollover from ESZ3-CME to next contract occurs at 2013-12-12. | 2014-11-05 05:41:38
Date rule based rollover from ESH4-CME to next contract occurs at 2014-03-13. | 2014-11-05 05:41:38
Date rule based rollover from ESM4-CME to next contract occurs at 2014-06-12. | 2014-11-05 05:41:38
Date rule based rollover from ESU4-CME to next contract occurs at 2014-09-11. | 2014-11-05 05:41:38
Checking Intraday data file for symbol ESU2-CME for the date range from 2012-06-07 to 2012-09-13. | 2014-11-05 05:41:38
Checking Daily data file for symbol ESU12 for the date range from 2012-06-07 to 2012-09-13. | 2014-11-05 05:41:38
Checking Intraday data file for symbol ESZ2-CME for the date range from 2012-09-13 to 2012-12-13. | 2014-11-05 05:41:38
Checking Daily data file for symbol ESZ12 for the date range from 2012-09-13 to 2012-12-13. | 2014-11-05 05:41:38
Checking Intraday data file for symbol ESH3-CME for the date range from 2012-12-13 to 2013-03-07. | 2014-11-05 05:41:38
Checking Daily data file for symbol ESH13 for the date range from 2012-12-13 to 2013-03-07. | 2014-11-05 05:41:38
Checking Intraday data file for symbol ESM3-CME for the date range from 2013-03-07 to 2013-06-13. | 2014-11-05 05:41:38
Checking Daily data file for symbol ESM13 for the date range from 2013-03-07 to 2013-06-13. | 2014-11-05 05:41:38
Checking Intraday data file for symbol ESU3-CME for the date range from 2013-06-13 to 2013-09-12. | 2014-11-05 05:41:38
Checking Daily data file for symbol ESU13 for the date range from 2013-06-13 to 2013-09-12. | 2014-11-05 05:41:38
Checking Intraday data file for symbol ESZ3-CME for the date range from 2013-09-12 to 2013-12-12. | 2014-11-05 05:41:38
Checking Daily data file for symbol ESZ13 for the date range from 2013-09-12 to 2013-12-12. | 2014-11-05 05:41:38
Checking Intraday data file for symbol ESH4-CME for the date range from 2013-12-12 to 2014-03-13. | 2014-11-05 05:41:38
Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-13. | 2014-11-05 05:41:38
Checking Intraday data file for symbol ESM4-CME for the date range from 2014-03-13 to 2014-06-12. | 2014-11-05 05:41:38
Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2014-11-05 05:41:38
Checking Intraday data file for symbol ESU4-CME for the date range from 2014-06-12 to 2014-09-11. | 2014-11-05 05:41:38
Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2014-11-05 05:41:38
ESZ4-CME [CV] 1 Min #3 | Symbols used for continuous contract chart: | 2014-11-05 05:41:38
ESU2-CME | 2014-11-05 05:41:38
ESZ2-CME | 2014-11-05 05:41:38
ESH3-CME | 2014-11-05 05:41:38
ESM3-CME | 2014-11-05 05:41:38
ESU3-CME | 2014-11-05 05:41:38
ESZ3-CME | 2014-11-05 05:41:38
ESH4-CME | 2014-11-05 05:41:38
ESM4-CME | 2014-11-05 05:41:38
ESU4-CME | 2014-11-05 05:41:38
ESZ4-CME [CV] 1 Min #3 | Waiting for historical downloads to complete with the IDs: 16, | 2014-11-05 05:41:38
Date rule based rollover from ESH4-CME to next contract occurs at 2014-03-13. | 2014-11-05 05:41:39
Date rule based rollover from ESM4-CME to next contract occurs at 2014-06-12. | 2014-11-05 05:41:39
Date rule based rollover from ESU4-CME to next contract occurs at 2014-09-11. | 2014-11-05 05:41:39
Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2014-11-05 05:41:39
Checking Intraday data file for symbol ESH4-CME for the date range from 2013-12-12 to 2014-03-13. | 2014-11-05 05:41:39
Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-13. | 2014-11-05 05:41:39
Checking Intraday data file for symbol ESM4-CME for the date range from 2014-03-13 to 2014-06-12. | 2014-11-05 05:41:39
Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2014-11-05 05:41:39
Checking Intraday data file for symbol ESU4-CME for the date range from 2014-06-12 to 2014-09-11. | 2014-11-05 05:41:39
Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2014-11-05 05:41:39
Intraday data file for ESZ4-CME exists and is empty. Skipping Intraday data download. | 2014-11-05 05:41:39
Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-11-05. | 2014-11-05 05:41:39
Skipping Daily data download for symbol ESZ14 since download was already done in last 24 hours. | 2014-11-05 05:41:39
ESZ4-CME [CV] 1 Min #2 | Symbols used for continuous contract chart: | 2014-11-05 05:41:39
ESH4-CME | 2014-11-05 05:41:39
ESM4-CME | 2014-11-05 05:41:39
ESU4-CME | 2014-11-05 05:41:39
ESZ4-CME | 2014-11-05 05:41:39
ESZ4-CME [CV] 1 Min #2 | Waiting for historical downloads to complete with the IDs: 16, | 2014-11-05 05:41:39
Limiting the number of days back for the continuous futures chart to 4.9993155 years based on the account type. | 2014-11-05 05:41:39
Date rule based rollover from ESZ9-CME to next contract occurs at 2009-12-10. | 2014-11-05 05:41:39
Date rule based rollover from ESH0-CME to next contract occurs at 2010-03-11. | 2014-11-05 05:41:39
Date rule based rollover from ESM0-CME to next contract occurs at 2010-06-10. | 2014-11-05 05:41:39
Date rule based rollover from ESU0-CME to next contract occurs at 2010-09-09. | 2014-11-05 05:41:39
Date rule based rollover from ESZ0-CME to next contract occurs at 2010-12-09. | 2014-11-05 05:41:39
Date rule based rollover from ESH1-CME to next contract occurs at 2011-03-10. | 2014-11-05 05:41:39
Date rule based rollover from ESM1-CME to next contract occurs at 2011-06-09. | 2014-11-05 05:41:39
Date rule based rollover from ESU1-CME to next contract occurs at 2011-09-08. | 2014-11-05 05:41:39
Date rule based rollover from ESZ1-CME to next contract occurs at 2011-12-08. | 2014-11-05 05:41:39
Date rule based rollover from ESH2-CME to next contract occurs at 2012-03-08. | 2014-11-05 05:41:39
Date rule based rollover from ESM2-CME to next contract occurs at 2012-06-07. | 2014-11-05 05:41:39
Date rule based rollover from ESU2-CME to next contract occurs at 2012-09-13. | 2014-11-05 05:41:39
Date rule based rollover from ESZ2-CME to next contract occurs at 2012-12-13. | 2014-11-05 05:41:39
Date rule based rollover from ESH3-CME to next contract occurs at 2013-03-07. | 2014-11-05 05:41:39
Date rule based rollover from ESM3-CME to next contract occurs at 2013-06-13. | 2014-11-05 05:41:39
Date rule based rollover from ESU3-CME to next contract occurs at 2013-09-12. | 2014-11-05 05:41:39
Date rule based rollover from ESZ3-CME to next contract occurs at 2013-12-12. | 2014-11-05 05:41:39
Intraday data file for ESZ9-CME exists and is empty. Skipping Intraday data download. | 2014-11-05 05:41:39
Checking Daily data file for symbol ESZ09 for the date range from 2009-09-10 to 2009-12-10. | 2014-11-05 05:41:39
Intraday data file for ESH0-CME exists and is empty. Skipping Intraday data download. | 2014-11-05 05:41:39
Checking Daily data file for symbol ESH10 for the date range from 2009-12-10 to 2010-03-11. | 2014-11-05 05:41:39
Intraday data file for ESM0-CME exists and is empty. Skipping Intraday data download. | 2014-11-05 05:41:39
Checking Daily data file for symbol ESM10 for the date range from 2010-03-11 to 2010-06-10. | 2014-11-05 05:41:39
Intraday data file for ESU0-CME exists and is empty. Skipping Intraday data download. | 2014-11-05 05:41:39
Checking Daily data file for symbol ESU10 for the date range from 2010-06-10 to 2010-09-09. | 2014-11-05 05:41:39
Intraday data file for ESZ0-CME exists and is empty. Skipping Intraday data download. | 2014-11-05 05:41:39
Checking Daily data file for symbol ESZ10 for the date range from 2010-09-09 to 2010-12-09. | 2014-11-05 05:41:39
Checking Intraday data file for symbol ESH1-CME for the date range from 2010-12-09 to 2011-03-10. | 2014-11-05 05:41:39
Checking Daily data file for symbol ESH11 for the date range from 2010-12-09 to 2011-03-10. | 2014-11-05 05:41:39
Checking Intraday data file for symbol ESM1-CME for the date range from 2011-03-10 to 2011-06-09. | 2014-11-05 05:41:39
Checking Daily data file for symbol ESM11 for the date range from 2011-03-10 to 2011-06-09. | 2014-11-05 05:41:39
Checking Intraday data file for symbol ESU1-CME for the date range from 2011-06-09 to 2011-09-08. | 2014-11-05 05:41:39
Checking Daily data file for symbol ESU11 for the date range from 2011-06-09 to 2011-09-08. | 2014-11-05 05:41:39
Checking Intraday data file for symbol ESZ1-CME for the date range from 2011-09-08 to 2011-12-08. | 2014-11-05 05:41:39
Checking Daily data file for symbol ESZ11 for the date range from 2011-09-08 to 2011-12-08. | 2014-11-05 05:41:39
Checking Intraday data file for symbol ESH2-CME for the date range from 2011-12-08 to 2012-03-08. | 2014-11-05 05:41:39
Checking Daily data file for symbol ESH12 for the date range from 2011-12-08 to 2012-03-08. | 2014-11-05 05:41:39
Checking Intraday data file for symbol ESM2-CME for the date range from 2012-03-08 to 2012-06-07. | 2014-11-05 05:41:39
Checking Daily data file for symbol ESM12 for the date range from 2012-03-08 to 2012-06-07. | 2014-11-05 05:41:39
Checking Intraday data file for symbol ESU2-CME for the date range from 2012-06-07 to 2012-09-13. | 2014-11-05 05:41:39
Checking Daily data file for symbol ESU12 for the date range from 2012-06-07 to 2012-09-13. | 2014-11-05 05:41:39
Checking Intraday data file for symbol ESZ2-CME for the date range from 2012-09-13 to 2012-12-13. | 2014-11-05 05:41:39
Checking Daily data file for symbol ESZ12 for the date range from 2012-09-13 to 2012-12-13. | 2014-11-05 05:41:39
Checking Intraday data file for symbol ESH3-CME for the date range from 2012-12-13 to 2013-03-07. | 2014-11-05 05:41:39
Checking Daily data file for symbol ESH13 for the date range from 2012-12-13 to 2013-03-07. | 2014-11-05 05:41:39
Checking Intraday data file for symbol ESM3-CME for the date range from 2013-03-07 to 2013-06-13. | 2014-11-05 05:41:39
Checking Daily data file for symbol ESM13 for the date range from 2013-03-07 to 2013-06-13. | 2014-11-05 05:41:39
Checking Intraday data file for symbol ESU3-CME for the date range from 2013-06-13 to 2013-09-12. | 2014-11-05 05:41:39
Checking Daily data file for symbol ESU13 for the date range from 2013-06-13 to 2013-09-12. | 2014-11-05 05:41:39
Checking Intraday data file for symbol ESZ3-CME for the date range from 2013-09-12 to 2013-12-12. | 2014-11-05 05:41:39
Checking Daily data file for symbol ESZ13 for the date range from 2013-09-12 to 2013-12-12. | 2014-11-05 05:41:39
ESZ4-CME [CV] 1 Day #9 | Symbols used for continuous contract chart: | 2014-11-05 05:41:39
ESZ9-CME | 2014-11-05 05:41:39
ESH0-CME | 2014-11-05 05:41:39
ESM0-CME | 2014-11-05 05:41:39
ESU0-CME | 2014-11-05 05:41:39
ESZ0-CME | 2014-11-05 05:41:39
ESH1-CME | 2014-11-05 05:41:39
ESM1-CME | 2014-11-05 05:41:39
ESU1-CME | 2014-11-05 05:41:39
ESZ1-CME | 2014-11-05 05:41:39
ESH2-CME | 2014-11-05 05:41:39
ESM2-CME | 2014-11-05 05:41:39
ESU2-CME | 2014-11-05 05:41:39
ESZ2-CME | 2014-11-05 05:41:39
ESH3-CME | 2014-11-05 05:41:39
ESM3-CME | 2014-11-05 05:41:39
ESU3-CME | 2014-11-05 05:41:39
ESZ3-CME | 2014-11-05 05:41:39
ESZ4-CME [CV] 1 Day #9 | Waiting for historical downloads to complete with the IDs: 16, | 2014-11-05 05:41:39
ESZ4-CME [CV] 10 Sec #15 | Symbols used for continuous contract chart: | 2014-11-05 05:41:39
ESZ4-CME [CV] 10 Sec #15 | Waiting for historical downloads to complete with the IDs: 16, | 2014-11-05 05:41:39
ESZ4-CME [CV] 2000 Volume #17 | Symbols used for continuous contract chart: | 2014-11-05 05:41:39
ESZ4-CME [CV] 2000 Volume #17 | Waiting for historical downloads to complete with the IDs: 16, | 2014-11-05 05:41:39
ESZ4-CME [CV] 15 Min #11 | Symbols used for continuous contract chart: | 2014-11-05 05:41:39
ESZ4-CME [CV] 15 Min #11 | Waiting for historical downloads to complete with the IDs: 16, | 2014-11-05 05:41:39
ESZ4-CME [C] 1 Min #20 | Symbols used for continuous contract chart: | 2014-11-05 05:41:39
ESZ4-CME [C] 1 Min #20 | Waiting for historical downloads to complete with the IDs: 16, | 2014-11-05 05:41:39
ESZ4-CME [CV] 30 Min #23 | Symbols used for continuous contract chart: | 2014-11-05 05:41:39
ESZ4-CME [CV] 30 Min #23 | Waiting for historical downloads to complete with the IDs: 16, | 2014-11-05 05:41:39
ESZ4-CME [CV] 2.50 Range #22 | Symbols used for continuous contract chart: | 2014-11-05 05:41:39
ESZ4-CME [CV] 2.50 Range #22 | Waiting for historical downloads to complete with the IDs: 16, | 2014-11-05 05:41:39
ESZ4-CME [CV] 1 Min #4 | Symbols used for continuous contract chart: | 2014-11-05 05:41:39
ESZ4-CME [CV] 1 Min #4 | Waiting for historical downloads to complete with the IDs: 16, | 2014-11-05 05:41:39
ESZ4-CME [CV] 15 Min #24 | Symbols used for continuous contract chart: | 2014-11-05 05:41:39
ESZ4-CME [CV] 15 Min #24 | Waiting for historical downloads to complete with the IDs: 16, | 2014-11-05 05:41:39
ESZ4-CME [CV] 1.25 Range #25 | Symbols used for continuous contract chart: | 2014-11-05 05:41:39
ESZ4-CME [CV] 1.25 Range #25 | Waiting for historical downloads to complete with the IDs: 16, | 2014-11-05 05:41:39
ESZ4-CME [CV] 1.25 Range #13 | Symbols used for continuous contract chart: | 2014-11-05 05:41:39
ESZ4-CME [CV] 1.25 Range #13 | Waiting for historical downloads to complete with the IDs: 16, | 2014-11-05 05:41:39
ESZ4-CME [CV] 1.25 Range #7 | Symbols used for continuous contract chart: | 2014-11-05 05:41:39
ESZ4-CME [CV] 1.25 Range #7 | Waiting for historical downloads to complete with the IDs: 16, | 2014-11-05 05:41:39
ESZ4-CME [CV] 15 Min #21 | Symbols used for continuous contract chart: | 2014-11-05 05:41:39
ESZ4-CME [CV] 15 Min #21 | Waiting for historical downloads to complete with the IDs: 16, | 2014-11-05 05:41:39
HD Request # 17 | Downloading Intraday chart data for ESZ4-CME to the file ESZ4-CME.scid. Service: rim | 2014-11-05 05:41:39
HD Request # 17 | Download start Date-Time: 1987-06-20 06:41:39.0 | 2014-11-05 05:41:39
HD Request # 17 | Using server: ds4.sierracharts.com port 10149 | 2014-11-05 05:41:39
Currently no data in file to display. Will start historical data download and real-time updates. File: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:41:39
Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-11-05 05:41:39
Socket (932) | Connected. | 2014-11-05 05:41:39
HD Request # 17 | Sending historical data logon request message. | 2014-11-05 05:41:39
HD Request # 17 | Requesting Intraday data. Start Date-Time: 1987-06-20 06:41:39. Record interval: 0. Symbol: ESZ4-CME | 2014-11-05 05:41:39
HD Request # 17 | Decompressing data. | 2014-11-05 05:41:39
HD Request # 17 | Receiving Intraday data for ESZ4-CME starting at 2014-06-30 23:30:31 | 2014-11-05 05:41:39
HD Request # 17 | Timestamp of first Intraday data file record written: 2014-06-30 23:30:31 | 2014-11-05 05:41:39
ESZ4-CME 1.25 Range #19 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:41:37. Next Bar Date Time: 2014-09-12 10:51:40. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:41:45
ESZ4-CME 1.25 Range #19 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:41:45. Next Bar Date Time: 2014-09-19 09:00:17. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:41:50
ESZ4-CME 1.25 Range #19 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:41:49. Next Bar Date Time: 2014-09-22 09:21:19. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:41:51
ESZ4-CME 1.25 Range #19 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:41:51. Next Bar Date Time: 2014-09-23 07:02:18. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:41:52
ESZ4-CME 1.25 Range #19 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:41:52. Next Bar Date Time: 2014-09-23 08:24:59. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:41:53
ESZ4-CME 1.25 Range #19 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:41:53. Next Bar Date Time: 2014-09-24 04:47:28. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:41:54
ESZ4-CME 1.25 Range #19 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:41:54. Next Bar Date Time: 2014-09-24 12:00:25. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:41:55
ESZ4-CME 1.25 Range #19 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:41:54. Next Bar Date Time: 2014-09-25 12:23:46. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:41:57
ESZ4-CME 1.25 Range #19 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:41:57. Next Bar Date Time: 2014-09-26 12:47:08. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:41:59
ESZ4-CME 1.25 Range #19 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:41:58. Next Bar Date Time: 2014-09-29 10:41:55. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:42:00
ESZ4-CME 1.25 Range #19 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:42:00. Next Bar Date Time: 2014-09-30 10:49:24. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:42:03
ESZ4-CME 1.25 Range #19 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:42:02. Next Bar Date Time: 2014-10-01 00:35:27. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:42:03
ESZ4-CME 1.25 Range #19 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:42:03. Next Bar Date Time: 2014-10-01 07:38:08. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:42:04
ESZ4-CME 1.25 Range #19 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:42:04. Next Bar Date Time: 2014-10-02 03:19:13. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:42:06
ESZ4-CME 1.25 Range #19 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:42:05. Next Bar Date Time: 2014-10-02 06:48:49. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:42:06
ESZ4-CME 1.25 Range #19 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:42:05. Next Bar Date Time: 2014-10-03 07:20:45. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:42:09
ESZ4-CME 1.25 Range #19 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:42:08. Next Bar Date Time: 2014-10-07 08:58:02. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:42:13
ESZ4-CME 1.25 Range #19 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:42:12. Next Bar Date Time: 2014-10-08 10:34:52. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:42:15
Socket (932) | Shutdown and closed. | 2014-11-05 05:43:05
The network socket for historical data has been closed. | 2014-11-05 05:43:05
HD Request # 17 | Received 23389233 records from 2014-06-30 23:30:31 to 2014-11-05 05:43:01 (127.3 days) and wrote 23389233 records for ESZ4-CME | 2014-11-05 05:43:05
HD Request # 17 | Intraday download COMPLETE for ESZ4-CME. Completion time: 1m 26s. Unique request ID: 16 | 2014-11-05 05:43:05
Removed historical data download ID 16 | 2014-11-05 05:43:05
Real-time Intraday chart data file updates started for ESZ4-CME | 2014-11-05 05:43:05
ESZ4-CME [CV] 1.25 Range #7: Download is complete for all contract months in chart. Proceeding with data load. | 2014-11-05 05:43:05
ESZ4-CME [CV] 1.25 Range #7: Checking for volume based rollover dates. | 2014-11-05 05:43:05
ESZ4-CME [CV] 1.25 Range #7: Volume based rollover from ESH4-CME to ESM4-CME occurs at 2014-03-14 | 2014-11-05 05:43:05
ESZ4-CME [CV] 1.25 Range #7: Volume based rollover from ESM4-CME to ESU4-CME occurs at 2014-06-13 | 2014-11-05 05:43:05
ESZ4-CME [CV] 1.25 Range #7: Volume based rollover from ESU4-CME to ESZ4-CME occurs at 2014-09-12 | 2014-11-05 05:43:05
ESZ4-CME [CV] 1 Day #9: Download is complete for all contract months in chart. Proceeding with data load. | 2014-11-05 05:43:05
ESZ4-CME [CV] 1 Day #9: Checking for volume based rollover dates. | 2014-11-05 05:43:05
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESZ9-CME to ESH0-CME occurs at 2009-12-11 | 2014-11-05 05:43:05
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESH0-CME to ESM0-CME occurs at 2010-03-12 | 2014-11-05 05:43:05
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESM0-CME to ESU0-CME occurs at 2010-06-11 | 2014-11-05 05:43:05
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESU0-CME to ESZ0-CME occurs at 2010-09-10 | 2014-11-05 05:43:05
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESZ0-CME to ESH1-CME occurs at 2010-12-10 | 2014-11-05 05:43:05
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESH1-CME to ESM1-CME occurs at 2011-03-11 | 2014-11-05 05:43:05
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESM1-CME to ESU1-CME occurs at 2011-06-10 | 2014-11-05 05:43:05
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESU1-CME to ESZ1-CME occurs at 2011-09-09 | 2014-11-05 05:43:05
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESZ1-CME to ESH2-CME occurs at 2011-12-09 | 2014-11-05 05:43:05
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESH2-CME to ESM2-CME occurs at 2012-03-09 | 2014-11-05 05:43:05
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESM2-CME to ESU2-CME occurs at 2012-06-08 | 2014-11-05 05:43:05
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESU2-CME to ESZ2-CME occurs at 2012-09-14 | 2014-11-05 05:43:05
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESZ2-CME to ESH3-CME occurs at 2012-12-14 | 2014-11-05 05:43:05
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESH3-CME to ESM3-CME occurs at 2013-03-08 | 2014-11-05 05:43:05
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESM3-CME to ESU3-CME occurs at 2013-06-14 | 2014-11-05 05:43:05
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESU3-CME to ESZ3-CME occurs at 2013-09-13 | 2014-11-05 05:43:05
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESZ3-CME to ESH4-CME occurs at 2013-12-13 | 2014-11-05 05:43:05
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESH4-CME to ESM4-CME occurs at 2014-03-14 | 2014-11-05 05:43:05
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESM4-CME to ESU4-CME occurs at 2014-06-13 | 2014-11-05 05:43:05
ESZ4-CME [CV] 1 Day #9: Volume based rollover from ESU4-CME to ESZ4-CME occurs at 2014-09-12 | 2014-11-05 05:43:05
ESZ4-CME [CV] 15 Min #21: Download is complete for all contract months in chart. Proceeding with data load. | 2014-11-05 05:43:05
ESZ4-CME [CV] 15 Min #21: Checking for volume based rollover dates. | 2014-11-05 05:43:05
ESZ4-CME [CV] 15 Min #21: Volume based rollover from ESM3-CME to ESU3-CME occurs at 2013-06-14 | 2014-11-05 05:43:05
ESZ4-CME [CV] 15 Min #21: Volume based rollover from ESU3-CME to ESZ3-CME occurs at 2013-09-13 | 2014-11-05 05:43:05
ESZ4-CME [CV] 15 Min #21: Volume based rollover from ESZ3-CME to ESH4-CME occurs at 2013-12-13 | 2014-11-05 05:43:05
ESZ4-CME [CV] 15 Min #21: Volume based rollover from ESH4-CME to ESM4-CME occurs at 2014-03-14 | 2014-11-05 05:43:05
ESZ4-CME [CV] 15 Min #21: Volume based rollover from ESM4-CME to ESU4-CME occurs at 2014-06-13 | 2014-11-05 05:43:05
ESZ4-CME [CV] 15 Min #21: Volume based rollover from ESU4-CME to ESZ4-CME occurs at 2014-09-12 | 2014-11-05 05:43:05
ESZ4-CME [CV] 10 Sec #15: Download is complete for all contract months in chart. Proceeding with data load. | 2014-11-05 05:43:05
ESZ4-CME [CV] 10 Sec #15: Checking for volume based rollover dates. | 2014-11-05 05:43:05
ESZ4-CME [CV] 10 Sec #15: Volume based rollover from ESH4-CME to ESM4-CME occurs at 2014-03-14 | 2014-11-05 05:43:05
ESZ4-CME [CV] 10 Sec #15: Volume based rollover from ESM4-CME to ESU4-CME occurs at 2014-06-13 | 2014-11-05 05:43:05
ESZ4-CME [CV] 10 Sec #15: Volume based rollover from ESU4-CME to ESZ4-CME occurs at 2014-09-12 | 2014-11-05 05:43:05
ESZ4-CME [CV] 2000 Volume #17: Download is complete for all contract months in chart. Proceeding with data load. | 2014-11-05 05:43:05
ESZ4-CME [CV] 2000 Volume #17: Checking for volume based rollover dates. | 2014-11-05 05:43:05
ESZ4-CME [CV] 15 Min #11: Download is complete for all contract months in chart. Proceeding with data load. | 2014-11-05 05:43:05
ESZ4-CME [CV] 15 Min #11: Checking for volume based rollover dates. | 2014-11-05 05:43:05
ESZ4-CME [CV] 15 Min #11: Volume based rollover from ESM3-CME to ESU3-CME occurs at 2013-06-14 | 2014-11-05 05:43:05
ESZ4-CME [CV] 15 Min #11: Volume based rollover from ESU3-CME to ESZ3-CME occurs at 2013-09-13 | 2014-11-05 05:43:05
ESZ4-CME [CV] 15 Min #11: Volume based rollover from ESZ3-CME to ESH4-CME occurs at 2013-12-13 | 2014-11-05 05:43:05
ESZ4-CME [CV] 15 Min #11: Volume based rollover from ESH4-CME to ESM4-CME occurs at 2014-03-14 | 2014-11-05 05:43:05
ESZ4-CME [CV] 15 Min #11: Volume based rollover from ESM4-CME to ESU4-CME occurs at 2014-06-13 | 2014-11-05 05:43:05
ESZ4-CME [CV] 15 Min #11: Volume based rollover from ESU4-CME to ESZ4-CME occurs at 2014-09-12 | 2014-11-05 05:43:05
ESZ4-CME [C] 1 Min #20: Download is complete for all contract months in chart. Proceeding with data load. | 2014-11-05 05:43:05
ESZ4-CME [CV] 30 Min #23: Download is complete for all contract months in chart. Proceeding with data load. | 2014-11-05 05:43:05
ESZ4-CME [CV] 30 Min #23: Checking for volume based rollover dates. | 2014-11-05 05:43:05
ESZ4-CME [CV] 30 Min #23: Volume based rollover from ESZ3-CME to ESH4-CME occurs at 2013-12-13 | 2014-11-05 05:43:05
ESZ4-CME [CV] 30 Min #23: Volume based rollover from ESH4-CME to ESM4-CME occurs at 2014-03-14 | 2014-11-05 05:43:05
ESZ4-CME [CV] 30 Min #23: Volume based rollover from ESM4-CME to ESU4-CME occurs at 2014-06-13 | 2014-11-05 05:43:05
ESZ4-CME [CV] 30 Min #23: Volume based rollover from ESU4-CME to ESZ4-CME occurs at 2014-09-12 | 2014-11-05 05:43:05
ESZ4-CME [CV] 2.50 Range #22: Download is complete for all contract months in chart. Proceeding with data load. | 2014-11-05 05:43:05
ESZ4-CME [CV] 2.50 Range #22: Checking for volume based rollover dates. | 2014-11-05 05:43:05
ESZ4-CME [CV] 2.50 Range #22: Volume based rollover from ESM3-CME to ESU3-CME occurs at 2013-06-14 | 2014-11-05 05:43:05
ESZ4-CME [CV] 2.50 Range #22: Volume based rollover from ESU3-CME to ESZ3-CME occurs at 2013-09-13 | 2014-11-05 05:43:05
ESZ4-CME [CV] 2.50 Range #22: Volume based rollover from ESZ3-CME to ESH4-CME occurs at 2013-12-13 | 2014-11-05 05:43:05
ESZ4-CME [CV] 2.50 Range #22: Volume based rollover from ESH4-CME to ESM4-CME occurs at 2014-03-14 | 2014-11-05 05:43:05
ESZ4-CME [CV] 2.50 Range #22: Volume based rollover from ESM4-CME to ESU4-CME occurs at 2014-06-13 | 2014-11-05 05:43:06
ESZ4-CME [CV] 2.50 Range #22: Volume based rollover from ESU4-CME to ESZ4-CME occurs at 2014-09-12 | 2014-11-05 05:43:06
ESZ4-CME [CV] 5 Min #12: Download is complete for all contract months in chart. Proceeding with data load. | 2014-11-05 05:43:06
ESZ4-CME [CV] 5 Min #12: Checking for volume based rollover dates. | 2014-11-05 05:43:06
ESZ4-CME [CV] 1 Min #4: Download is complete for all contract months in chart. Proceeding with data load. | 2014-11-05 05:43:06
ESZ4-CME [CV] 1 Min #4: Checking for volume based rollover dates. | 2014-11-05 05:43:06
ESZ4-CME [CV] 15 Min #24: Download is complete for all contract months in chart. Proceeding with data load. | 2014-11-05 05:43:06
ESZ4-CME [CV] 15 Min #24: Checking for volume based rollover dates. | 2014-11-05 05:43:06
ESZ4-CME [CV] 1 Min #3: Download is complete for all contract months in chart. Proceeding with data load. | 2014-11-05 05:43:07
ESZ4-CME [CV] 1 Min #3: Checking for volume based rollover dates. | 2014-11-05 05:43:07
ESZ4-CME [CV] 1 Min #3: Volume based rollover from ESU2-CME to ESZ2-CME occurs at 2012-09-14 | 2014-11-05 05:43:07
ESZ4-CME [CV] 1 Min #3: Volume based rollover from ESZ2-CME to ESH3-CME occurs at 2012-12-14 | 2014-11-05 05:43:07
ESZ4-CME [CV] 1 Min #3: Volume based rollover from ESH3-CME to ESM3-CME occurs at 2013-03-08 | 2014-11-05 05:43:07
ESZ4-CME [CV] 1 Min #3: Volume based rollover from ESM3-CME to ESU3-CME occurs at 2013-06-14 | 2014-11-05 05:43:07
ESZ4-CME [CV] 1 Min #3: Volume based rollover from ESU3-CME to ESZ3-CME occurs at 2013-09-13 | 2014-11-05 05:43:07
ESZ4-CME [CV] 1 Min #3: Volume based rollover from ESZ3-CME to ESH4-CME occurs at 2013-12-13 | 2014-11-05 05:43:07
ESZ4-CME [CV] 1 Min #3: Volume based rollover from ESH4-CME to ESM4-CME occurs at 2014-03-14 | 2014-11-05 05:43:07
ESZ4-CME [CV] 1 Min #3: Volume based rollover from ESM4-CME to ESU4-CME occurs at 2014-06-13 | 2014-11-05 05:43:07
ESZ4-CME [CV] 1 Min #3: Volume based rollover from ESU4-CME to ESZ4-CME occurs at 2014-09-12 | 2014-11-05 05:43:07
ESZ4-CME [CV] 1.25 Range #25: Download is complete for all contract months in chart. Proceeding with data load. | 2014-11-05 05:43:07
ESZ4-CME [CV] 1.25 Range #25: Checking for volume based rollover dates. | 2014-11-05 05:43:07
ESZ4-CME [CV] 1.25 Range #13: Download is complete for all contract months in chart. Proceeding with data load. | 2014-11-05 05:43:07
ESZ4-CME [CV] 1.25 Range #13: Checking for volume based rollover dates. | 2014-11-05 05:43:07
ESZ4-CME [CV] 1.25 Range #13: Volume based rollover from ESH4-CME to ESM4-CME occurs at 2014-03-14 | 2014-11-05 05:43:07
ESZ4-CME [CV] 1.25 Range #13: Volume based rollover from ESM4-CME to ESU4-CME occurs at 2014-06-13 | 2014-11-05 05:43:07
ESZ4-CME [CV] 1.25 Range #13: Volume based rollover from ESU4-CME to ESZ4-CME occurs at 2014-09-12 | 2014-11-05 05:43:07
ESZ4-CME [CV] 1 Min #2: Download is complete for all contract months in chart. Proceeding with data load. | 2014-11-05 05:43:08
ESZ4-CME [CV] 1 Min #2: Checking for volume based rollover dates. | 2014-11-05 05:43:08
ESZ4-CME [CV] 1 Min #2: Volume based rollover from ESH4-CME to ESM4-CME occurs at 2014-03-14 | 2014-11-05 05:43:08
ESZ4-CME [CV] 1 Min #2: Volume based rollover from ESM4-CME to ESU4-CME occurs at 2014-06-13 | 2014-11-05 05:43:08
ESZ4-CME [CV] 1 Min #2: Volume based rollover from ESU4-CME to ESZ4-CME occurs at 2014-09-12 | 2014-11-05 05:43:08
ESZ4-CME [CV] 15 Min #24 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:30:00. Next Bar Date Time: 2014-10-31 07:30:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:43:08
ESZ4-CME [CV] 1.25 Range #25 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:42:08. Next Bar Date Time: 2014-10-07 08:58:02. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:43:08
ESZ4-CME [CV] 15 Min #24 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:30:00. Next Bar Date Time: 2014-10-31 10:30:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:43:08
ESZ4-CME [CV] 15 Min #24 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:30:00. Next Bar Date Time: 2014-10-31 12:30:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:43:08
ESZ4-CME [CV] 1.25 Range #25 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:42:12. Next Bar Date Time: 2014-10-08 10:34:52. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:43:09
ESZ4-CME [CV] 1.25 Range #25 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:42:15. Next Bar Date Time: 2014-10-09 00:10:27. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:43:09
ESZ4-CME [CV] 1.25 Range #25 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:42:16. Next Bar Date Time: 2014-10-09 05:36:04. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:43:09
ESZ4-CME [CV] 1.25 Range #25 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:42:16. Next Bar Date Time: 2014-10-09 12:11:10. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:43:10
ESZ4-CME [CV] 1.25 Range #25 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:42:18. Next Bar Date Time: 2014-10-10 07:10:14. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:43:10
ESZ4-CME [CV] 1.25 Range #25 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:42:20. Next Bar Date Time: 2014-10-10 07:56:05. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:43:10
ESZ4-CME [CV] 1.25 Range #25 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:42:21. Next Bar Date Time: 2014-10-10 11:50:47. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:43:10
ESZ4-CME [CV] 1.25 Range #25 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:42:22. Next Bar Date Time: 2014-10-10 12:18:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:43:10
ESZ4-CME [CV] 1.25 Range #25 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:42:22. Next Bar Date Time: 2014-10-13 06:39:54. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:43:11
ESZ4-CME [CV] 1.25 Range #25 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:42:23. Next Bar Date Time: 2014-10-13 10:41:17. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:43:11
ESZ4-CME [CV] 1.25 Range #25 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:42:24. Next Bar Date Time: 2014-10-15 06:23:16. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:43:12
ESZ4-CME [CV] 1.25 Range #25 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:42:29. Next Bar Date Time: 2014-10-15 06:51:46. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:43:12
ESZ4-CME [CV] 1.25 Range #25 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:42:29. Next Bar Date Time: 2014-10-15 09:45:49. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:43:12
ESZ4-CME [CV] 1.25 Range #25 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:42:31. Next Bar Date Time: 2014-10-16 07:10:38. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:43:13
ESZ4-CME [CV] 1.25 Range #25 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:42:35. Next Bar Date Time: 2014-10-17 12:34:57. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:43:14
ESZ4-CME [CV] 1.25 Range #25 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:42:40. Next Bar Date Time: 2014-10-21 06:56:34. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:43:14
ESZ4-CME [CV] 1.25 Range #25 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:42:44. Next Bar Date Time: 2014-10-23 00:44:35. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:43:15
ESZ4-CME [CV] 1.25 Range #25 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:42:47. Next Bar Date Time: 2014-10-29 07:29:42. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:43:17
ESZ4-CME [CV] 1.25 Range #25 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:42:56. Next Bar Date Time: 2014-10-31 07:30:49. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:43:18
ESZ4-CME [CV] 2.50 Range #22 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:41:37. Next Bar Date Time: 2014-09-12 10:51:40. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:43:47
ESZ4-CME [CV] 2.50 Range #22 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:41:45. Next Bar Date Time: 2014-09-19 09:00:17. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:43:47
ESZ4-CME [CV] 2.50 Range #22 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:41:49. Next Bar Date Time: 2014-09-22 09:21:19. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:43:47
ESZ4-CME [CV] 2.50 Range #22 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:41:51. Next Bar Date Time: 2014-09-23 07:02:18. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:43:48
ESZ4-CME [CV] 2.50 Range #22 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:41:52. Next Bar Date Time: 2014-09-23 08:24:59. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:43:48
ESZ4-CME [CV] 2.50 Range #22 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:41:53. Next Bar Date Time: 2014-09-24 04:47:28. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:43:48
ESZ4-CME [CV] 2.50 Range #22 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:41:54. Next Bar Date Time: 2014-09-24 12:00:25. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:43:48
ESZ4-CME [CV] 2.50 Range #22 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:41:54. Next Bar Date Time: 2014-09-25 12:23:46. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:43:48
ESZ4-CME [CV] 2.50 Range #22 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:41:57. Next Bar Date Time: 2014-09-26 12:47:08. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:43:48
ESZ4-CME [CV] 2.50 Range #22 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:41:58. Next Bar Date Time: 2014-09-29 10:41:55. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:43:49
ESZ4-CME [CV] 2.50 Range #22 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:42:00. Next Bar Date Time: 2014-09-30 10:49:24. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:43:49
ESZ4-CME [CV] 2.50 Range #22 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:42:02. Next Bar Date Time: 2014-10-01 00:35:27. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:43:49
ESZ4-CME [CV] 2.50 Range #22 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:42:03. Next Bar Date Time: 2014-10-01 07:38:08. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:43:49
ESZ4-CME [CV] 2.50 Range #22 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:42:04. Next Bar Date Time: 2014-10-02 03:19:13. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:43:49
ESZ4-CME [CV] 2.50 Range #22 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:42:05. Next Bar Date Time: 2014-10-02 06:48:49. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:43:49
ESZ4-CME [CV] 2.50 Range #22 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:42:05. Next Bar Date Time: 2014-10-03 07:20:45. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:43:50
ESZ4-CME [CV] 2.50 Range #22 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:42:08. Next Bar Date Time: 2014-10-07 08:58:02. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:43:50
ESZ4-CME [CV] 2.50 Range #22 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:42:12. Next Bar Date Time: 2014-10-08 10:34:52. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:43:50
ESZ4-CME [CV] 2.50 Range #22 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:42:15. Next Bar Date Time: 2014-10-09 00:10:27. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:43:50
ESZ4-CME [CV] 2.50 Range #22 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:42:16. Next Bar Date Time: 2014-10-09 05:36:04. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:43:51
ESZ4-CME [CV] 10 Sec #15 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:41:30. Next Bar Date Time: 2014-09-12 10:51:40. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:43:58
ESZ4-CME [CV] 10 Sec #15 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:41:40. Next Bar Date Time: 2014-09-19 09:00:10. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:00
ESZ4-CME [CV] 10 Sec #15 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:41:40. Next Bar Date Time: 2014-09-22 09:21:10. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:00
ESZ4-CME [CV] 30 Min #23 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:30:00. Next Bar Date Time: 2014-09-12 10:30:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:00
ESZ4-CME [CV] 10 Sec #15 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:41:50. Next Bar Date Time: 2014-09-23 07:02:10. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:00
ESZ4-CME [CV] 10 Sec #15 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:41:50. Next Bar Date Time: 2014-09-23 08:24:50. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:00
ESZ4-CME [CV] 10 Sec #15 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:41:50. Next Bar Date Time: 2014-09-24 04:47:20. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:00
ESZ4-CME [CV] 10 Sec #15 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:41:50. Next Bar Date Time: 2014-09-24 12:00:20. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:01
ESZ4-CME [CV] 30 Min #23 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:30:00. Next Bar Date Time: 2014-09-19 09:00:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:01
ESZ4-CME [CV] 10 Sec #15 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:41:50. Next Bar Date Time: 2014-09-25 12:23:40. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:01
ESZ4-CME [CV] 30 Min #23 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:30:00. Next Bar Date Time: 2014-09-22 09:00:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:01
ESZ4-CME [CV] 10 Sec #15 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:41:50. Next Bar Date Time: 2014-09-26 12:47:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:01
ESZ4-CME [CV] 30 Min #23 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:30:00. Next Bar Date Time: 2014-09-23 07:00:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:01
ESZ4-CME [CV] 30 Min #23 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:30:00. Next Bar Date Time: 2014-09-23 08:00:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:01
ESZ4-CME [CV] 30 Min #23 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:30:00. Next Bar Date Time: 2014-09-24 04:30:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:01
ESZ4-CME [CV] 10 Sec #15 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:41:50. Next Bar Date Time: 2014-09-29 10:41:50. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:02
ESZ4-CME [CV] 30 Min #23 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:30:00. Next Bar Date Time: 2014-09-24 12:00:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:02
ESZ4-CME [CV] 10 Sec #15 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:42:00. Next Bar Date Time: 2014-09-30 10:49:20. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:02
ESZ4-CME [CV] 10 Sec #15 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:42:00. Next Bar Date Time: 2014-10-01 00:35:20. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:02
ESZ4-CME [CV] 30 Min #23 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:30:00. Next Bar Date Time: 2014-09-25 12:00:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:02
ESZ4-CME [CV] 10 Sec #15 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:42:00. Next Bar Date Time: 2014-10-01 07:38:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:02
ESZ4-CME [CV] 30 Min #23 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:30:00. Next Bar Date Time: 2014-09-26 12:30:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:02
ESZ4-CME [CV] 10 Sec #15 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:42:00. Next Bar Date Time: 2014-10-02 03:19:10. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:02
ESZ4-CME [CV] 10 Sec #15 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:42:00. Next Bar Date Time: 2014-10-02 06:48:40. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:02
ESZ4-CME [CV] 30 Min #23 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:30:00. Next Bar Date Time: 2014-09-29 10:30:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:02
ESZ4-CME [CV] 30 Min #23 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:30:00. Next Bar Date Time: 2014-09-30 10:30:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:03
ESZ4-CME [CV] 30 Min #23 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:30:00. Next Bar Date Time: 2014-10-01 00:30:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:03
ESZ4-CME [CV] 10 Sec #15 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:42:00. Next Bar Date Time: 2014-10-03 07:20:40. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:03
ESZ4-CME [CV] 30 Min #23 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:30:00. Next Bar Date Time: 2014-10-01 07:30:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:03
ESZ4-CME [CV] 30 Min #23 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:30:00. Next Bar Date Time: 2014-10-02 03:00:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:03
ESZ4-CME [CV] 30 Min #23 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:30:00. Next Bar Date Time: 2014-10-02 06:30:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:03
ESZ4-CME [CV] 10 Sec #15 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:42:00. Next Bar Date Time: 2014-10-07 08:58:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:03
ESZ4-CME [CV] 30 Min #23 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:30:00. Next Bar Date Time: 2014-10-03 07:00:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:04
ESZ4-CME [CV] 10 Sec #15 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:42:10. Next Bar Date Time: 2014-10-08 10:34:50. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:04
ESZ4-CME [CV] 30 Min #23 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:30:00. Next Bar Date Time: 2014-10-07 08:30:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:04
ESZ4-CME [CV] 10 Sec #15 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:42:10. Next Bar Date Time: 2014-10-09 00:10:20. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:04
ESZ4-CME [CV] 10 Sec #15 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:42:10. Next Bar Date Time: 2014-10-09 05:36:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:04
ESZ4-CME [CV] 30 Min #23 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:30:00. Next Bar Date Time: 2014-10-08 10:30:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:04
ESZ4-CME [CV] 30 Min #23 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:30:00. Next Bar Date Time: 2014-10-09 00:00:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:04
ESZ4-CME [CV] 30 Min #23 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:30:00. Next Bar Date Time: 2014-10-09 05:30:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:05
ESZ4-CME [CV] 1.25 Range #13 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:41:37. Next Bar Date Time: 2014-09-12 10:51:40. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:25
ESZ4-CME [CV] 1.25 Range #13 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:41:45. Next Bar Date Time: 2014-09-19 09:00:17. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:26
ESZ4-CME [CV] 1.25 Range #13 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:41:49. Next Bar Date Time: 2014-09-22 09:21:19. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:27
ESZ4-CME [CV] 1.25 Range #13 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:41:51. Next Bar Date Time: 2014-09-23 07:02:18. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:27
ESZ4-CME [CV] 1.25 Range #13 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:41:52. Next Bar Date Time: 2014-09-23 08:24:59. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:27
ESZ4-CME [CV] 1.25 Range #13 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:41:53. Next Bar Date Time: 2014-09-24 04:47:28. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:27
ESZ4-CME [CV] 1.25 Range #13 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:41:54. Next Bar Date Time: 2014-09-24 12:00:25. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:27
ESZ4-CME [CV] 1 Min #2 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:41:00. Next Bar Date Time: 2014-09-12 10:51:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:27
ESZ4-CME [CV] 1.25 Range #13 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:41:54. Next Bar Date Time: 2014-09-25 12:23:46. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:28
ESZ4-CME [CV] 1.25 Range #13 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:41:57. Next Bar Date Time: 2014-09-26 12:47:08. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:28
ESZ4-CME [CV] 1 Min #2 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:41:00. Next Bar Date Time: 2014-09-19 09:00:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:28
ESZ4-CME [CV] 1.25 Range #13 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:41:58. Next Bar Date Time: 2014-09-29 10:41:55. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:28
ESZ4-CME [CV] 1 Min #2 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:41:00. Next Bar Date Time: 2014-09-22 09:21:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:28
ESZ4-CME [CV] 1 Min #2 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:41:00. Next Bar Date Time: 2014-09-23 07:02:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:28
ESZ4-CME [CV] 1 Min #2 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:41:00. Next Bar Date Time: 2014-09-23 08:24:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:28
ESZ4-CME [CV] 1.25 Range #13 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:42:00. Next Bar Date Time: 2014-09-30 10:49:24. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:28
ESZ4-CME [CV] 1 Min #2 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:41:00. Next Bar Date Time: 2014-09-24 04:47:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:29
ESZ4-CME [CV] 1 Min #2 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:41:00. Next Bar Date Time: 2014-09-24 12:00:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:29
ESZ4-CME [CV] 1.25 Range #13 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:42:02. Next Bar Date Time: 2014-10-01 00:35:27. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:29
ESZ4-CME [CV] 1.25 Range #13 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:42:03. Next Bar Date Time: 2014-10-01 07:38:08. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:29
ESZ4-CME [CV] 1 Min #2 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:41:00. Next Bar Date Time: 2014-09-25 12:23:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:29
ESZ4-CME [CV] 1.25 Range #13 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:42:04. Next Bar Date Time: 2014-10-02 03:19:13. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:29
ESZ4-CME [CV] 1.25 Range #13 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:42:05. Next Bar Date Time: 2014-10-02 06:48:49. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:29
ESZ4-CME [CV] 1 Min #2 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:41:00. Next Bar Date Time: 2014-09-26 12:47:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:29
ESZ4-CME [C] 1 Min #20 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:41:00. Next Bar Date Time: 2014-09-12 10:51:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:29
ESZ4-CME [CV] 1 Min #2 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:41:00. Next Bar Date Time: 2014-09-29 10:41:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:29
ESZ4-CME [CV] 1.25 Range #13 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:42:05. Next Bar Date Time: 2014-10-03 07:20:45. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:29
ESZ4-CME [CV] 1 Min #2 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:42:00. Next Bar Date Time: 2014-09-30 10:49:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:30
ESZ4-CME [CV] 1 Min #2 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:42:00. Next Bar Date Time: 2014-10-01 00:35:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:30
ESZ4-CME [CV] 1 Min #2 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:42:00. Next Bar Date Time: 2014-10-01 07:38:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:30
ESZ4-CME [CV] 1.25 Range #13 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:42:08. Next Bar Date Time: 2014-10-07 08:58:02. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:30
ESZ4-CME [CV] 1 Min #2 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:42:00. Next Bar Date Time: 2014-10-02 03:19:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:30
ESZ4-CME [CV] 1 Min #2 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:42:00. Next Bar Date Time: 2014-10-02 06:48:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:30
ESZ4-CME [CV] 1.25 Range #13 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:42:12. Next Bar Date Time: 2014-10-08 10:34:52. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:30
ESZ4-CME [CV] 1 Min #2 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:42:00. Next Bar Date Time: 2014-10-03 07:20:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:30
ESZ4-CME [CV] 1.25 Range #13 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:42:15. Next Bar Date Time: 2014-10-09 00:10:27. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:30
ESZ4-CME [CV] 1.25 Range #13 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:42:16. Next Bar Date Time: 2014-10-09 05:36:04. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:31
ESZ4-CME [C] 1 Min #20 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:41:00. Next Bar Date Time: 2014-09-19 09:00:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:31
ESZ4-CME [C] 1 Min #20 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:41:00. Next Bar Date Time: 2014-09-22 09:21:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:31
ESZ4-CME [CV] 1 Min #2 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:42:00. Next Bar Date Time: 2014-10-07 08:58:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:31
ESZ4-CME [C] 1 Min #20 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:41:00. Next Bar Date Time: 2014-09-23 07:02:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:31
ESZ4-CME [C] 1 Min #20 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:41:00. Next Bar Date Time: 2014-09-23 08:24:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:31
ESZ4-CME [CV] 1 Min #2 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:42:00. Next Bar Date Time: 2014-10-08 10:34:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:31
ESZ4-CME [C] 1 Min #20 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:41:00. Next Bar Date Time: 2014-09-24 04:47:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:31
ESZ4-CME [CV] 1 Min #2 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:42:00. Next Bar Date Time: 2014-10-09 00:10:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:31
ESZ4-CME [C] 1 Min #20 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2014-11-05 05:41:00. Next Bar Date Time: 2014-09-24 12:00:00. Filename: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ESZ4-CME.scid | 2014-11-05 05:44:31
[2014-11-05 17:44:54]
This is the problem:
Data Files path: C:\Users\Trader\Desktop\Dropbox\Trading\SierraChart - Trading PC\Data\ | 2014-11-04 15:06:29
You are sharing a Data Files Folder with your other copy of Sierra Chart! Do not do that. Change this through Global Settings >> General Settings.
Date Time Of Last Edit: 2014-11-05 17:45:21
[2014-11-05 18:17:34]
OneMoreTick - Posts: 79
Ahhh ok, thank you!
