Date/Time: Mon, 16 Nov 2026 08:09:32 +0000
How to disable Order Confirmations
View Count: 329
| [2026-08-12 13:58:43] |
| User121101 - Posts: 18 |
Hi, somehow my trade confirmation has turned on, so when i move my stop or Take-profit i get a pop-up message confirming it. Would you let me know how to turn it off? see attached printscreen for more info. Thanks. |
| [2026-08-12 14:02:57] |
| User135243 - Posts: 334 |
Click the "M" on your DOM and there go to "Confirmation" and uncheck
| [2026-08-12 14:04:26] |
| Sierra_Chart Engineering - Posts: 25428 |
Refer to this section here: Basic Trading and the Trade Window: Main/C >> Menu >> Order Confirmations (chart specific) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-08-12 14:07:04] |
Hi again, I figured it out and would like to share what i learned from one of the other traders in my community. on the trade window , under the main tab, there is an M button just above the 6. If you click that, a pop-up window appears. From there you hover-over confirmations and can then click on and off whatever type of confirmation you would like or not like. hope this helps, give it a thank you if it does. |
