Date/Time: Tue, 17 Nov 2026 19:06:57 +0000
[Feature request] Can a single hotkey use the Buy/Sell column logic based on Last
View Count: 382
[2026-08-12 13:00:10]
User450833 - Posts: 8
I have successfully configured Global Settings >> Chart DOM Settings to behave similarly to Jigsaw daytradr order type section set to Auto option.
Buy Column Above Last > Buy Stop
Sell Column Above/Equal Last > Sell Limit
Buy Column Below/Equal Last > Buy Limit
Sell Column Below Last > Sell Stop
But it requires clicking directly on the Buy or Sell column.
Is it possible to assign a single hotkey to each column, for example:
W → Buy Column behavior
S → Sell Column behavior
The hotkey would use the current pointer price and let the Chart DOM Settings automatically determine whether the order should be a Limit or Stop based on the Last Price.
Currently, the Global Settings >> Trading Keyboard Shortcuts have separate commands for:
Buy Limit at Current Pointer Price
Buy Stop at Current Pointer Price
Sell Limit at Current Pointer Price
Sell Stop at Current Pointer Price
So I would need four different hotkeys. I would like to combine the Buy Limit/Stop behavior into W, and Sell Limit/Stop behavior into S, based on the Last Price.
Is this currently possible? If not currently possible, could this be considered as a feature request?
Thanks.
[2026-08-13 14:59:38]
Sierra_Chart Engineering - Posts: 25432
So you are saying to determine whether the order is a Limit or Stop order based upon the Pointer price in relation to the last traded price, and also whether it is a buy or sell order?
We could probably add another keyboard shortcut for that.
We will note this as a feature request but it would be a long while before we would get to it.
[2026-08-19 02:24:56]
Yes.
I know this is quite a niche feature, so I understand if it’s not a priority yet or might not even be considered.
I’ve already implemented it as a custom study, so no worries if you want to drop the feature request.
const double targetPrice = sc.ChartTradingOrderPrice;
const double lastPrice = sc.LastTradePrice;
sc.SendOrdersToTradeService = sc.GlobalTradeSimulationIsOn ? 0 : 1;
s_SCNewOrder newOrder;
newOrder.OrderQuantity = sc.TradeWindowOrderQuantity;
newOrder.Price1 = targetPrice;
newOrder.Symbol = sc.GetTradeSymbol();
newOrder.TradeAccount = sc.SelectedTradeAccount;
if (isBuyClick)
if (targetPrice > lastPrice)
newOrder.OrderType = SCT_ORDERTYPE_STOP;
else
newOrder.OrderType = SCT_ORDERTYPE_LIMIT;
sc.BuyOrder(newOrder);
else if (isSellClick)
if (targetPrice >= lastPrice)
else
sc.SellOrder(newOrder);
