Date/Time: Tue, 10 Nov 2026 19:11:15 +0000
Order combining into one??
View Count: 307
| [2026-08-11 21:29:33] |
| KylieV1618 - Posts: 79 |
Hi, I used to be able to stagger entry my orders, and every single attached orders, would be its own orders. So I could have say 4 entries each with 3 attached orders, and as I enter into them, their attached orders stay exactly at the offsets I make them. But recently, now....if I layer into a position, it just combines all the offsetted orders, into one big aggregate, and I cant scale out anymore??? What the hell happened? What changed? This is no good. Im hoping its just a setting I accidentally changed. Please help |
| [2026-08-12 20:30:58] |
| Sierra_Chart Engineering - Posts: 25407 |
Make sure you have Scale In disabled: Attached Orders: Scaling In Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
