Date/Time: Tue, 10 Nov 2026 19:11:15 +0000
Show Orders And Position - issue
View Count: 331
| [2026-08-11 20:42:37] |
| Marek F - Posts: 254 |
1. I have 10 charts in my chartbook. 2. On one chart, I have the Show Orders And Position option enabled, while on the remaining charts it is disabled. 3. The Trade Simulation Mode On option is enabled. 4. When the Settlement Price Adjustment occurs near the end of the session, the Show Orders And Position option gets enabled on all charts. This issue does not occur when the Trade Simulation Mode On option is disabled. |
| [2026-08-12 06:38:36] |
| Sierra_Chart Engineering - Posts: 25407 |
What do you mean by this: Settlement Price Adjustment
We have looked into this: the Show Orders And Position option gets enabled on all charts. This issue does not occur when the Trade Simulation Mode On option is disabled.
The reason this would happen, is when Trade Simulation Mode is enabled, and you submit an order from the Trade Window, then this becomes enabled only for the specific chart that the Trade Window is associated with. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-08-12 06:39:09
| [2026-08-12 07:04:10] |
I'm not sure what the technical English term for it is, but it refers to the market data update process that occurs 5 minutes before the session close. Then a market data update appears on the chart. - Daily / Session Close Settlement Processing - MOC Imbalance (Market-On-Close Imbalance) / Imbalance Publication - Closing Data Feed Refresh The reason this would happen, is when Trade Simulation Mode is enabled, and you submit an order from the Trade Window, then this becomes enabled only for the specific chart that the Trade Window is associated with.
I did not submit any order. The described "Settlement Price Adjustment" is the trigger for this issue, but only in the Trade Simulation Mode On enabled.
| [2026-08-12 07:25:06] |
This does not exist: - Daily / Session Close Settlement Processing
- MOC Imbalance (Market-On-Close Imbalance) / Imbalance Publication - Closing Data Feed Refresh You must be using a custom trading study submitting an order. Check the Trade >> Trade Orders Window. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
