Date/Time: Wed, 11 Nov 2026 18:03:41 +0000
Spredsheet
View Count: 318
| [2026-08-11 16:25:13] |
| User841161 - Posts: 357 |
I cleared the values from Column E in my Quotes sheet. However, I have a formula on another sheet that references the Quotes sheet, and it is still calculating using the previous value from Column E. When should the formula recalculate and recognize that the value in Column E has been cleared? Is there something I need to do to force the spreadsheet to recalculate? Thanks, Greg |
| [2026-08-11 22:14:26] |
| Sierra_Chart Engineering - Posts: 25412 |
We need to look into this.
| [2026-08-14 20:49:41] |
We were unable to reproduce this with a quick test. Everything is working as expected when we tried it. We need to get your original spreadsheet, with values in the cells before they were deleted. Instructions to attach: Support Board Posting Information: Attaching a File (Optional) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
