Date/Time: Tue, 10 Nov 2026 19:11:13 +0000
market order receive to market fill : 28.685ms MES futures
View Count: 347
[2026-08-11 14:32:40]
flare9x - Posts: 3
Hello
Querying teton order routing (im with AMP).
Order Received: 14:45:00.061213 (Order from DTC client)
Order Filled: 14:45:00.089898 (Teton CME Routing (Filled))
the time difference is 28.685ms
on a market order is there any explanation of why, sometimes fill times are faster though.
Is there any settings i can check on my side or once its released from sierrachart to be flled its with the gods and nothing can do?
I guess im surprised at how long it takes?
Thanks,
Andrew
[2026-08-11 14:37:09]
Sierra_Chart Engineering - Posts: 25407
You cannot analyze timestamps on your side to determine how fast an order is being processed by the exchange. That can only be looked at on the server and it is consistently under 1 ms.
Also AMP cannot help you with this at all. You are not going to get any accurate information from them about this.
Date Time Of Last Edit: 2026-08-11 14:37:56
[2026-08-12 02:59:49]
flare9x - Posts: 3
Ah ok did not realize that was timestamps local sierrachart so is Chicago to home computer travel time. Sub 1ms seems fine thanks for clarifying.
Date Time Of Last Edit: 2026-08-12 03:00:12
