Date/Time: Tue, 10 Nov 2026 19:11:12 +0000
When running on a live account, Sierra runs super slow, when switching to SIM, it runs OK?
View Count: 290
| [2026-08-11 14:31:05] |
| User172061 - Posts: 36 |
like it says, when is witch to live (which has fills) my sierra runs super slow, but if i move to sim which has no fills, its fine. any ideas?
| [2026-08-11 14:35:42] |
| User273277 - Posts: 145 |
What broker are you trading live with? What is slow in Sierra when trading live for you?
| [2026-08-11 14:38:40] |
AMP everything, even moving the chart around, updating data to show the latest price movement, its all painfully slow. its like being on my old 486 computer from when i was a kid. |
| [2026-08-11 15:01:39] |
| Sierra_Chart Engineering - Posts: 25407 |
Refer to the information here: Chart Trading and the Chart DOM: Improving Performance Of Chart / Trade DOM Best to use a sub instance to move more complex charting there, and then to use the primary instance for trading. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
