Date/Time: Tue, 10 Nov 2026 19:11:13 +0000
Chart Values Tool on Chart DOM
View Count: 299
| [2026-08-11 09:47:27] |
| nosast - Posts: 327 |
Is there a way to extend the chart value crosshair line across ChartDOM columns?
| [2026-08-11 14:28:16] |
| Sierra_Chart Engineering - Posts: 25407 |
No this is not supported. However, there is this option: Chart Settings: Extend Chart DOM Across Entire Chart When Using Ctrl(Buy) / Shift(Sell) (Chart >> Chart Settings >> Trading menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
