Date/Time: Tue, 10 Nov 2026 19:11:11 +0000
DOM horizontal grid line alignment
View Count: 354
| [2026-08-11 08:33:25] |
| User453636 - Posts: 28 |
Dear Support Team! Version: 2922 I'm using a 2 tick compressed DOM (Market Depth Combine Increment in Ticks). Please see in the attached picture, the alignment of the histogram of everything is a bit off to the downside. Could you be so kind and help me so that the histogram's are inside the grid lines? Thank you in advance! |
| [2026-08-11 14:20:53] |
| Sierra_Chart Engineering - Posts: 25407 |
We need to look into this to see how to solve this. Provide that particular chart by following these instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-08-11 14:21:17
| [2026-08-11 15:48:34] |
Thank you!
| [2026-08-12 06:46:18] |
We will check on this as soon as we can.
