Date/Time: Tue, 10 Nov 2026 19:11:14 +0000
VPOC color is spanning more than 1 price
View Count: 379
| [2026-08-10 22:59:38] |
| joshtrader - Posts: 569 |
I updated to 2936 (from 2904 or something like that), and for some reason my profile is coloring more than 1 price for the VPOC. I've never seen this before. Note that I made no changes to anything, the upgrade alone did this. Ticks per bar is 1, chart VaP multiplier is 1, tick size is 0.25. What's going on here? |
| [2026-08-11 01:07:50] |
| Sierra_Chart Engineering - Posts: 25407 |
We will check on this.
| [2026-08-11 20:43:05] |
We cannot reproduce this. We tried the settings you mentioned and other combinations including changing the Value Format of the chart. We need to get that chart following these instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-08-12 06:59:11] |
Chartbook attached
Private File |
| [2026-08-12 14:24:43] |
We see the reason for the problem. This will be solved in the next release. For now change the Value Format setting with the study to .01.
