Date/Time: Mon, 16 Nov 2026 08:09:36 +0000
2936 different shading behaviour
View Count: 490
| [2026-08-10 16:29:16] |
| User273277 - Posts: 145 |
V2936 shading is not working like it did in v2931. I had to down grade versions. This shows up in multiple places. The vwap bands from the Volume Weighted Average Price study are showing without the specified colour (eg. red/green), and only as light shadows. I changed the Draw Study Underneath Main Price Graph setting but it did not fix the issue. Please see attached. Date Time Of Last Edit: 2026-08-10 17:09:06
| [2026-08-10 16:29:34] |
The VBP does the same thing. Just a light shadow on the side, missing the actual colour. Also attached. I reinstalled 2936 between seeing this issue on VWAP and VBP.
Date Time Of Last Edit: 2026-08-11 13:17:11
| [2026-08-12 04:24:33] |
2937 Seems to of fixed the shading behaviour.
| [2026-08-12 14:15:05] |
| Sierra_Chart Engineering - Posts: 25428 |
This is good because we did not fully understand this enough. It sounds like you are using transparent Subgraphs?
| [2026-08-12 15:40:01] |
Yes, transparent Subgraphs. No changes between upgrading/downgrading versions. I did the upgrade/downgrade two times and same result.
| [2026-08-12 20:28:37] |
Are you still noticing a problem with the latest/current version? We ask based on post #3.
| [2026-08-12 20:56:25] |
The problem did not occur in 2937 or the latest 2939 I just tested.
| [2026-08-12 20:59:32] |
This is good.
